[code]# cat /etc/X11/xorg.conf
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller"
Driver "i810"
BusID "PCI:0:2:0"
Option “XAANoOffscreenPixmaps” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Section "DRI"
Mode 0666
EndSection
Dedicated “Extensions” section
Section "Extensions"
Option “Composite” "enable"
EndSection[/code]
je suis pas sûr d’avoir rajouté quoi que ce soit dans xorg.conf… sinon “Option “XAANoOffscreenPixmaps” “true””… autre chose à ajouter ?
