Et le xorg.0.log
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10)
Current Operating System: Linux asux-e 2.6.26-1-686 #1 SMP Sat Jan 10 18:29:31 UTC 2009 i686
Build Date: 09 January 2009 02:57:16AM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Mar 12 11:23:11 2009
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "aticonfig Layout"
(**) |-->Screen "aticonfig-Screen[0]-0" (0)
(**) | |-->Monitor "aticonfig-Monitor[0]-0"
(**) | |-->Device "aticonfig-Device[0]-0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,29e0 card 1043,8295 rev 01 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,29e1 card 0000,0000 rev 01 class 06,04,00 hdr 01
(II) PCI: 05:01:2: chip 1102,4001 card 1102,0010 rev 04 class 0c,00,10 hdr 80
(II) PCI: 05:03:0: chip 11c1,5811 card 1043,8294 rev 70 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfe800000 - 0xfe8fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 4: bridge is at (0:28:0), (0,4,4), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:28:1), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xfea00000 - 0xfeafffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MX[B]
(II) Bus 2: bridge is at (0:28:5), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfe900000 - 0xfe9fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 5: bridge is at (0:30:0), (0,5,5), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 5 non-prefetchable memory range:
[0] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc unknown chipset (0x9598) rev 0, Mem @ 0xd0000000/28, 0xfe8e0000/16, I/O @ 0xb000/8, BIOS @ 0xfe8c0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfebfe000 - 0xfebfefff (0x1000) MX[B]
[30] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
[1] -1 0 0xfebf8000 - 0xfebfbfff (0x4000) MX[B]
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[36] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
(II) "extmod" will be loaded by default.
(II) "dbe" will be loaded by default.
(II) "glx" will be loaded by default.
(II) "freetype" will be loaded by default.
(II) "record" will be loaded by default.
(II) "dri" will be loaded by default.
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.4.2, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
compiled for 7.1.0, module version = 1.0.0
(II) Loading extension XFree86-DRI
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.56.4
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.3.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.3.0
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.56.4
(II) ATI Proprietary Linux Driver Release Identifier: 8.561
(II) ATI Proprietary Linux Driver Build Date: Dec 1 2008 14:55:22
(--) Chipset Supported AMD Graphics Processor (0x9598) found
(II) AMD Video driver is running on a device belonging to a group targeted for this release
(II) AMD Video driver is signed
(II) resource ranges after xf86ClaimFixedResources() call:
[41] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "EnableDepthMoves" "yes"
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "ForceMonitors" "crt1,notv"
(**) fglrx(0): Option "DPMS" "true"
(**) fglrx(0): Option "EnableRandR12"
(II) fglrx(0): Loading PCS database from /etc/ati/amdpcsdb
(II) fglrx(0): 10BitPixelFormat disabled by default
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(**) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(--) fglrx(0): Chipset: "ATI Radeon HD 3600 Series" (Chipset = 0x9598)
(--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x01da)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
(--) fglrx(0): MMIO registers at 0xfe8e0000
(--) fglrx(0): I/O port at 0x0000b000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(**) fglrx(0): Option "mtrr" "on"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.1.0
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 10.78
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: RV635
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: Searching for BusID PCI:1:0:0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports PCI:1:0:0
(II) fglrx(0): Using adapter: 1:0.0.
(II) fglrx(0): [FB] MC range(MCFBBase = 0xc0000000, MCFBSize = 0x20000000)
(--) fglrx(0): Video RAM: 524288 kByte, Type: DDR2
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(**) fglrx(0): ForceMonitors Settings: 40001
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) fglrx(0): ***Display: ConnectedDisplayTypes=0x00000001, disabled=0x00000004
(II) fglrx(0): Connected Display1: CRT on primary DAC [crt1]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: XXX Model: 3 Serial#: 0
(II) fglrx(0): Year: 1990 Week: 0
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) fglrx(0): Sync:
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 40 vert.: 30
(II) fglrx(0): Gamma: 1.00
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; Non RGB Multicolor Display
(II) fglrx(0): First detailed timing not preferred mode in violation of standard!(II) fglrx(0): redX: 0.000 redY: 0.000 greenX: 0.000 greenY: 0.000
(II) fglrx(0): blueX: 0.000 blueY: 0.000 whiteX: 0.000 whiteY: 0.000
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 640 vsize 480 refresh: 60 vid: 16433
(II) fglrx(0): #1: hsize: 800 vsize 600 refresh: 60 vid: 16453
(II) fglrx(0): #2: hsize: 1024 vsize 768 refresh: 60 vid: 16481
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff006318030000000000
(II) fglrx(0): 0000010300281e00f000000000000000
(II) fglrx(0): 00000021080031404540614000000000
(II) fglrx(0): 00000000000000000000000000000000
(II) fglrx(0): 0000000000000000000000000000008e
(II) fglrx(0): End of Display1 EDID data --------------------
(WW) fglrx(0): Only one display is connnected,so single mode is enabled
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000001
(==) fglrx(0): QBS disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 60 modes found for primary display.
