[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-1-686 (Debian 2.6.26-9) (waldi@debian.org) (gcc version 4.1.3 20080623 (prerelease) (Debian 4.1.2-23)) #1 SMP Sat Oct 18 16:22:25 UTC 2008
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000004ff70000 (usable)
[ 0.000000] BIOS-e820: 000000004ff70000 - 000000004ff7f000 (ACPI data)
[ 0.000000] BIOS-e820: 000000004ff7f000 - 000000004ff80000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000004ff80000 - 0000000050000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] 383MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 327536) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 327536
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 327536
[ 0.000000] On node 0 totalpages: 327536
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 767 pages used for memmap
[ 0.000000] HighMem zone: 97393 pages, LIFO batch:31
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP 000F7240, 0014 (r0 PTLTD )
[ 0.000000] ACPI: RSDT 4FF7A89F, 0034 (r1 PTLTD RSDT 6040000 LTP 0)
[ 0.000000] ACPI: FACP 4FF7EE34, 0074 (r1 NVIDIA CK8 6040000 PTL_ F4240)
[ 0.000000] ACPI: DSDT 4FF7A8D3, 4561 (r1 NVIDIA CK8 6040000 MSFT 100000E)
[ 0.000000] ACPI: FACS 4FF7FFC0, 0040
[ 0.000000] ACPI: APIC 4FF7EEA8, 005A (r1 NVIDIA NV_APIC_ 6040000 LTP 0)
[ 0.000000] ACPI: BOOT 4FF7EF02, 0028 (r1 PTLTD $SBFTBL$ 6040000 LTP 1)
[ 0.000000] ACPI: SSDT 4FF7EF2A, 00D6 (r1 PTLTD POWERNOW 6040000 LTP 1)
[ 0.000000] ACPI: DMI detected: Hewlett-Packard
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x8008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 pin2 override ignored.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 60000000 (gap: 50000000:aff80000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000d0000
[ 0.000000] PM: Registered nosave memory: 00000000000d0000 - 0000000000100000
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37960 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 324977
[ 0.000000] Kernel command line: root=/dev/hda7 ro
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 797.953 MHz processor.
[ 0.004000] spurious 8259A interrupt: IRQ7.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Memory: 1287776k/1310144k available (1768k kernel code, 21096k reserved, 752k data, 244k init, 392640k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 0.004000] .init : 0xc037f000 - 0xc03bc000 ( 244 kB)
[ 0.004000] .data : 0xc02ba25b - 0xc0376620 ( 752 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02ba25b (1768 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084243] Calibrating delay using timer specific routine.. 1597.59 BogoMIPS (lpj=3195188)
[ 0.084418] Security Framework initialized
[ 0.084486] SELinux: Disabled at boot.
[ 0.084546] Capability LSM initialized
[ 0.084628] Mount-cache hash table entries: 512
[ 0.084938] Initializing cgroup subsys ns
[ 0.085000] Initializing cgroup subsys cpuacct
[ 0.085061] Initializing cgroup subsys devices
[ 0.085149] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.085215] CPU: L2 Cache: 256K (64 bytes/line)
[ 0.085277] Intel machine check architecture supported.
[ 0.085339] Intel machine check reporting enabled on CPU#0.
[ 0.085420] Checking 'hlt' instruction... OK.
[ 0.100791] SMP alternatives: switching to UP code
[ 0.116007] Freeing SMP alternatives: 16k freed
[ 0.116007] ACPI: Core revision 20080321
[ 0.132008] ENABLING IO-APIC IRQs
[ 0.132008] ..TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.174782] CPU0: AMD Athlon(tm) XP Processor 3000+ stepping 00
[ 0.176011] Brought up 1 CPUs
[ 0.176011] Total of 1 processors activated (1597.59 BogoMIPS).
[ 0.176011] CPU0 attaching sched-domain:
[ 0.176011] domain 0: span 0
[ 0.176011] groups: 0
[ 0.176011] net_namespace: 660 bytes
[ 0.176011] Booting paravirtualized kernel on bare hardware
[ 0.176011] NET: Registered protocol family 16
[ 0.176011] ACPI: bus type pci registered
[ 0.176011] PCI: PCI BIOS revision 2.10 entry at 0xfd8bc, last bus=2
[ 0.176011] PCI: Using configuration type 1 for base access
[ 0.176011] Setting up standard PCI resources
[ 0.178008] ACPI: EC: Look up EC in DSDT
[ 0.180973] ACPI: Interpreter enabled
[ 0.181036] ACPI: (supports S0 S3 S4 S5)
[ 0.181248] ACPI: Using IOAPIC for interrupt routing
[ 0.186610] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.266263] ACPI: EC: GPE = 0x21, I/O: command/status = 0x66, data = 0x62
[ 0.266331] ACPI: EC: driver started in interrupt mode
[ 0.266484] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.267710] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.267864] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P0._PRT]
[ 0.267943] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP0._PRT]
[ 0.292587] ACPI: PCI Interrupt Link [LNK1] (IRQs 16 18 19) *0
[ 0.293192] ACPI: PCI Interrupt Link [LNK2] (IRQs 16 18 19) *0
[ 0.293785] ACPI: PCI Interrupt Link [LNK3] (IRQs 17) *0
[ 0.294308] ACPI: PCI Interrupt Link [LNK4] (IRQs 16 18 19) *0, disabled.
[ 0.294939] ACPI: PCI Interrupt Link [LNK5] (IRQs 16 18 19) *0
[ 0.295524] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22) *0
[ 0.296131] ACPI: PCI Interrupt Link [LUS0] (IRQs 20 21 22) *0
[ 0.296720] ACPI: PCI Interrupt Link [LUS1] (IRQs 20 21 22) *0
[ 0.297307] ACPI: PCI Interrupt Link [LUS2] (IRQs 20 21 22) *0
[ 0.297895] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22) *0, disabled.
[ 0.298518] ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22) *0
[ 0.299112] ACPI: PCI Interrupt Link [LMCI] (IRQs 20 21 22) *0
[ 0.299708] ACPI: PCI Interrupt Link [LPID] (IRQs 20 21 22) *0, disabled.
[ 0.300354] ACPI: PCI Interrupt Link [LTID] (IRQs 20 21 22) *0, disabled.
[ 0.300926] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.301044] pnp: PnP ACPI init
[ 0.301111] ACPI: bus type pnp registered
[ 0.331150] pnp: PnP ACPI: found 12 devices
[ 0.331213] ACPI: ACPI bus type pnp unregistered
[ 0.331275] PnPBIOS: Disabled by ACPI PNP
[ 0.331783] PCI: Using ACPI for IRQ routing
[ 0.332166] ACPI: RTC can wake from S4
[ 0.332268] system 00:01: ioport range 0x8000-0x807f has been reserved
[ 0.332334] system 00:01: ioport range 0x8080-0x80ff has been reserved
[ 0.332399] system 00:01: ioport range 0x8400-0x847f has been reserved
[ 0.332463] system 00:01: ioport range 0x8480-0x84ff has been reserved
[ 0.332528] system 00:01: ioport range 0x8800-0x887f has been reserved
[ 0.332593] system 00:01: ioport range 0x8880-0x88ff has been reserved
[ 0.332658] system 00:01: ioport range 0x2040-0x207f has been reserved
[ 0.332723] system 00:01: ioport range 0x2000-0x203f has been reserved
[ 0.332801] system 00:02: iomem range 0xfff80000-0xffffffff could not be reserved
[ 0.332883] system 00:02: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.332949] system 00:02: iomem range 0xfee00000-0xfeefffff has been reserved
[ 0.333021] system 00:02: iomem range 0xfed00000-0xfed00fff has been reserved
[ 0.333095] system 00:03: ioport range 0x200-0x20f has been reserved
[ 0.333159] system 00:03: ioport range 0x680-0x6ff has been reserved
[ 0.333224] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.333289] system 00:03: ioport range 0xfe00-0xfe01 has been reserved
[ 0.364117] PCI: region 0000:02:04.0/9 too large: 0x0000000000000000-0x0000000003ffffff
[ 0.364201] PCI: region 0000:02:04.1/9 too large: 0x0000000000000000-0x0000000003ffffff
[ 0.364299] PCI: Failed to allocate mem resource #10:4000000@e4000000 for 0000:02:04.0
[ 0.364382] PCI: Failed to allocate mem resource #10:4000000@e4000000 for 0000:02:04.1
[ 0.364467] PCI: Bus 3, cardbus bridge: 0000:02:04.0
[ 0.364527] IO window: 0x00003000-0x000030ff
[ 0.364588] IO window: 0x00003400-0x000034ff
[ 0.364649] PCI: Bus 7, cardbus bridge: 0000:02:04.1
[ 0.364709] IO window: 0x00003800-0x000038ff
[ 0.364769] IO window: 0x00003c00-0x00003cff
[ 0.364828] PCI: Bridge: 0000:00:0a.0
[ 0.364885] IO window: 3000-7fff
[ 0.364944] MEM window: 0xe0100000-0xe17fffff
[ 0.365004] PREFETCH window: disabled.
