Configuration prosody
Aprés avoir discuté sur le tchat de jappix, j’ai finalement décidé de laisser tomber openfire pour installer prosody en me servant du tuto suivant: jeyg.info/un-serveur-xmpp-pe … 5-minutes/
Mais la j’ai des problemes de disponibilité de mon serveur
voila ma configuration actuelle
/etc/prosody/prosody.cfg.lua
-- Prosody Example Configuration File
-- Information on configuring Prosody can be found on our
-- website at http://prosody.im/doc/configure
-- Tip: You can check that the syntax of this file is correct
-- when you have finished by running: luac -p prosody.cfg.lua
-- If there are any errors, it will let you know what and where
-- they are, otherwise it will keep quiet.
-- The only thing left to do is rename this file to remove the .dist ending, and fill in the
-- blanks. Good luck, and happy Jabbering!
---------- Server-wide settings ----------
-- Settings in this section apply to the whole server and are the default settings
-- for any virtual hosts
-- This is a (by default, empty) list of accounts that are admins
-- for the server. Note that you must create the accounts separately
-- (see http://prosody.im/doc/creating_accounts for info)
-- Example: admins = { "user1@example.com", "user2@example.net" }
admins = { }
-- Enable use of libevent for better performance under high load
-- For more information see: http://prosody.im/doc/libevent
--use_libevent = true;
-- This is the list of modules Prosody will load on startup.
-- It looks for mod_modulename.lua in the plugins folder, so make sure that exists too.
-- Documentation on modules can be found at: http://prosody.im/doc/modules
modules_enabled = {
        -- Generally required
                "roster"; -- Allow users to have a roster. Recommended ;)
                "saslauth"; -- Authentication for clients and servers. Recommended if you want to log in.
                "tls"; -- Add support for secure TLS on c2s/s2s connections
                "dialback"; -- s2s dialback support
                "disco"; -- Service discovery
        -- Not essential, but recommended
                "private"; -- Private XML storage (for room bookmarks, etc.)
                "vcard"; -- Allow users to set vCards
                --"privacy"; -- Support privacy lists
                --"compression"; -- Stream compression
        -- Nice to have
                "legacyauth"; -- Legacy authentication. Only used by some old clients and bots.
                "version"; -- Replies to server version requests
                "uptime"; -- Report how long server has been running
                "time"; -- Let others know the time here on this server
                "ping"; -- Replies to XMPP pings with pongs
                "pep"; -- Enables users to publish their mood, activity, playing music and more
                "register"; -- Allow users to register on this server using a client and change passwords
        -- Other specific functionality
                --"console"; -- Opens admin telnet interface on localhost port 5582
                "bosh"; -- Enable BOSH clients, aka "Jabber over HTTP"
                "httpserver"; -- Serve static files from a directory over HTTP
                "groups"; -- Shared roster support
                "announce"; -- Send announcement to all online users
                "welcome"; -- Welcome users who register accounts
                --"watchregistrations"; -- Alert admins of registrations
        -- Debian: do not remove this module, or you lose syslog
        -- support
                "posix"; -- POSIX functionality, sends server to background, enables syslog, etc.
-- These modules are auto-loaded, should you
-- for (for some mad reason) want to disable
-- them then uncomment them below
modules_disabled = {
        -- "presence";
        -- "message";
        -- "iq";
-- Disable account creation by default, for security
-- For more information see http://prosody.im/doc/creating_accounts
allow_registration = true;
-- Debian:
--   send the server to background.
daemonize = true;
-- Debian:
--   Please, don't change this option since /var/run/prosody/
--   is one of the few directories Prosody is allowed to write to
pidfile = "/var/run/prosody/prosody.pid";
-- These are the SSL/TLS-related settings. If you don't want
-- to use SSL/TLS, you may comment or remove this
ssl = {
        key = "/etc/prosody/certs/localhost.key";
        certificate = "/etc/prosody/certs/localhost.cert";
-- Require encryption on client/server connections?
--c2s_require_encryption = false
--s2s_require_encryption = false
-- Logging configuration
-- For advanced logging see http://prosody.im/doc/logging
log = "prosody.log";
debug = false; -- Log debug messages?
-- Debian:
--  all to var/log
--  errors to syslog also
log = {
        { levels = { "error" }; to = "syslog";  };
        { levels = { "error" }; to = "file"; filename = "/var/log/prosody/prosody.err";  };
        -- Change "info" to "debug" for more verbose logging
        { levels = { min = "info" }; to = "file"; filename = "/var/log/prosody/prosody.log";  };
-- Loads all configuration files in /etc/prosody/conf.d/ --
local ztact = require "util.ztact"
local cfgdir = "/etc/prosody/conf.d/"
for f in ztact.dir(cfgdir) do Include(cfgdir..f); end
/etc/prosody/conf.avail/blabla.dlinkddns.com.cfg.lua
[code]-- Section for example.com
VirtualHost "blabla.dlinkddns.com"
enabled = true
    -- Assign this host a certificate for TLS, otherwise it would use the one
    -- set in the global section (if any).
    -- Note that old-style SSL on port 5223 only supports one certificate, and will always
    -- use the global one.
    ssl = {
            key = "/etc/prosody/certs/example.com.key";
            certificate = "/etc/prosody/certs/example.com.crt";
------ Components ------
– You can specify components to add hosts that provide special services,
– like multi-user conferences, and transports.
– For more information on components, see http://prosody.im/doc/components
– Set up a MUC (multi-user chat) room server on conference.example.com:
Component “conference.example.com” “muc”
– Set up a SOCKS5 bytestream proxy for server-proxied file transfers:
–Component “proxy.example.com” “proxy65”
—Set up an external component (default component port is 5347)
–Component “gateway.example.com”
– component_secret = “password”
/etc/prosody/conf.d/:
blabla.dlinkddns.com.cfg.lua -> …/conf.avail/blabla.dlinkddns.com.cfg.lua
localhost.cfg.lua -> …/conf.avail/localhost.cfg.lua
j’ai bien créé un user via: prosodyctl adduser myuser@blabla.dlinkddns.com
j’ai ajouté a /etc/bind/
_xmpp-client._tcp.blabla.dlinkddns.com 86400 IN SRV 20 0 5222 blabla.dlinkddns.com
_xmpp-server._tcp.blabla.dlinkddns.com 86400 IN SRV 20 0 5269 blabla.dlinkddns.com
Sur le routeur j’ai ouvert les ports 5269, 5222, 5280.
Ensuite je me connecte a mon serveur via jappix sur l’adresse: blabla.dlinkddns.com/jappix/
j’ai bien accés au panneau d’accueil mais une fois le user et mdp entrée en choississant comme serveur @blabla.dlinkddns.com
Jappix me dit service indisponible :smiling_imp:
ma configuration jappix
Hôte principal: blabla.dlinkddns.com
Hôte de salons: muc.blabla.dlinkddns.com
Hôte Pubsub: pubsub.blabla.dlinkddns.com
Hôte anonyme: anonymous.blabla.dlinkddns.com
Hôte d’annuaire: vjud.blabla.dlinkddns.com
hote bosh: localhost:5280/http-bind
La je ne vois pas du tout ou est le soucis
Déja pour éliminer les sources d’erreurs, est ce que ma configuration de prosody est correcte??
ouf c’est resolu avec l’aide du forum jappix :dance:
c’etait une erreur dans les configs des deux logiciels :whistle:
