Bonsoir,
j’ai compiler mon kernel (sous etch) pour résoudre certains pbs mais depuis j’en ai un nouveau : ma clé usb n’est plus montée automatiquement.
Un “dmesg” sur le kernel “standard”:
[quote]pci_hotplug: PCI Hot Plug PCI Core version: 0.5
usbcore: registered new driver usbfs
usbcore: registered new driver hub
usbcore: registered new driver usb-storage
USB Universal Host Controller Interface driver v3.0
uhci_hcd 0000:00:1f.2: UHCI Host Controller
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1f.2: irq 9, io base 0x0000ff00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-2: new full speed USB device using uhci_hcd and address 2
usb 1-2: configuration #1 chosen from 1 choice
SCSI subsystem initialized
Initializing USB Mass Storage driver…
scsi0 : SCSI emulation for USB Mass Storage devices
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
SCSI device sda: 4013709 512-byte hdwr sectors (2055 MB)
sda: Write Protect is off
sda: Mode Sense: 03 00 00 00
sda: assuming drive cache: write through
sda: sda1
sd 0:0:0:0: Attached scsi removable disk sda[/quote]
et sur le kernel maison (2.6.25)
[quote]usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbcore: registered new interface driver usb-storage
scsi 0:0:0:0: Direct-Access SanDisk U3 Cruzer Micro 4.05 PQ: 0 ANSI: 2
usb-storage: device scan complete
Driver ‘sd’ needs updating - please use bus_type methods
sd 0:0:0:0: [sda] 4013709 512-byte hardware sectors (2055 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
Il semblerait qu’il manque “hotplug” mais je ne le trouve pas dans mon “menuconfig” : rien dans la section “general setup” où il se trouvait “avant” ?
Que faire ? Où chercher ?
Merci de votre aide