[ 0.365065] PCI: Bridge: 0000:00:0b.0
[ 0.365121] IO window: disabled.
[ 0.365181] MEM window: 0xe2000000-0xe2ffffff
[ 0.365242] PREFETCH window: 0x00000000f0000000-0x00000000f80fffff
[ 0.365316] PCI: Setting latency timer of device 0000:00:0a.0 to 64
[ 0.365859] ACPI: PCI Interrupt Link [LNK1] enabled at IRQ 19
[ 0.365928] ACPI: PCI Interrupt 0000:02:04.0[A] -> Link [LNK1] -> GSI 19 (level, low) -> IRQ 19
[ 0.366548] ACPI: PCI Interrupt Link [LNK2] enabled at IRQ 18
[ 0.366613] ACPI: PCI Interrupt 0000:02:04.1[B] -> Link [LNK2] -> GSI 18 (level, low) -> IRQ 18
[ 0.366816] NET: Registered protocol family 2
[ 0.367055] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.367719] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.369368] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.371414] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.371480] TCP reno registered
[ 0.371706] NET: Registered protocol family 1
[ 0.371991] checking if image is initramfs...<7>Switched to high resolution mode on CPU 0
[ 0.987215] it is
[ 1.663119] Freeing initrd memory: 6748k freed
[ 1.663396] Simple Boot Flag at 0x37 set to 0x1
[ 1.664436] audit: initializing netlink socket (disabled)
[ 1.664518] type=2000 audit(1226604784.664:1): initialized
[ 1.664822] highmem bounce pool size: 64 pages
[ 1.664885] Total HugeTLB memory allocated, 0
[ 1.665053] VFS: Disk quotas dquot_6.5.1
[ 1.665173] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.665292] msgmni has been set to 1763
[ 1.665542] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.665623] io scheduler noop registered
[ 1.665681] io scheduler anticipatory registered
[ 1.665740] io scheduler deadline registered
[ 1.665813] io scheduler cfq registered (default)
[ 1.666048] pci 0000:01:00.0: Boot video device
[ 1.666659] isapnp: Scanning for PnP cards...
[ 2.020862] isapnp: No Plug & Play device found
[ 2.025654] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 2.027043] ACPI: PCI Interrupt Link [LMCI] enabled at IRQ 22
[ 2.027114] ACPI: PCI Interrupt 0000:00:06.1[B] -> Link [LMCI] -> GSI 22 (level, low) -> IRQ 22
[ 2.027268] ACPI: PCI interrupt for device 0000:00:06.1 disabled
[ 2.030390] brd: module loaded
[ 2.030619] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.036727] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 2.046835] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.046900] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 2.046961] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 2.047022] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 2.047084] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 2.047402] mice: PS/2 mouse device common for all mice
[ 2.047903] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 2.047985] rtc0: alarms up to one year, y3k
[ 2.048094] cpuidle: using governor ladder
[ 2.048094] cpuidle: using governor menu
[ 2.048094] No iBFT detected.
[ 2.049263] TCP cubic registered
[ 2.049322] NET: Registered protocol family 17
[ 2.049388] Using IPI No-Shortcut mode
[ 2.049819] registered taskstats version 1
[ 2.050149] rtc_cmos 00:06: setting system clock to 2008-11-13 19:33:05 UTC (1226604785)
[ 2.050484] Freeing unused kernel memory: 244k freed
[ 2.087203] input: AT Translated Set 2 keyboard as /class/input/input0
[ 2.303506] ACPI: CPU0 (power states: C1[C1] C2[C2])
[ 2.303764] ACPI: ACPI0007:00 is registered as cooling_device0
[ 2.307981] Marking TSC unstable due to: TSC halts in idle.
