Bonjour à tous et à toutes,
j’ai voulu installer Conky mais problème je ne sais pas comment le configurer à ma guise, voici mon .conkyrc :
[code]background yes
font Bitstream Vera Sans:size=8
xftfont Bitstream Vera Sans:size=8
use_xft yes
xftalpha 0.1
update_interval 1.0
total_run_times 0
own_window yes
own_window_type background
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders yes
minimum_size 300
maximum_width 370
default_color white
default_shade_color 000000
default_outline_color 000000
alignment top_right
gap_x 20
gap_y 70
no_buffers yes
cpu_avg_samples 2
override_utf8_locale yes
uppercase no # set to yes if you want all text to be in uppercase
use_spacer yes
TEXT
$alignc Hostname: $nodename
$alignc Kernel: $kernel
$alignc Uptime: $uptime
${offset 45}${font DejaVuSans:Condensed:Bold:size=14} ${tztime}${font Bitstream Vera Sans:size=7}
${color #B8FF00}CPU:${color white}
Core1:$alignr ${cpu cpu1}%@${freq_g cpu1}GHz ${cpubar cpu1 7,76} Temp: ${color orange}${execi 10 acpi -t | grep Thermal | head -n1 | cut -d"," -f2 | cut -d"." -f1}${color white}°C
${color #B8FF00}Highest CPU${color white} $alignr CPU% MEM%
${top name 1}$alignr${top cpu 1} ${top mem 1}
${top name 2}$alignr${top cpu 2} ${top mem 2}
${color #B8FF00}MEM:${color white}
RAM ${alignr}$mem / $memmax ($memperc%)
${membar 8}
SWAP ${alignr}$swap / $swapmax ($swapperc%)
${swapbar 8}
${color #B8FF00}Highest MEM${color white} $alignr CPU% MEM%
${top_mem name 1}$alignr${top_mem cpu 1} ${top_mem mem 1}
${top_mem name 2}$alignr${top_mem cpu 2} ${top_mem mem 2}
${color #B8FF00}HDD:${color white} ${alignr} HDD Temp: ${color orange}${hddtemp /dev/hda}${color white}
Racine: ${alignc} ${fs_bar 8,75} ${alignr} ${fs_free /} / ${fs_size /} (${fs_free_perc /}%)
Home: ${alignc} ${fs_bar 8,75 /home} ${alignr}${fs_free /home} / ${fs_size /home} (${fs_free_perc /home}%)
Web + Log: ${alignc} ${fs_bar 8,75 /var} ${alignr}${fs_free /var} / ${fs_size /var} (${fs_free_perc /var}%)
${color white}HDD Read-> ${alignc}${color green}${diskio_read}/s ${alignr}${color #FF0009}${diskio_write}/s ${color white}<-HDD Write
${color green}${diskiograph_read 20,150} ${alignr}${color #FF0009}${diskiograph_write 20,150}${color white}
${color #B8FF00}LAN:${color white} ${alignr}IP: ${addr eth1}
${color green}LAN Download: $alignr${color #FF0009}LAN Upload:
${color green}${downspeed eth1} k/s ${alignr} ${color #FF0009} ${upspeed eth1} k/s
${color green}${downspeedgraph eth1 20,150} ${alignr}${color #FF0009}${upspeedgraph eth1 20,150}
${color green}Total:${totaldown eth1} ${alignr}${color #FF0009}Total:${totalup eth1}
${color #B8FF00}WiFi:${color white} ${alignc} IP: ${addr eth0_rename} ${alignr}Rate:${color orange}${wireless_bitrate eth0_rename}${color white}
Link quality: ${color orange}${wireless_link_qual_perc eth0_rename}%${color white} ${alignr}${wireless_link_bar 8,185 eth0_rename}
${color green}WiFi Download: ${color white}${alignc} ESSID: ${color orange}${wireless_essid eth0_rename}${color white} $alignr${color #FF0009}WiFi Upload:
${color green}${downspeed eth0_rename}KB/s ${color #FF0009} ${alignr}${upspeed eth0_rename}KB/s
${color green}${downspeedgraph eth0_rename 20,150} ${alignr}${color #FF0009}${upspeedgraph eth0_rename 20,150}
${color green}Total:${totaldown eth0_rename} ${alignr}${color #FF0009}Total:${totalup eth0_rename}
${color white}AP Mode: ${wireless_mode eth0_rename} ${alignr}AP MAC: ${wireless_ap eth0_rename}[/code]
Un petit problème c’est que je ne comprends pas toutes les lignes, j’aimerais conserver seulement quelques petites choses et en ajouter d’autres.
C’est surtout la première partie que je n’arrive pas trop à “déchiffrer” on va dire.
