Configuration Webcam
J’utilise Debian Squeeze avec KDE4 sur mes postes de travail. Ma principale machine est une 64bits. Jusque-là, je suis très content de tout ça. Il me reste quelques broutilles à voir. Une chose après l’autre.
Voici ma Webcam :
[kikinovak@alphamule:~] $ lsusb Bus 002 Device 002: ID 046d:0928 Logitech, Inc. QuickCam Express ...
Lorsque j’essaie de tester ce que ça donne, je n’obtiens pas de vidéo, juste la série de messages que voici :
[code][kikinovak@alphamule:~] $ mplayer tv://
MPlayer SVN-r31918 © 2000-2010 MPlayer Team
Can’t open joystick device /dev/input/js0: No such file or directory
Can’t init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv://.
TV file format detected.
Selected driver: v4l2
name: Video 4 Linux 2 input
author: Martin Olschewski olschewski@zpr.uni-koeln.de
comment: first try, more to come :wink:
v4l2: your device driver does not support VIDIOC_G_STD ioctl, VIDIOC_G_PARM was used instead.
Selected device: Camera
Capabilities: video capture read/write streaming
supported norms:
inputs: 0 = spca561;
Current input: 0
Current format: unknown (0x31363553)
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
v4l2: ioctl enum norm failed: Invalid argument
Error: Cannot set norm!
Selected input hasn’t got a tuner!
v4l2: Cannot get fps
v4l2: ioctl set mute failed: Invalid argument
v4l2: ioctl query control failed: Invalid argument
open: No such file or directory
[MGA] Couldn’t open: /dev/mga_vid
[VO_TDFXFB] Can’t open /dev/fb0: No such file or directory.
s3fb: can’t open /dev/fb0: No such file or directory
Cannot find codec matching selected -vo and video format 0x31363553.
v4l2: 3 frames successfully processed, 3 frames dropped.
Exiting… (End of file)[/code]
Et là, je n’ai pas la moindre idée de ce que je peux faire. Quelqu’un a une suggestion ?
Remarque : la machine tournait sous Ubuntu 10.04 64bits avant, et la webcam fonctionnait.
essaye d’utiliser la cam avec vlc,pour voir ce qui se passe.Dans vlc—>Media—>ouvrir un périphérique de capture
essaye aussi:
et regarde si ca marche
Merci pour le tuyau ! La cam marche nickel !