[ 2.320061] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 2.326940] ACPI: Thermal Zone [THRM] (48 C)
[ 3.114028] usbcore: registered new interface driver usbfs
[ 3.114146] usbcore: registered new interface driver hub
[ 3.114282] usbcore: registered new device driver usb
[ 3.128286] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.128336] ohci_hcd 0000:00:02.0: enabling device (0004 -> 0006)
[ 3.129047] ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 21
[ 3.129118] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUS0] -> GSI 21 (level, low) -> IRQ 21
[ 3.129282] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 3.129289] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 3.129525] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 3.377310] ohci_hcd 0000:00:02.0: irq 21, io mem 0xe0000000
[ 3.434214] usb usb1: configuration #1 chosen from 1 choice
[ 3.434337] hub 1-0:1.0: USB hub found
[ 3.434408] hub 1-0:1.0: 3 ports detected
[ 3.536286] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.536359] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.536439] usb usb1: Product: OHCI Host Controller
[ 3.536500] usb usb1: Manufacturer: Linux 2.6.26-1-686 ohci_hcd
[ 3.536561] usb usb1: SerialNumber: 0000:00:02.0
[ 3.536687] ohci_hcd 0000:00:02.1: enabling device (0004 -> 0006)
[ 3.537288] ACPI: PCI Interrupt Link [LUS1] enabled at IRQ 20
[ 3.537358] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUS1] -> GSI 20 (level, low) -> IRQ 20
[ 3.537522] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 3.537529] ohci_hcd 0000:00:02.1: OHCI Host Controller
[ 3.537639] ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
[ 4.379354] No dock devices found.
[ 4.495786] SCSI subsystem initialized
[ 4.649230] libata version 3.00 loaded.
[ 4.778679] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 5.008777] ohci_hcd 0000:00:02.1: irq 20, io mem 0xe0001000
[ 5.066204] usb usb2: configuration #1 chosen from 1 choice
[ 5.066329] hub 2-0:1.0: USB hub found
[ 5.066400] hub 2-0:1.0: 3 ports detected
[ 5.168258] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.168331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.168412] usb usb2: Product: OHCI Host Controller
[ 5.168472] usb usb2: Manufacturer: Linux 2.6.26-1-686 ohci_hcd
[ 5.168534] usb usb2: SerialNumber: 0000:00:02.1
[ 5.169413] ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 22
[ 5.169477] ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [LUS2] -> GSI 22 (level, low) -> IRQ 22
[ 5.169643] PCI: Setting latency timer of device 0000:00:02.2 to 64
[ 5.169650] ehci_hcd 0000:00:02.2: EHCI Host Controller
[ 5.169756] ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
[ 5.169877] PCI: cache line size of 64 is not supported by device 0000:00:02.2
[ 5.169902] ehci_hcd 0000:00:02.2: irq 22, io mem 0xe0004000
[ 5.180058] ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 5.180271] usb usb3: configuration #1 chosen from 1 choice
[ 5.180393] hub 3-0:1.0: USB hub found
[ 5.180466] hub 3-0:1.0: 6 ports detected
[ 5.284206] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.284272] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.284352] usb usb3: Product: EHCI Host Controller
[ 5.284411] usb usb3: Manufacturer: Linux 2.6.26-1-686 ehci_hcd
[ 5.284474] usb usb3: SerialNumber: 0000:00:02.2
[ 5.299797] ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [LNK1] -> GSI 19 (level, low) -> IRQ 19
[ 5.349857] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[19] MMIO=[e0108000-e01087ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 5.350197] Uniform Multi-Platform E-IDE driver
[ 5.350261] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 5.351592] NFORCE3-150: 0000:00:08.0 (rev a5) UDMA133 controller
[ 5.351664] NFORCE3-150: IDE controller (0x10de:0x00d5 rev 0xa5) at PCI slot 0000:00:08.0
[ 5.351773] NFORCE3-150: not 100% native mode: will probe irqs later
[ 5.351842] NFORCE3-150: BIOS didn't set cable bits correctly. Enabling workaround.
[ 5.351933] ide0: BM-DMA at 0x2080-0x2087
[ 5.351999] ide1: BM-DMA at 0x2088-0x208f
[ 5.352090] Probing IDE interface ide0...
[ 5.362869] 8139cp 0000:02:01.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
[ 5.362958] 8139cp 0000:02:01.0: Try the "8139too" driver instead.
[ 5.363629] ACPI: PCI Interrupt Link [LNK3] enabled at IRQ 17
[ 5.363699] ACPI: PCI Interrupt 0000:02:02.0[A] -> Link [LNK3] -> GSI 17 (level, low) -> IRQ 17
[ 5.367288] ssb: Sonics Silicon Backplane found on PCI device 0000:02:02.0
[ 5.373114] 8139too Fast Ethernet driver 0.9.28
[ 5.640142] hda: FUJITSU MHT2060AT PL, ATA DISK drive
[ 6.312110] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 6.314570] hda: UDMA/100 mode selected
[ 6.316822] Probing IDE interface ide1...
[ 6.632224] ieee1394: Host added: ID:BUS[0-00:1023] GUID[473f0200473f0200]
[ 7.108129] hdc: SD-R6252, ATAPI CD/DVD-ROM drive
[ 7.780116] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 7.808258] hdc: MWDMA2 mode selected
[ 7.808790] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 7.888988] ide1 at 0x170-0x177,0x376 on irq 15
[ 7.899251] ACPI: PCI Interrupt 0000:02:01.0[A] -> Link [LNK2] -> GSI 18 (level, low) -> IRQ 18
[ 7.899251] eth0: RealTek RTL8139 at 0x7000, 00:0f:b0:05:40:b4, IRQ 18
[ 7.899251] eth0: Identified 8139 chip type 'RTL-8101'
[ 7.899251] b44.c:v2.0
[ 7.899251] b44: Invalid MAC address found in EEPROM
[ 7.899251] b44 ssb0:1: Problem fetching invariants of chip, aborting.
[ 7.899251] b44: probe of ssb0:1 failed with error -22
[ 7.985925] hda: max request size: 128KiB
[ 7.988414] hda: 117210240 sectors (60011 MB) w/8192KiB Cache, CHS=65535/16/63
[ 7.994422] hda: cache flushes supported
[ 7.994554] hda: hda1 hda2 < hda5 hda6 hda7 hda8floppy0: no floppy controllers found
[ 8.103657] hda9 hda10 hda11 >
[ 8.147126] hdc: ATAPI 24X DVD-ROM CD-R/RW drive, 2048kB Cache
[ 8.147366] Uniform CD-ROM driver Revision: 3.20
[ 8.792794] PM: Starting manual resume from disk
[ 8.843452] JFS: nTxBlock = 8192, nTxLock = 65536
[ 11.038579] udevd version 125 started
[ 13.685208] Linux agpgart interface v0.103
[ 13.739114] agpgart: Detected AGP bridge 0
[ 13.739229] agpgart: Setting up Nforce3 AGP.
[ 13.745854] agpgart: AGP aperture is 128M @ 0xe8000000
[ 13.907258] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x2040
[ 13.907359] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x2000
[ 14.388671] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 14.399586] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.928918] input: Power Button (FF) as /class/input/input1
[ 14.952751] ACPI: Power Button (FF) [PWRF]
[ 14.952958] input: Power Button (CM) as /class/input/input2
[ 14.986225] ACPI: Power Button (CM) [PWRB]
[ 14.986426] input: Lid Switch as /class/input/input3
[ 15.002191] ACPI: Lid Switch [LID]
[ 15.289449] ACPI: WMI: Mapper loaded
[ 16.661798] ACPI: AC Adapter [ACAD] (on-line)
[ 17.904262] ACPI: Battery Slot [BAT1] (battery present)
[ 17.905987] input: Video Bus as /class/input/input4
[ 17.933109] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 18.442155] Yenta: CardBus bridge found at 0000:02:04.0 [103c:006d]
[ 18.442245] PCI: Bus 3, cardbus bridge: 0000:02:04.0
[ 18.442306] IO window: 0x00003000-0x000030ff
[ 18.442367] IO window: 0x00003400-0x000034ff
[ 18.442429] PREFETCH window: 0xe0400000-0xe07fffff
[ 18.442491] MEM window: 0xe0800000-0xe0bfffff
[ 18.442554] Yenta: Enabling burst memory read transactions
[ 18.442617] Yenta: Using CSCINT to route CSC interrupts to PCI
[ 18.442678] Yenta: Routing CardBus interrupts to PCI
[ 18.442741] Yenta TI: socket 0000:02:04.0, mfunc 0x01111d22, devctl 0x64
[ 18.672827] Yenta: ISA IRQ mask 0x0cf8, PCI irq 19
[ 18.672895] Socket status: 30000086
[ 18.672954] Yenta: Raising subordinate bus# of parent bus (#02) from #02 to #06
[ 18.673039] pcmcia: parent PCI bridge I/O window: 0x3000 - 0x7fff
[ 18.673103] cs: IO port probe 0x3000-0x7fff: clean.
[ 18.675325] pcmcia: parent PCI bridge Memory window: 0xe0100000 - 0xe17fffff
[ 18.820656] ACPI: PCI Interrupt 0000:00:06.1[B] -> Link [LMCI] -> GSI 22 (level, low) -> IRQ 22
[ 18.820839] PCI: Setting latency timer of device 0000:00:06.1 to 64
[ 18.928868] ACPI: PCI Interrupt Link [LACI] enabled at IRQ 21
[ 18.928937] ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [LACI] -> GSI 21 (level, low) -> IRQ 21
[ 18.929121] PCI: Setting latency timer of device 0000:00:06.0 to 64
[ 18.929170] Yenta: CardBus bridge found at 0000:02:04.1 [103c:006d]
[ 18.929253] Yenta: Using CSCINT to route CSC interrupts to PCI
[ 18.929315] Yenta: Routing CardBus interrupts to PCI
[ 18.929378] Yenta TI: socket 0000:02:04.1, mfunc 0x01111d22, devctl 0x64
[ 19.040046] AC'97 0 analog subsections not ready
[ 19.160837] Yenta: ISA IRQ mask 0x0cf8, PCI irq 18
[ 19.160905] Socket status: 30000006
[ 19.160964] Yenta: Raising subordinate bus# of parent bus (#02) from #06 to #0a
[ 19.161049] pcmcia: parent PCI bridge I/O window: 0x3000 - 0x7fff
[ 19.161112] cs: IO port probe 0x3000-0x7fff: clean.
[ 19.163374] pcmcia: parent PCI bridge Memory window: 0xe0100000 - 0xe17fffff
[ 19.167446] input: PC Speaker as /class/input/input5
[ 19.593260] b43legacy-phy0: Broadcom 4301 WLAN found
[ 19.608229] intel8x0_measure_ac97_clock: measured 55519 usecs
[ 19.608299] intel8x0: clocking to 47447
[ 19.618540] b43legacy-phy0 debug: Found PHY: Analog 0, Type 1, Revision 4
[ 19.618569] b43legacy-phy0 debug: Found Radio: Manuf 0x17F, Version 0x2050, Revision 2
[ 19.640059] b43legacy-phy0 debug: Radio initialized
[ 19.640936] phy0: Selected rate control algorithm 'pid'
[ 19.825196] input: PS/2 Mouse as /class/input/input6
[ 19.868549] input: AlpsPS/2 ALPS GlidePoint as /class/input/input7
[ 20.006422] parport_pc 00:0b: reported by Plug and Play ACPI
[ 20.006547] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 20.487308] Broadcom 43xx-legacy driver loaded [ Features: PLRID, Firmware-ID: FW10 ]
[ 20.830553] cs: IO port probe 0x100-0x3af: clean.
[ 20.832563] cs: IO port probe 0x3e0-0x4ff: clean.
[ 20.833480] cs: IO port probe 0x820-0x8ff: clean.
[ 20.834256] cs: IO port probe 0xc00-0xcf7: clean.
[ 20.835257] cs: IO port probe 0xa00-0xaff: clean.
[ 20.967354] cs: IO port probe 0x100-0x3af: clean.
[ 20.969368] cs: IO port probe 0x3e0-0x4ff: clean.
[ 20.970283] cs: IO port probe 0x820-0x8ff: clean.
