Trouvé dans /etc/laptop-mode/laptop-mode.conf
[code]###############################################################################
Auto-hibernation settings
Using these settings, you can make laptop mode tools automatically put your
computer into hibernation when the battery level goes critically low.
This feature only works on ACPI, and only works on computers whose batteries
give off battery events often enough.
Should laptop mode tools perform auto-hibernation?
ENABLE_AUTO_HIBERNATION=0
The hibernation command that is to be executed when auto-hibernation
is triggered.
HIBERNATE_COMMAND=/usr/sbin/hibernate
Auto-hibernation battery level threshold, in percentage of the battery’s
total capacity.
AUTO_HIBERNATION_BATTERY_CHARGE_PERCENT=2
Enable this to auto-hibernate if the battery reports that its level is
“critical”.
AUTO_HIBERNATION_ON_CRITICAL_BATTERY_LEVEL=1
