toujours en decouverte de debian, me voici confronté a un probleme avec compiz
lors de compiz --replace
j’ai
[code]Backend : ini
Integration : true
Profile : default
Adding plugins
Initializing core options…done
Initializing move options…done
Initializing resize options…done
Initializing place options…done
Initializing decoration options…done
WARNING: Application calling GLX 1.3 function “glXCreatePixmap” when GLX 1.3 is not supported! This is an application bug!
Initializing gnomecompat options…done
Initializing neg options…done
(compiz-decorator:8441): GConf-CRITICAL **: gconf_client_set_string: assertion `val != NULL’ failed
Initializing fade options…done
compiz (cube) - Warn: Failed to load slide: /usr/share/images/desktop-base/debian-blueish-wallpaper-640x480.png
Initializing cube options…done
Initializing rotate options…done
WARNING: Application calling GLX 1.3 function “glXDestroyPixmap” when GLX 1.3 is not supported! This is an application bug!
qqn a t’il deja eu le probleme, je ne trouve rien sur google de fonctionnel…
merci
Cédric
