J’ai suivi ce tuto pour installer un serveur DNS en intranet sur une machine Linux Debian. A la fin j’arrive à un serveur qui démarre sans problème mais malheureusement il est pas fonctionnel. En effet, les tests avec les commandes nslookup et host résultent en un timeout.
-Le nom d’hôte de la machine Linux est : serveurdns
-Son ipv4: 10.0.0.10
-Le domaine à mettre en place: ensias.org
-Les logs affichent (tail -30 /var/log/syslog):
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'E.ROOT-SERVERS.NET/AAAA/IN': 2001:500:2f::f#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'E.ROOT-SERVERS.NET/AAAA/IN': 2001:7fe::53#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'G.ROOT-SERVERS.NET/AAAA/IN': 2001:500:2f::f#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'G.ROOT-SERVERS.NET/AAAA/IN': 2001:7fe::53#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'serveurdns/A/IN': 2001:503:ba3e::2:30#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'serveurdns/AAAA/IN': 2001:503:ba3e::2:30#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'B.ROOT-SERVERS.NET/AAAA/IN': 192.58.128.30#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'B.ROOT-SERVERS.NET/AAAA/IN': 2001:500:3::42#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'B.ROOT-SERVERS.NET/AAAA/IN': 202.12.27.33#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'C.ROOT-SERVERS.NET/AAAA/IN': 192.58.128.30#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'C.ROOT-SERVERS.NET/AAAA/IN': 2001:500:3::42#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'C.ROOT-SERVERS.NET/AAAA/IN': 202.12.27.33#53
Aug 21 19:36:26 serveurdns named[4208]: error (network unreachable) resolving 'D.ROOT-SERVERS.NET/AAAA/IN': 192.58.128.30#53
Aug 21 19:36:26 serveurdns rsyslogd-2177: imuxsock begins to drop messages from pid 4208 due to rate-limiting
Aug 21 19:48:56 serveurdns dbus[2270]: [system] Activating service name='org.freedesktop.SystemToolsBackends.SMBConfig' (using servicehelper)
Aug 21 19:48:56 serveurdns dbus[2270]: [system] Activating service name='org.freedesktop.SystemToolsBackends.NFSConfig' (using servicehelper)
Aug 21 19:48:57 serveurdns dbus[2270]: [system] Successfully activated service 'org.freedesktop.SystemToolsBackends.SMBConfig'
Aug 21 19:48:57 serveurdns dbus[2270]: [system] Successfully activated service 'org.freedesktop.SystemToolsBackends.NFSConfig'
Aug 21 19:50:36 serveurdns ntpd_intres[2754]: host name not found: 0.debian.pool.ntp.org
Aug 21 19:50:36 serveurdns ntpd_intres[2754]: host name not found: 1.debian.pool.ntp.org
Aug 21 19:50:36 serveurdns ntpd_intres[2754]: host name not found: 2.debian.pool.ntp.org
Aug 21 19:50:36 serveurdns ntpd_intres[2754]: host name not found: 3.debian.pool.ntp.org
Aug 21 19:58:36 serveurdns dhclient: DHCPREQUEST on eth0 to 10.0.0.9 port 67
Aug 21 19:58:36 serveurdns dhclient: DHCPACK from 10.0.0.9
Aug 21 19:58:36 serveurdns dhclient: bound to 10.0.0.10 -- renewal in 1631 seconds.
Aug 21 19:58:36 serveurdns NetworkManager[2549]: <info> (eth0): DHCPv4 state changed bound -> renew
Aug 21 19:58:36 serveurdns NetworkManager[2549]: <info> address 10.0.0.10
Aug 21 19:58:36 serveurdns NetworkManager[2549]: <info> prefix 8 (255.0.0.0)
Aug 21 19:58:36 serveurdns dbus[2270]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Aug 21 19:58:37 serveurdns dbus[2270]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Voici mes fichiers du répertoire /etc/bind.
Pouvez-vous m’aider ? Merci
