voici la liste des fichiers dans l’archive:
extensions mozconfigs README.updates win_installer
LICENSE.txt NOTES README.windows xulrunner_locales
mac_installer README.linux strings_extract.php
MacUploadr.app README.locales strings_import.php
Makefile README.osx strings_verify.php
le readme linux:
[code]Flickr Uploadr
Copyright © 2007-2008 Yahoo! Inc. All rights reserved. This library is
free software; you can redistribute it and/or modify it under the terms of
the GNU General Public License (GPL), version 2 only. This library is
distributed WITHOUT ANY WARRANTY, whether express or implied. See the GNU
GPL for more details (http://www.gnu.org/licenses/gpl.html)
This guide uses UPLOADR to indicate the root of the Flickr Uploadr
source tree on your filesystem. It probably shouldn’t contain spaces.
You can obtain the Flickr Uploadr source code from either a tarball or
from Subversion.
Download tarball:
http://flickr.com/tools/uploadr/
Checkout from Subversion:
$ svn co http://code.flickr.com/svn/trunk/uploadr UPLOADR
XULRunner
XULRunner trunk builds:
ftp://ftp.mozilla.org/pub/mozilla.org/xulrunner/nightly/latest-trunk/
Note: You want the version without ‘sdk’ in the name.
TODO
Gecko SDK
To build the XPCOM components you will need the Gecko SDK:
http://developer.mozilla.org/en/docs/Gecko_SDK#Downloading
Place the SDK here:
UPLOADR/MacUploadr.app/Contents/Resources/gecko-sdk.lin
These SDKs are from the Gecko 1.8 series and so are only safe to use
if the XPCOM components use only frozen interfaces. Fortunately,
Uploadr currently falls into this category.
API Keys
You’ll need your own API key and secret from Flickr to build Uploadr.
These can be obtained at http://flickr.com/services/api/. The key
and secret must be placed in flKey.cpp in the spaces provided. Copy
flKey.cpp.template to flKey.cpp and insert your keys:
UPLOADR/MacUploadr.app/Contents/Resources/components/flKey.cpp.template
The API key is stored as a string. The secret is stored as individual
characters so it is not easily readable from the binary.
There are blocks to keep both a Windows and Mac key/secret in the same
source file (you certainly don’t have to, though). This is mainly
important for the official builds.
GraphicsMagick
TODO
Exiv2
Download Exiv2 source from:
http://exiv2.org/download.html
TODO
FFmpeg
TODO
Building XPCOM components
If you make any changes to the IDL files defining the XPCOM interfaces,
you must increment the BuildID defined in:
UPLOADR/MacUploadr.app/Contents/Resources/application.ini
TODO
Running Flickr Uploadr
TODO
Packaging
TODO[/code]
