je cherche à installer compiz-fusion sur ma belle distrib super légère ( oui, du sado-masochisme… ) qui est composée de Debian Testing et de openbox, tout léger, sans rien de base, sur un pc avec une carte graphique Intel GMA950 ( GMA 945 réelle, le 950 n’existe pas… )
Problème :
bah, j’installe mon compiz, je tape compiz en console et sa bug, X qui se coupe…
Bon, on fait
Et on à :
Checking for Xgl: not present.
Detected PCI ID for VGA: 00:02.0 0300: 8086:27a2 (rev 03) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1280x800) to maximum 3D texture size (2048): Passed.
Checking for nVidia: not present.
Checking for FBConfig: present.
Bah oui, mais ce n’est ni une carte NVIDIA, ni une ATI…
Mon Xorg.cong :
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
Option “XkbOptions” "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Voila, donc si quelqu’un sait comment le faire marcher…
Il fonctionne sur Ubuntu/Kubuntu/Xubuntu, sur la même machine, mais bon, Xfce/OpenBox, s’pas la même chos quoi…
