Impossible de me connecter, il semble qu’il y ait un souci avec la rétention du mot de passe.
J’obtiens le message:
The VPN Connection failed
Voici le Syslog:
[size=85]Jul 11 11:20:08 horgh pptp[7275]: nm-pptp-service-6042 warn[open_inetsock:pptp_callmgr.c:329]: connect: Connection timed out
Jul 11 11:20:08 horgh pptp[7275]: nm-pptp-service-6042 fatal[callmgr_main:pptp_callmgr.c:127]: Could not open control connection to 94.75.220.32
Jul 11 11:20:08 horgh pptp[6047]: nm-pptp-service-6042 fatal[open_callmgr:pptp.c:487]: Call manager exited with error 256
Jul 11 11:20:21 horgh NetworkManager: Starting VPN service ‘org.freedesktop.NetworkManager.pptp’…
Jul 11 11:20:21 horgh NetworkManager: VPN service ‘org.freedesktop.NetworkManager.pptp’ started (org.freedesktop.NetworkManager.pptp), PID 7288
Jul 11 11:20:21 horgh NetworkManager: VPN service ‘org.freedesktop.NetworkManager.pptp’ just appeared, activating connections
Jul 11 11:20:21 horgh NetworkManager: VPN plugin state changed: 1
Jul 11 11:20:21 horgh NetworkManager: VPN plugin state changed: 3
Jul 11 11:20:21 horgh NetworkManager: VPN connection ‘its hidden’ (Connect) reply received.
Jul 11 11:20:21 horgh pppd[7290]: Plugin /usr/lib/pppd/2.4.4/nm-pptp-pppd-plugin.so loaded.
Jul 11 11:20:21 horgh pppd[7290]: pppd 2.4.4 started by root, uid 0
Jul 11 11:20:21 horgh pppd[7290]: Using interface ppp0
Jul 11 11:20:21 horgh pppd[7290]: Connect: ppp0 <–> /dev/pts/3
Jul 11 11:20:21 horgh modem-manager: (net/ppp0): could not get port’s parent device
Jul 11 11:20:21 horgh NetworkManager: SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/ppp0, iface: ppp0)
Jul 11 11:20:21 horgh NetworkManager: SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/ppp0, iface: ppp0): no ifupdown configuration found.
Jul 11 11:20:22 horgh pptp[7294]: nm-pptp-service-7288 log[main:pptp.c:314]: The synchronous pptp option is NOT activated
Jul 11 11:20:25 horgh pptp[7302]: nm-pptp-service-7288 log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request’
Jul 11 11:20:52 horgh pppd[7290]: LCP: timeout sending Config-Requests
Jul 11 11:20:52 horgh pppd[7290]: Connection terminated.
Jul 11 11:20:52 horgh NetworkManager: VPN plugin failed: 1
Jul 11 11:20:52 horgh NetworkManager: SCPlugin-Ifupdown: devices removed (path: /sys/devices/virtual/net/ppp0, iface: ppp0)
Jul 11 11:20:52 horgh pppd[7290]: Modem hangup
Jul 11 11:20:57 horgh pppd[7290]: Exit.
Jul 11 11:20:57 horgh NetworkManager: VPN plugin failed: 1
Jul 11 11:20:57 horgh NetworkManager: VPN plugin state changed: 6
Jul 11 11:20:57 horgh NetworkManager: VPN plugin state change reason: 0
Jul 11 11:20:57 horgh NetworkManager: connection_state_changed(): Could not process the request because no VPN connection was active.
Jul 11 11:20:57 horgh NetworkManager: Policy set ‘Auto dlink’ (wlan0) as default for routing and DNS.
Jul 11 11:21:10 horgh NetworkManager: [1278840070.002929] ensure_killed(): waiting for vpn service pid 7288 to exit
Jul 11 11:21:10 horgh NetworkManager: [1278840070.003108] ensure_killed(): vpn service pid 7288 cleaned up[/size]
