J’essaie d’installer un logiciel sur 64studio…mais il faut le compiler (ça devient compliqué pour moi…)
Alors, j’ai lu qu’il fallait faire un “Make” puis “make install” après avoir vérifier que les paquets “libclthreads” et “libclxclient” étaient installés. Seulement, voila ce qui se passe…
Merci pour votre aide
g++ -O3 -Wall -MMD -MP -DPROGRAM=\"jkmeter\" -DVERSION=\"0.4.0\" -DSHARED=\"/usr/local/share\" -ffast-math -I/usr/include/freetype2 -c -o jkmeter.o jkmeter.ccjkmeter.cc:22:23: warning: clthreads.h: Aucun fichier ou répertoire de ce type
In file included from jkmeter.cc:25:
styles.h:24:23: warning: clxclient.h: Aucun fichier ou répertoire de ce type
styles.h:42: error: expected initializer before ‘*’ token
styles.h:43: error: expected initializer before ‘*’ token
styles.h:44: error: ‘X_button_style’ does not name a type
styles.h:46: warning: ‘styles_init’ initialized and declared ‘extern’
styles.h:46: error: variable or field ‘styles_init’ declared void
styles.h:46: error: ‘X_display’ was not declared in this scope
styles.h:46: error: ‘disp’ was not declared in this scope
styles.h:46: error: ‘X_resman’ was not declared in this scope
styles.h:46: error: ‘xrm’ was not declared in this scope
styles.h:46: error: initializer expression list treated as compound expression
styles.h:47: warning: ‘styles_fini’ initialized and declared ‘extern’
styles.h:47: error: variable or field ‘styles_fini’ declared void
styles.h:47: error: ‘X_display’ was not declared in this scope
styles.h:47: error: ‘disp’ was not declared in this scope
jclient.h:32: error: expected class-name before ‘{’ token
jclient.h:32: warning: ‘class Jclient’ has virtual functions but non-virtual destructor
kmeter.h:28: error: expected class-name before ‘{’ token
kmeter.h:35: error: expected `)' before ‘*’ token
kmeter.h:45: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:45: error: expected ‘;’ before ‘*’ token
kmeter.h:51: error: expected `;' before ‘static’
kmeter.h:51: error: ‘X_display’ has not been declared
kmeter.h:53: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:53: error: expected ‘;’ before ‘*’ token
kmeter.h:54: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:54: error: expected ‘;’ before ‘*’ token
kmeter.h:55: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:55: error: expected ‘;’ before ‘*’ token
kmeter.h:56: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:56: error: expected ‘;’ before ‘*’ token
kmeter.h:70: error: ‘Pixmap’ does not name a type
kmeter.h:71: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:71: error: expected ‘;’ before ‘*’ token
kmeter.h:72: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:72: error: expected ‘;’ before ‘*’ token
kmeter.h:75: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:75: error: expected ‘;’ before ‘*’ token
kmeter.h:76: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:76: error: expected ‘;’ before ‘*’ token
kmeter.h:77: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:77: error: expected ‘;’ before ‘*’ token
kmeter.h:78: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:78: error: expected ‘;’ before ‘*’ token
kmeter.h:79: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:79: error: expected ‘;’ before ‘*’ token
kmeter.h:80: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:80: error: expected ‘;’ before ‘*’ token
kmeter.h:81: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:81: error: expected ‘;’ before ‘*’ token
kmeter.h:82: error: ISO C++ forbids declaration of ‘XImage’ with no type
kmeter.h:82: error: expected ‘;’ before ‘*’ token
cmeter.h:28: error: expected class-name before ‘{’ token
cmeter.h:34: error: expected `)' before ‘*’ token
cmeter.h:44: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:44: error: expected ‘;’ before ‘*’ token
cmeter.h:49: error: expected `;' before ‘static’
cmeter.h:49: error: ‘X_display’ has not been declared
cmeter.h:51: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:51: error: expected ‘;’ before ‘*’ token
cmeter.h:52: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:52: error: expected ‘;’ before ‘*’ token
cmeter.h:60: error: ‘Pixmap’ does not name a type
cmeter.h:61: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:61: error: expected ‘;’ before ‘*’ token
cmeter.h:62: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:62: error: expected ‘;’ before ‘*’ token
cmeter.h:64: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:64: error: expected ‘;’ before ‘*’ token
cmeter.h:65: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:65: error: expected ‘;’ before ‘*’ token
cmeter.h:66: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:66: error: expected ‘;’ before ‘*’ token
cmeter.h:67: error: ISO C++ forbids declaration of ‘XImage’ with no type
cmeter.h:67: error: expected ‘;’ before ‘*’ token
mainwin.h:32: error: expected class-name before ‘,’ token
mainwin.h:33: error: expected class-name before ‘{’ token
mainwin.h:36: error: expected `)' before ‘*’ token
mainwin.h:50: error: ‘XEvent’ has not been declared
mainwin.h:51: error: ‘X_window’ has not been declared
mainwin.h:51: error: ‘XEvent’ has not been declared
mainwin.h:52: error: ‘XExposeEvent’ has not been declared
mainwin.h:53: error: ‘XClientMessageEvent’ has not been declared
mainwin.h:54: error: ‘X_window’ has not been declared
mainwin.h:54: error: ‘X_textln_style’ has not been declared
mainwin.h:61: error: ISO C++ forbids declaration of ‘X_resman’ with no type
mainwin.h:61: error: expected ‘;’ before ‘*’ token
mainwin.h:62: error: ‘Atom’ does not name a type
mainwin.h:74: error: ISO C++ forbids declaration of ‘X_tbutton’ with no type
mainwin.h:74: error: expected ‘;’ before ‘*’ token
mainwin.h:33: warning: ‘class Mainwin’ has virtual functions but non-virtual destructor
jkmeter.cc:32: error: ‘XrmOptionDescRec’ does not name a type
jkmeter.cc: In function ‘int main(int, char**)’:
jkmeter.cc:77: error: ‘X_resman’ was not declared in this scope
jkmeter.cc:77: error: expected `;' before ‘xresman’
jkmeter.cc:78: error: ‘X_display’ was not declared in this scope
jkmeter.cc:78: error: ‘display’ was not declared in this scope
jkmeter.cc:79: error: ‘X_handler’ was not declared in this scope
jkmeter.cc:79: error: ‘handler’ was not declared in this scope
jkmeter.cc:80: error: ‘X_rootwin’ was not declared in this scope
jkmeter.cc:80: error: ‘rootwin’ was not declared in this scope
jkmeter.cc:85: error: ‘xresman’ was not declared in this scope
jkmeter.cc:85: error: ‘options’ was not declared in this scope
jkmeter.cc:88: error: expected type-specifier before ‘X_display’
jkmeter.cc:88: error: expected `;' before ‘X_display’
jkmeter.cc:92: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
jkmeter.cc:100: error: ‘styles_init’ cannot be used as a function
jkmeter.cc:101: error: expected type-specifier before ‘X_rootwin’
jkmeter.cc:101: error: expected `;' before ‘X_rootwin’
jkmeter.cc:104: error: expected type-specifier before ‘X_handler’
jkmeter.cc:104: error: expected `;' before ‘X_handler’
jkmeter.cc:106: error: ‘class Mainwin’ has no member named ‘x_map’
jkmeter.cc:107: error: ‘XFlush’ was not declared in this scope
jkmeter.cc:124: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
jkmeter.cc:125: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
jkmeter.cc:126: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
make: *** [jkmeter.o] Erreur 1
