[quote=“mattotop”]il te faut un NOPASSWD qqpart (man sudoers)
l’ajout des users au groupe sudoers est inutile.[/quote]
+1
pour le sans pass :
tt est là :
[code]NOPASSWD and PASSWD
By default, sudo requires that a user authenticate him or herself before running a command. This behavior can be
modified via the NOPASSWD tag. Like a Runas_Spec, the NOPASSWD tag sets a default for the commands that follow
it in the Cmnd_Spec_List. Conversely, the PASSWD tag can be used to reverse things. For example:
ray rushmore = NOPASSWD: /bin/kill, /bin/ls, /usr/bin/lprm
would allow the user ray to run /bin/kill, /bin/ls, and /usr/bin/lprm as root on the machine rushmore as root
without authenticating himself. If we only want ray to be able to run /bin/kill without a password the entry
would be:
ray rushmore = NOPASSWD: /bin/kill, PASSWD: /bin/ls, /usr/bin/lprm
Note, however, that the PASSWD tag has no effect on users who are in the group specified by the exempt_group
option.
By default, if the NOPASSWD tag is applied to any of the entries for a user on the current host, he or she will
be able to run sudo -l without a password. Additionally, a user may only run sudo -v without a password if the
NOPASSWD tag is present for all a user’s entries that pertain to the current host. This behavior may be overrid‐
den via the verifypw and listpw options.
