J’ai actuellement une configuration postfix et j’aimerais avoir votre avis dessus…
Concernant son efficacité contre le spam et j’ai cette erreur dans la queue : “Undelivered Mail Returned to Sender”
host client-tld.mail.eo.outlook.com[213.199.154.23]
said: 501 5.1.7 Invalid address (in reply to MAIL FROM command)
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
double_bounce_sender=root
bounce_notice_recipient=root
delay_notice_recipient=root
error_notice_recipient=root
notify_classes = bounce, delay, policy, resource
allow_percent_hack = no
show_user_unknown_table_name=no
#smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
smtpd_helo_required=yes
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
myhostname = server1.domain.tld
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = server1.domain.tld, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
html_directory = /usr/share/doc/postfix/html
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /var/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
inet_protocols = all
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf,
reject_unauth_destination
smtpd_tls_security_level = may
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
relay_domains = mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
smtpd_sender_restrictions =
check_sender_access regexp:/etc/postfix/tag_as_originating.re,
permit_mynetworks,
check_sender_access mysql:/etc/postfix/mysql-virtual_sender.cf,
check_sender_access regexp:/etc/postfix/tag_as_foreign.re
smtpd_client_restrictions =
permit_mynetworks,
reject_unknown_client_hostname
check_client_access mysql:/etc/postfix/mysql-virtual_client.cf
smtpd_client_message_rate_limit = 100
maildrop_destination_concurrency_limit = 1
maildrop_destination_recipient_limit = 1
virtual_transport = dovecot
header_checks = regexp:/etc/postfix/header_checks
mime_header_checks = regexp:/etc/postfix/mime_header_checks
nested_header_checks = regexp:/etc/postfix/nested_header_checks
body_checks = regexp:/etc/postfix/body_checks
owner_request_special = no
dovecot_destination_recipient_limit = 1
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
content_filter = amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings
message_size_limit = 0
smtpd_tls_CAfile = /usr/local/ispconfig/interface/ssl/startssl.chain.class1.server.crt
swap_bangpath = no
append_at_myorigin = no
#SPAM
disable_vrfy_command = yes
smtpd_helo_restrictions =
permit_mynetworks,
reject_non_fqdn_helo_hostname,
reject_invalid_helo_hostname
strict_rfc821_envelopes = yes
Un tout grand merci !