[ 20.971062] cs: IO port probe 0xc00-0xcf7: clean.
[ 20.972077] cs: IO port probe 0xa00-0xaff: clean.
[ 22.752064] floppy0: no floppy controllers found
[ 23.380618] Adding 979924k swap on /dev/hda6. Priority:-1 extents:1 across:979924k
[ 24.448490] loop: module loaded
[ 28.540926] input: b43legacy-phy0 as /class/input/input8
[ 28.604124] firmware: requesting b43legacy/ucode2.fw
[ 28.728786] firmware: requesting b43legacy/pcm4.fw
[ 28.758113] firmware: requesting b43legacy/b0g0initvals2.fw
[ 28.876056] b43legacy-phy0: Loading firmware version 0x127, patch level 14 (2005-04-18 02:36:27)
[ 28.976761] b43legacy-phy0 debug: Chip initialized
[ 28.977184] b43legacy-phy0 debug: 30-bit DMA initialized
[ 28.977329] Registered led device: b43legacy-phy0:tx
[ 28.977424] Registered led device: b43legacy-phy0:rx
[ 28.977517] Registered led device: b43legacy-phy0:radio
[ 28.977617] b43legacy-phy0 debug: Wireless interface started
[ 28.977625] b43legacy-phy0 debug: Adding Interface type 2
[ 29.552044] b43legacy-phy0: Radio hardware status changed to DISABLED
[ 31.232175] wlan0: Initial auth_alg=0
[ 31.232187] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 31.432040] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 31.632042] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 31.832048] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 42.160064] wlan0: Initial auth_alg=0
[ 42.160075] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 42.160183] wlan0: Initial auth_alg=0
[ 42.160191] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 42.360038] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 42.560038] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 42.760038] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 53.088074] wlan0: Initial auth_alg=0
[ 53.088086] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 53.088217] wlan0: Initial auth_alg=0
[ 53.088226] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 53.288054] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 53.488048] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 53.688051] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 55.553162] powernow-k8: Found 1 AMD Athlon(tm) XP Processor 3000+ processors (1 cpu cores) (version 2.20.00)
[ 55.553162] powernow-k8: 0 : fid 0x8 (1600 MHz), vid 0x6
[ 55.553162] powernow-k8: 1 : fid 0x0 (800 MHz), vid 0x18
[ 55.864034] Clocksource tsc unstable (delta = 304988360 ns)
[ 63.388094] wlan0: Initial auth_alg=0
[ 63.388112] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 63.388589] wlan0: Initial auth_alg=0
[ 63.388601] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 63.588049] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 63.629567] eth0: link down
[ 63.788046] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 63.988065] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 65.689858] Bluetooth: Core ver 2.11
[ 65.692009] NET: Registered protocol family 31
[ 65.692009] Bluetooth: HCI device and connection manager initialized
[ 65.692009] Bluetooth: HCI socket layer initialized
[ 65.806624] Bluetooth: L2CAP ver 2.9
[ 65.806694] Bluetooth: L2CAP socket layer initialized
[ 65.865889] Bluetooth: RFCOMM socket layer initialized
[ 65.865977] Bluetooth: RFCOMM TTY layer initialized
[ 65.866038] Bluetooth: RFCOMM ver 1.8
[ 71.253414] nvidia: module license 'NVIDIA' taints kernel.
