suite à la compilation de mon nouveau kernel lors de ma commande : make modules
un message me dit "The present kernel configuration has modules disabled.
savez-vous comment je pourrais faire activer les modules ?
merci à vous.
merci à vous.
Si ca n’est pas déjà résolu, verifie dans le menu de configuration du menu, la deuxieme option du menu principal ( Enable loadable module support ) :
.config - Linux Kernel v2.6.26 Configuration
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
lqqqqqqqqqqqqqqqqqqqqqq Linux Kernel Configuration qqqqqqqqqqqqqqqqqqqqqqqk
x Arrow keys navigate the menu. <Enter> selects submenus --->. x
x Highlighted letters are hotkeys. Pressing <Y> includes, <N> excludes, x
x <M> modularizes features. Press <Esc><Esc> to exit, <?> for Help, </> x
x for Search. Legend: [*] built-in [ ] excluded <M> module < > x
x lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk x
x x General setup ---> x x
x x [*] Enable loadable module support ---> x x
x x -*- Enable the block layer ---> x x
x x Processor type and features ---> x x
x x Power management options ---> x x
x x Bus options (PCI etc.) ---> x x
x x Executable file formats / Emulations ---> x x
x x Networking ---> x x
x x Device Drivers ---> x x
x x Firmware Drivers ---> x x
x x File systems ---> x x
x x Kernel hacking ---> x x
x x Security options ---> x x
x x -*- Cryptographic API ---> x x
x x [*] Virtualization ---> x x
x x Library routines ---> x x
x x --- x x
x x Load an Alternate Configuration File x x
x x Save an Alternate Configuration File x x
x mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj x
tqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqu
x <Select> < Exit > < Help > x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
