Bonjour à toutes et à tous
C’est la première fois que je compile un noyau Linux et j’obtiens une erreur dès le début de la compilation à propos d’un module Xen. Pourriez vous m’indiquer de quel type d’erreur s’agit t-il car je n’y connais absolument rien du tout. Je poste la trace de la compile jusqu’à l’erreur.
[code]compil:/home/compil/src/linux# make-kpkg kernel-image --rootcmd fakeroot --initr d --append-to-version=date +%y%m%d --revision=2.6.26
exec debian/rules DEBIAN_REVISION=2.6.26 APPEND_TO_VERSION=091118 INITRD=YES ROOT_CMD=fakeroot kernel-image
====== making target conf.vars [new prereqs: ]======
====== making target debian/stamp/build/kernel [new prereqs: conf.vars]======
This is kernel package version 11.015.
if [ -f include/linux/version.h ]; then uts_ver=$(grep ‘define UTS_RELEASE’ incl ude/linux/version.h | perl -nle ‘m/^\s*#define\s+UTS_RELEASE\s+("?)(\S+)\1/g & & print $2;’); if [ “X$uts_ver” != “X” ]; then echo “The UTS Release version in include/linux/version.h”; echo " “$uts_ver” "; echo "does not match current version " ; echo " “2.6.26091118” " ; echo “Reconfiguring.” ; touch Makefile; fi; fi
test ! -f scripts/package/builddeb.kpkg-dist || mv -f scripts/package/builddeb.k pkg-dist scripts/package/builddeb
test ! -f scripts/package/Makefile.kpkg-dist || mv -f scripts/package/Makefile.k pkg-dist scripts/package/Makefile
/usr/bin/make EXTRAVERSION=091118 ARCH=i386
bzImage
make[1]: Entering directory /home/compil/src/linux-source-2.6.26' scripts/kconfig/conf -s arch/x86/Kconfig make[1]: Leaving directory/home/compil/src/linux-source-2.6.26’
make[1]: Entering directory /home/compil/src/linux-source-2.6.26' CHK include/linux/version.h UPD include/linux/version.h CHK include/linux/utsrelease.h UPD include/linux/utsrelease.h SYMLINK include/asm -> include/asm-x86 CC kernel/bounds.s GEN include/linux/bounds.h CC arch/x86/kernel/asm-offsets.s GEN include/asm-x86/asm-offsets.h CALL scripts/checksyscalls.sh HOSTCC scripts/genksyms/genksyms.o SHIPPED scripts/genksyms/lex.c SHIPPED scripts/genksyms/parse.h SHIPPED scripts/genksyms/keywords.c HOSTCC scripts/genksyms/lex.o scripts/genksyms/lex.c:1487: warning: âinputâ defined but not used SHIPPED scripts/genksyms/parse.c HOSTCC scripts/genksyms/parse.o HOSTLD scripts/genksyms/genksyms CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o HOSTLD scripts/mod/modpost HOSTCC scripts/kallsyms HOSTCC scripts/conmakehash HOSTCC scripts/bin2c CC init/main.o CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o CC init/do_mounts.o CC init/do_mounts_rd.o CC init/do_mounts_initrd.o LD init/mounts.o CC init/initramfs.o CC init/calibrate.o LD init/built-in.o HOSTCC usr/gen_init_cpio GEN usr/initramfs_data.cpio.gz AS usr/initramfs_data.o LD usr/built-in.o CC arch/x86/kvm/svm.o CC arch/x86/kvm/vmx.o CC arch/x86/kvm/../../../virt/kvm/kvm_main.o CC arch/x86/kvm/../../../virt/kvm/ioapic.o CC arch/x86/kvm/x86.o CC arch/x86/kvm/mmu.o CC arch/x86/kvm/x86_emulate.o CC arch/x86/kvm/i8259.o CC arch/x86/kvm/irq.o CC arch/x86/kvm/lapic.o CC arch/x86/kvm/i8254.o LD arch/x86/kvm/kvm.o LD arch/x86/kvm/kvm-intel.o LD arch/x86/kvm/kvm-amd.o LD arch/x86/kvm/built-in.o CC arch/x86/xen/enlighten.o CC arch/x86/xen/setup.o arch/x86/xen/setup.c: In function âxen_enable_sysenterâ: arch/x86/xen/setup.c:75: warning: unused variable âcpuâ CC arch/x86/xen/multicalls.o CC arch/x86/xen/mmu.o .{standard input}: Assembler messages: {standard input}:272805: Warning: end of file not at end of a line; newline inserted gcc: Internal error: Killed (program cc1) Please submit a full bug report. See <file:///usr/share/doc/gcc-4.3/README.Bugs> for instructions. make[2]: *** [arch/x86/xen/mmu.o] Error 1 make[1]: *** [arch/x86/xen] Error 2 make[1]: Leaving directory/home/compil/src/linux-source-2.6.26’
make: *** [debian/stamp/build/kernel] Error 2
compil:/home/compil/src/linux#[/code]
J’ai essayé cet aprem’…
