J’ai mis en place un proxy (squid +dansguardian) + iptable sur mon serveur.
Je voulait rajouter bind9 pour faire du cache dns, celui-ci est installé mais impossible de le lancer.
FW-PROXY:~# /etc/init.d/bind9 restart
Stopping domain name service...: bind9rndc: connect failed: 127.0.0.1#953: connection refused
Starting domain name service...: bind9 failed!
FW-PROXY:~# tail -f /var/log/syslog
Jul 17 09:42:57 FW-PROXY named[2620]: using up to 4096 sockets
Jul 17 09:42:57 FW-PROXY named[2620]: loading configuration from '/etc/bind/named.conf'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:12: unknown option 'zone'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:20: unknown option 'zone'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:25: unknown option 'zone'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:30: unknown option 'zone'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:35: unknown option 'zone'
Jul 17 09:42:57 FW-PROXY named[2620]: /etc/bind/named.conf:42: '}' expected near end of file
Jul 17 09:42:57 FW-PROXY named[2620]: loading configuration: unexpected token
Jul 17 09:42:57 FW-PROXY named[2620]: exiting (due to fatal error)
named.conf:
FW-PROXY:~# cat /etc/bind/named.conf
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, *BEFORE* you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
include "/etc/bind/named.conf.options";
// prime the server with knowledge of the root servers
zone "." {
type hint;
file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
include "/etc/bind/named.conf.local";
aucune regle iptables:
FW-PROXY:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Quel est le problème? Faut-il paramétrer un fichier pour faire du cache dns?
guigui69
