Je suis sous une FC4 avec Apache.
Je voudrais configurer un serveur webdav
Donc j’ai commencer par modifier mon httpd.conf:
[code]
Section 1: Global Environment
ServerTokens OS
ServerRoot “/etc/httpd”
#ScoreBoardFile run/httpd.scoreboard
PidFile "/var/run/httpd.pid"
TimeOut 300
KeepAlive false
MaxKeepAliveRequests 100
KeepAliveTimeout 15
Listen 192.168.2.2:80
Dynamic Shared Object (DSO) Support
To be able to use the functionality of a module which was built as a DSO you
have to place corresponding `LoadModule’ lines at this location so the
directives contained in it are actually available before they are used.
Statically compiled modules (those listed by `httpd -l’) do not need
to be loaded here.
Example:
LoadModule foo_module modules/mod_foo.so
LoadModule access_module modules/mod_access.so
LoadModule auth_module modules/mod_auth.so
LoadModule auth_anon_module modules/mod_auth_anon.so
LoadModule auth_dbm_module modules/mod_auth_dbm.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule ldap_module modules/mod_ldap.so
LoadModule auth_ldap_module modules/mod_auth_ldap.so
LoadModule include_module modules/mod_include.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule env_module modules/mod_env.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule expires_module modules/mod_expires.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule headers_module modules/mod_headers.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule mime_module modules/mod_mime.so
LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule asis_module modules/mod_asis.so
LoadModule info_module modules/mod_info.so
LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
LoadModule imap_module modules/mod_imap.so
LoadModule actions_module modules/mod_actions.so
LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule cache_module modules/mod_cache.so
LoadModule suexec_module modules/mod_suexec.so
LoadModule disk_cache_module modules/mod_disk_cache.so
LoadModule file_cache_module modules/mod_file_cache.so
LoadModule mem_cache_module modules/mod_mem_cache.so
LoadModule cgi_module modules/mod_cgi.so
Load config files from the config directory “/etc/httpd/conf.d”.
Include conf.d/*.conf
#ExtendedStatus On
Section 2: ‘Main’ server configuration
User apache
Group apache
ServerAdmin rjc@9online.fr
ServerName RJCSERVEUR
UseCanonicalName on
DocumentRoot “/var/www/html”
<LocationMatch “^/$”>
Options -Indexes
ErrorDocument 403 /error/noindex.html
UserDir "disable"
#UserDir public_html
DirectoryIndex
AccessFileName .htaccess
<Files ~ “^.ht”>
Order allow,deny
Deny from all
TypesConfig "/etc/mime.types"
DefaultType text/plain
HostNameLookups Off
#EnableMMAP off
#EnableSendfile off
ErrorLog “/var/log/httpd/error_log”
LogLevel warn
LogFormat “%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”” combined
LogFormat “%h %l %u %t “%r” %>s %b” common
LogFormat “%{Referer}i -> %U” referer
LogFormat “%{User-agent}i” agent
CustomLog logs/access_log common
CustomLog logs/access_log combined
#CustomLog logs/referer_log referer
#CustomLog logs/agent_log agent
#CustomLog logs/access_log combined
ServerSignature on
Alias /icons/ "/var/www/icons/"
Alias /manual “/var/www/manual”
ScriptAlias /cgi-bin/ “/var/www/cgi-bin/”
#Scriptsock logs/cgisock
IndexOptions FancyIndexing VersionSort NameWidth=*
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif …
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon is which icon to show for files which do not have an icon
explicitly set.
DefaultIcon /icons/unknown.gif
AddDescription allows you to place a short description after a file in
server-generated indexes. These are only displayed for FancyIndexed
directories.
Format: AddDescription “description” filename
#AddDescription “GZIP compressed document” .gz
#AddDescription “tar archive” .tar
#AddDescription “GZIP compressed tar archive” .tgz
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* ~ # HEADER README RCS CVS *,v *,t
AddEncoding x-compress Z
AddEncoding x-gzip gz tgz
DefaultLanguage fr
Danish (da) - Dutch (nl) - English (en) - Estonian (et)
French (fr) - German (de) - Greek-Modern (el)
Italian (it) - Norwegian (no) - Norwegian Nynorsk (nn) - Korean (kr)
Portugese (pt) - Luxembourgeois* (ltz)
Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cz)
Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
Russian (ru) - Croatian (hr)
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .et
AddLanguage fr .fr
AddLanguage de .de
AddLanguage he .he
AddLanguage el .el
AddLanguage it .it
AddLanguage ja .ja
AddLanguage pl .po
AddLanguage kr .kr
AddLanguage pt .pt
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pt-br .pt-br
AddLanguage ltz .ltz
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .se
AddLanguage cz .cz
AddLanguage ru .ru
AddLanguage tw .tw
AddLanguage zh-tw .tw
AddLanguage hr .hr
LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ltz ca es sv tw
ForceLanguagePriority Prefer Fallback
AddDefaultCharset ISO-8859-1
AddCharset ISO-8859-1 .iso8859-1 .latin1
AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
AddCharset ISO-8859-3 .iso8859-3 .latin3
AddCharset ISO-8859-4 .iso8859-4 .latin4
AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
AddCharset ISO-2022-JP .iso2022-jp .jis
AddCharset ISO-2022-KR .iso2022-kr .kis
AddCharset ISO-2022-CN .iso2022-cn .cis
AddCharset Big5 .Big5 .big5
For russian, more than one charset is used (depends on client, mostly):
AddCharset WINDOWS-1251 .cp-1251 .win-1251
AddCharset CP866 .cp866
AddCharset KOI8-r .koi8-r .koi8-ru
AddCharset KOI8-ru .koi8-uk .ua
AddCharset ISO-10646-UCS-2 .ucs2
AddCharset ISO-10646-UCS-4 .ucs4
AddCharset UTF-8 .utf8
AddCharset GB2312 .gb2312 .gb
AddCharset utf-7 .utf7
AddCharset utf-8 .utf8
AddCharset big5 .big5 .b5
AddCharset EUC-TW .euc-tw
AddCharset EUC-JP .euc-jp
AddCharset EUC-KR .euc-kr
AddCharset shift_jis .sjis
AddType application/x-tar .tgz
#AddHandler cgi-script .cgi
#AddHandler send-as-is asis
AddHandler imap-file map
AddHandler type-map var
AddOutputFilter INCLUDES .shtml
Some examples:
#ErrorDocument 500 “The server made a boo boo.”