(--) fglrx(0): Virtual size is 1600x1200 (pitch 0)
(**) fglrx(0): *Mode "1600x1200": 229.5 MHz (scaled from 0.0 MHz), 106.2 kHz, 85.0 Hz
(II) fglrx(0): Modeline "1600x1200"x85.0 229.50 1600 1664 1856 2160 1200 1201 1204 1250 (106.2 kHz)
(**) fglrx(0): Default mode "1600x1200": 202.5 MHz (scaled from 0.0 MHz), 93.8 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1600x1200"x75.0 202.50 1600 1664 1856 2160 1200 1201 1204 1250 (93.8 kHz)
(**) fglrx(0): Default mode "1600x1200": 162.0 MHz (scaled from 0.0 MHz), 75.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 (75.0 kHz)
(**) fglrx(0): *Mode "1280x1024": 157.5 MHz (scaled from 0.0 MHz), 91.1 kHz, 85.0 Hz
(II) fglrx(0): Modeline "320x200"x60.0 12.59 320 336 384 400 200 457 459 524 doublescan (31.5 kHz)
(**) fglrx(0): Display dimensions: (400, 300) mm
(**) fglrx(0): DPI set to (101, 101)
(--) fglrx(0): Virtual size is 1600x1200 (pitch 1600)
(II) fglrx(0): Modeline "320x200"x75.0 13.10 320 352 368 416 200 406 407 417 doublescan (31.5 kHz)
(**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.2.0
(==) fglrx(0): NoDRI = NO
(II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x8000001d
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): Ring buffer size: 16 MB
(II) fglrx(0): [pcie] 262144 kB allocated
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(II) fglrx(0): Direct rendering enabled
(II) fglrx(0): AC Adapter is used
(II) fglrx(0): Interrupt handler installed at IRQ 16.
(II) fglrx(0): Exposed events to the /proc interface
(II) fglrx(0): Finished Initialize PPLIB!
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xfe8e0000 - 0xfe8effff (0x10000) MX[B]
[1] 0 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
[2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[42] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
[43] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[44] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(WW) fglrx(0): could not detect X server version (query_status=-1)
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
(II) fglrx(0): DRIScreenInit for fglrx driver
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0x2000
(II) fglrx(0): [drm] mapped SAREA 0x2000 to 0xb7f3d000
(II) fglrx(0): [drm] framebuffer handle = 0x3000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 8.56.4
(II) fglrx(0): Date: Dec 1 2008
(II) fglrx(0): Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.26-1-686
(II) fglrx(0): Build-Kernel MODVERSIONS: no
(II) fglrx(0): Build-Kernel __SMP__: no
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [drm] register handle = 0x00004000
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x01004000
(II) fglrx(0): FBMM initialized for area (0,0)-(1600,2624)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1600,1200) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1600 x 1424
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(**) fglrx(0): Textured Video is enabled.
(II) LoadModule: "glesx"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 90
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Driver provided ScreenToScreenBitBlt replacement
Driver provided FillSolidRects replacement
(II) fglrx(0): GLESX is enabled
(II) LoadModule: "amdxmm"
(II) Loading /usr/lib/xorg/modules//amdxmm.so
(II) Module amdxmm: vendor="X.Org Foundation"
(II) fglrx(0): UVD2 feature is available
(II) fglrx(0): X context handle = 0x1
(II) fglrx(0): [DRI] installation complete
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using hardware cursor
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 10, (OK)
drmOpenByBusid: drmOpenMinor returns 10
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x71
(WW) AIGLX: 3D driver claims to not support visual 0x72
(II) AIGLX: Loaded and initialized /usr/lib/dri/fglrx_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) fglrx(0): Enable the clock gating!
(II) fglrx(0): Restoring recent mode: 1600x1200@85Hz
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "be"
(**) Keyboard0: XkbLayout: "be"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/input/mice"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Device" "/dev/input/mice"
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" " 4 5 6 7"
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(**) Mouse0: Sensitivity: 1
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(--) Mouse0: PnP-detected protocol: "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!
SetGrabKeysState - disabled
SetGrabKeysState - enabled
(II) 3rd Button detected: disabling emulate3Button
Warning: LookupDrawable()/SecurityLookupDrawable() are deprecated. Please convert your driver/module to use dixLookupDrawable().
Merci à toi,
Debcool