[ 71.510706] ACPI: PCI Interrupt Link [LNK5] enabled at IRQ 16
[ 71.510727] ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNK5] -> GSI 16 (level, low) -> IRQ 16
[ 71.511198] NVRM: loading NVIDIA Linux x86 Kernel Module 96.43.07 Wed Jul 2 12:17:43 PDT 2008
[ 71.625501] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[ 71.625538] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[ 71.625615] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[ 74.320082] wlan0: Initial auth_alg=0
[ 74.320099] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 74.320547] wlan0: Initial auth_alg=0
[ 74.320559] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 74.520047] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 74.720054] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 74.920056] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 85.248072] wlan0: Initial auth_alg=0
[ 85.248089] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 85.248535] wlan0: Initial auth_alg=0
[ 85.248547] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 85.448048] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 85.648048] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 85.848052] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 96.176209] wlan0: Initial auth_alg=0
[ 96.176227] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 96.177411] wlan0: Initial auth_alg=0
[ 96.177427] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 96.376079] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 96.576053] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 96.776375] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 107.104077] wlan0: Initial auth_alg=0
[ 107.104089] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 107.104832] wlan0: Initial auth_alg=0
[ 107.104841] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 107.304044] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 107.504043] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 107.704042] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 116.858962] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 118.032060] wlan0: Initial auth_alg=0
[ 118.032070] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 118.032398] wlan0: Initial auth_alg=0
[ 118.032405] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 118.232041] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 118.432039] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 118.632034] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 128.960144] wlan0: Initial auth_alg=0
[ 128.960162] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 128.961400] wlan0: Initial auth_alg=0
[ 128.961416] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 129.160109] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 129.360054] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 129.560050] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 139.888104] wlan0: Initial auth_alg=0
[ 139.888121] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 139.889257] wlan0: Initial auth_alg=0
[ 139.889273] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 140.088097] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 140.288050] wlan0: authenticate with AP c6:2a:cb:71:23:0c
[ 140.488048] wlan0: authentication with AP c6:2a:cb:71:23:0c timed out
[ 145.260740] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 145.317709] b43legacy-phy0 debug: Removing Interface type 2
[ 145.325296] b43legacy-phy0 debug: Wireless interface stopped
[ 145.325388] b43legacy-phy0 debug: DMA-30 0x0260 (RX) max used slots: 1/64
[ 145.325428] b43legacy-phy0 debug: DMA-30 0x0200 (RX) max used slots: 4/64
[ 145.325472] b43legacy-phy0 debug: DMA-30 0x02A0 (TX) max used slots: 0/128
[ 145.332041] b43legacy-phy0 debug: DMA-30 0x0280 (TX) max used slots: 0/128
[ 145.340041] b43legacy-phy0 debug: DMA-30 0x0260 (TX) max used slots: 0/128
[ 145.348032] b43legacy-phy0 debug: DMA-30 0x0240 (TX) max used slots: 0/128
[ 145.356255] b43legacy-phy0 debug: DMA-30 0x0220 (TX) max used slots: 4/128
[ 145.364036] b43legacy-phy0 debug: DMA-30 0x0200 (TX) max used slots: 0/128
[ 145.372047] b43legacy-phy0 debug: Radio initialized
[ 145.372061] b43legacy-phy0 debug: Radio initialized
[ 169.020945] NET: Registered protocol family 10
[ 169.021586] lo: Disabled Privacy Extensions
dans les logs de demarrage ma carte est BCM 4301 ???
et dans lspci
00:00.0 Host bridge: nVidia Corporation nForce3 Host Bridge (rev a4)
00:01.0 ISA bridge: nVidia Corporation nForce3 LPC Bridge (rev a6)
00:01.1 SMBus: nVidia Corporation nForce3 SMBus (rev a4)
00:02.0 USB Controller: nVidia Corporation nForce3 USB 1.1 (rev a5)
00:02.1 USB Controller: nVidia Corporation nForce3 USB 1.1 (rev a5)
00:02.2 USB Controller: nVidia Corporation nForce3 USB 2.0 (rev a2)
00:06.0 Multimedia audio controller: nVidia Corporation nForce3 Audio (rev a2)
00:06.1 Modem: nVidia Corporation nForce3 Audio (rev a2)
00:08.0 IDE interface: nVidia Corporation nForce3 IDE (rev a5)
00:0a.0 PCI bridge: nVidia Corporation nForce3 PCI Bridge (rev a2)
00:0b.0 PCI bridge: nVidia Corporation nForce3 AGP Bridge (rev a4)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 440 Go 64M] (rev a3)
02:00.0 FireWire (IEEE 1394): Texas Instruments TSB43AB21 IEEE-1394a-2000 Controller (PHY/Link)
02:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
02:02.0 Network controller: Broadcom Corporation BCM4303 802.11b Wireless LAN Controller (rev 02)
02:04.0 CardBus bridge: Texas Instruments PCI1620 PC Card Controller (rev 01)
02:04.1 CardBus bridge: Texas Instruments PCI1620 PC Card Controller (rev 01)
02:04.2 System peripheral: Texas Instruments PCI1620 Firmware Loading Function (rev 01)
quel est le probleme docteur ?