#ErrorDocument 404 /missing.html
#ErrorDocument 404 “/cgi-bin/missing_handler.pl”
#ErrorDocument 402 http://www.example.com/subscription_info.html
Alias /error/ “/var/www/error/”
BrowserMatch “Mozilla/2” nokeepalive
BrowserMatch “MSIE 4.0b2;” nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch “RealPlayer 4.0” force-response-1.0
BrowserMatch “Java/1.0” force-response-1.0
BrowserMatch “JDK/1.0” force-response-1.0
BrowserMatch “Microsoft Data Access Internet Publishing Provider” redirect-carefully
BrowserMatch “^WebDrive” redirect-carefully
BrowserMatch “^WebDAVFS/1.[012]” redirect-carefully
BrowserMatch “^gnome-vfs” redirect-carefully
Allow server status reports, with the URL of http://servername/server-status
Change the “.your-domain.com” to match your domain to enable.
#<Location /server-status>
SetHandler server-status
Order deny,allow
Deny from all
Allow from .your-domain.com
Allow remote server configuration reports, with the URL of
http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
Proxy Server directives. Uncomment the following lines to
enable the proxy server:
#ProxyRequests On
#<Proxy *>
Order deny,allow
Deny from all
Enable/disable the handling of HTTP/1.1 “Via:” headers.
(“Full” adds the server version; “Block” removes all outgoing Via: headers)
Set to one of: Off | On | Full | Block
#ProxyVia On
To enable the cache as well, edit and uncomment the following lines:
(no cacheing without CacheRoot)
#CacheRoot “/etc/httpd/proxy”
#CacheSize 5
#CacheGcInterval 4
#CacheMaxExpire 24
#CacheLastModifiedFactor 0.1
#CacheDefaultExpire 1
#NoCache a-domain.com another-domain.edu joes.garage-sale.com
End of proxy directives.
Section 3: Virtual Hosts
NameVirtualHost 192.168.2.2
LockFile "/var/lock/httpd.lock"
CoreDumpDirectory “/etc/httpd”
Virtual host Divers
<VirtualHost 192.168.2.2>
DocumentRoot /var/www/html/divers.ath.cx
ServerName divers.ath.cx
ServerSignature email
DirectoryIndex index.html index.htm index.shtml
Virtual host Groupe
DocumentRoot /var/www/html/grp.ath.cx
ServerName grp.ath.cx
Virtual host Tir
DocumentRoot /var/www/html/tir.ath.cx
ServerName tir.ath.cx
Virtual host Loisirscreatifs
DocumentRoot /var/www/html/loisirscreatifs.ath.cx
ServerName loisirscreatifs.ath.cx
<Directory “/”>
Options FollowSymLinks
AllowOverride None
<Directory “/var/www/html/grp.ath.cx”>
Options Indexes Includes FollowSymLinks
AuthName "Acces Prive Contactez l'administrateur"
AuthType basic
AuthUserFile /etc/httpd/mdp
require valid-user
AllowOverride all
Allow from all
Order allow,deny
<Directory “/var/www/icons”>
Options Indexes MultiViews
AllowOverride None
Allow from all
Order allow,deny
<Directory “/var/www/cgi-bin”>
Options ExecCGI
AllowOverride None
Allow from all
Order allow,deny
#Web DAV
DAVLockDB /ftp/dav/DAVLockDB
<Directory “/ftp/dav”>
DAV On
AuthName 'WebDAV’
AuthType Basic
AuthUserFile /etc/httpd/.htpasswd
AuthGroupFile /dev/null
require valid-user
Le pb c’est quand je veux me connecter à localhost/dav/ depuis la machine ou est installé le serveur, il me dit:
The connection was refused when attempting to contact localhost.
Je présise que les deux répertoires dav et DAVLockDB sont en 777.
