Bonjour ,
Vous m’avez mis sur la piste de LTSP pour mon projet.
J’essaye de suivre ce wiki http://wiki.debian.org/LTSP/Howto mais je bloque sur la config du serveur dhcp.
- Configure /etc/dhcp3/dhcpd.conf and /etc/ltsp/dhcpd.conf:
Edit /etc/ltsp/dhcpd.conf to adapt to your network. See examples in /usr/share/doc/ltsp-server/examples/dhcpd.conf as a reference.
Include the LTSP dhcpd.conf at the bottom of /etc/dhcp3/dhcpd.conf
Restart dhcp3-server:
alors moi je touche a rien au /etc/dhcp3/dhcpd.conf a part la derniere ligne ou je met include "/etc/ltsp/dhcpd.conf"; et decommenter autoritative.
Sample configuration file for ISC dhcpd for Debian
$Id: dhcpd.conf,v 1.1.1.1 2002/05/21 00:07:44 peloy Exp $
The ddns-updates-style parameter controls whether or not the server will
attempt to do a DNS update when a lease is confirmed. We default to the
behavior of the version 2 packages (‘none’, since DHCP v2 didn’t
have support for DDNS.)
ddns-update-style none;
option definitions common to all supported networks…
option domain-name “example.org”;
option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
If this DHCP server is the official DHCP server for the local
network, the authoritative directive should be uncommented.
authoritative;
Use this to send dhcp log messages to a different log file (you also
have to hack syslog.conf to complete the redirection).
log-facility local7;
No service will be given on this subnet, but declaring it helps the
DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
This is a very basic subnet declaration.
#subnet 10.254.239.0 netmask 255.255.255.224 {
range 10.254.239.10 10.254.239.20;
option routers rtr-239-0-1.example.org, rtr-239-0-2.example.org;
This declaration allows BOOTP clients to get dynamic addresses,
which we don’t really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
range dynamic-bootp 10.254.239.40 10.254.239.60;
option broadcast-address 10.254.239.31;
option routers rtr-239-32-1.example.org;
A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
range 10.5.5.26 10.5.5.30;
option domain-name-servers ns1.internal.example.org;
option domain-name “internal.example.org”;
option routers 10.5.5.1;
option broadcast-address 10.5.5.31;
Hosts which require special configuration options can be listed in
host statements. If no address is specified, the address will be
allocated dynamically (if possible), but the host-specific information
will still come from the host declaration.
#host passacaglia {
hardware ethernet 0:0:c0:5d:bd:95;
filename “vmunix.passacaglia”;
server-name “toccata.fugue.com”;
Fixed IP addresses can also be specified for hosts. These addresses
should not also be listed as being available for dynamic assignment.
Hosts for which fixed IP addresses have been specified can boot using
BOOTP or DHCP. Hosts for which no fixed address is specified can only
be booted with DHCP, unless there is an address range on the subnet
to which a BOOTP client is connected which has the dynamic-bootp flag
set.
#host fantasia {
hardware ethernet 08:00:07:26:c0:a5;
fixed-address fantasia.fugue.com;
You can declare a class of clients and then do address allocation
based on that. The example below shows a case where all clients
in a certain class get addresses on the 10.17.224/24 subnet, and all
other clients get addresses on the 10.0.29/24 subnet.
#class “foo” {
match if substring (option vendor-class-identifier, 0, 4) = “SUNW”;
#shared-network 224-29 {
subnet 10.17.224.0 netmask 255.255.255.0 {
option routers rtr-224.example.org;
subnet 10.0.29.0 netmask 255.255.255.0 {
option routers rtr-29.example.org;
pool {
allow members of “foo”;
range 10.17.224.10 10.17.224.250;
pool {
deny members of “foo”;
range 10.0.29.10 10.0.29.230;
include “/etc/ltsp/dhcpd.conf”;
et je le configure comme ca :
[code]#
Default LTSP dhcpd.conf config file.
authoritative;
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.20 192.168.0.250;
option domain-name “example.com”;
option domain-name-servers 192.168.0.1;
option broadcast-address 192.168.0.255;
option routers 192.168.0.1;
next-server 192.168.0.1;
get-lease-hostnames true;
option subnet-mask 255.255.255.0;
option root-path "/opt/ltsp/i386";
if substring( option vendor-class-identifier, 0, 9 ) = "PXEClient" {
filename "/ltsp/i386/pxelinux.0";
} else {
filename "/ltsp/i386/nbi.img";
}[/code]
et je me met en ip fixe : 192.168.0.1
je restart le serveur
et sur le pc qui boot sur le lan j’ai
mount call failed:13
des idées ?
