Bonsoir, j’ ai installé Compiz sur ma Lenny avec kde. J’ ai suivi ce tuto : pendrivelinux.com/how-to-ins … in-debian/
Ce qui m’ étonne c’ est cette section :
[code]# Add the following option under Section “ServerLayout”
Option “AIGLX” “true”[/code]
Car "ServerLayout je ne l’ ai pas dans mon xorg.conf :
[code] # xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Que faire ? Rajouter cette section carrément ?
Bonne soirée !
