hello:
j’essaye de me peaufiner un fichier de config pour conky seulement il me manque l’essentiel.
la temp de la carte mère et du cpu et si c est possible de la carte graphique
voila ce que j’ai dejà:
# set to yes if you want Conky to be forked in the background
background no
cpu_avg_samples 2
net_avg_samples 2
out_to_console no
# X font when Xft is disabled, you can pick one with program xfontsel
#font 7x12
#font 6x10
#font 7x13
#font 8x13
#font 7x12
#font *mintsmild.se*
#font -*-*-*-*-*-*-34-*-*-*-*-*-*-*
#font -artwiz-snap-normal-r-normal-*-*-100-*-*-p-*-iso8859-1
# Use Xft?
use_xft yes
# Xft font when Xft is enabled
xftfont Bitstream Vera Sans Mono:size=8
own_window_transparent no
own_window_colour hotpink
# Text alpha when using Xft
xftalpha 0.8
# on_bottom yes
# mail spool
# mail_spool $MAIL
# Update interval in seconds
update_interval 1
# Create own window instead of using desktop (required in nautilus)
own_window no
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer no
# Minimum size of text area
#minimum_size 280 5
#maximum_width 150
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders no
# Stippled borders?
stippled_borders 10
# border margins
border_margin 4
# border width
border_width 1
# Default colors and also border colors
default_color white
default_shade_color white
default_outline_color white
# Text alignment, other possible values are commented
#alignment top_left
#minimum_size 10 10
gap_x 13
gap_y 13
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
# Add spaces to keep things from moving about? This only affects certain objects.
use_spacer no
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# boinc (seti) dir
# seti_dir /opt/seti
# Possible variables to be used:
# Variable Arguments Description
# acpiacadapter ACPI ac adapter state.
# acpifan ACPI fan state
# acpitemp ACPI temperature.
# adt746xcpu CPU temperature from therm_adt746x
# adt746xfan Fan speed from therm_adt746x
# battery (num) Remaining capasity in ACPI or APM
# battery. ACPI battery number can be
# given as argument (default is BAT0).
# buffers Amount of memory buffered
# cached Amount of memory cached
# color (color) Change drawing color to color
# cpu CPU usage in percents
# cpubar (height) Bar that shows CPU usage, height is
# bar's height in pixels
# downspeed net Download speed in kilobytes
# downspeedf net Download speed in kilobytes with one
# decimal
# exec shell command Executes a shell command and displays
# the output in torsmo. warning: this
# takes a lot more resources than other
# variables. I'd recommend coding wanted
# behaviour in C and posting a patch :-).
# execi interval, shell Same as exec but with specific interval.
# command Interval can't be less than
# update_interval in configuration.
# fs_bar (height), (fs) Bar that shows how much space is used on
# a file system. height is the height in
# pixels. fs is any file on that file
# system.
# fs_free (fs) Free space on a file system available
# for users.
# fs_free_perc (fs) Free percentage of space on a file
# system available for users.
# fs_size (fs) File system size
# fs_used (fs) File system used space
# hr (height) Horizontal line, height is the height in
# pixels
# i2c (dev), type, n I2C sensor from sysfs (Linux 2.6). dev
i2c
# may be omitted if you have only one I2C
# device. type is either in (or vol)
# meaning voltage, fan meaning fan or temp
# meaning temperature. n is number of the
# sensor. See /sys/bus/i2c/devices/ on
# your local computer.
# kernel Kernel version
# loadavg (1), (2), (3) System load average, 1 is for past 1
# minute, 2 for past 5 minutes and 3 for
# past 15 minutes.
# machine Machine, i686 for example
# mails Mail count in mail spool. You can use
# program like fetchmail to get mails from
# some server using your favourite
# protocol. See also new_mails.
# mem Amount of memory in use
# membar (height) Bar that shows amount of memory in use
# memmax Total amount of memory
# memperc Percentage of memory in use
# new_mails Unread mail count in mail spool.
# nodename Hostname
# outlinecolor (color) Change outline color
# pre_exec shell command Executes a shell command one time before
# torsmo displays anything and puts output
# as text.
# processes Total processes (sleeping and running)
# running_processes Running processes (not sleeping),
# requires Linux 2.6
# shadecolor (color) Change shading color
# stippled_hr (space), Stippled (dashed) horizontal line
# (height)
# swapbar (height) Bar that shows amount of swap in use
# swap Amount of swap in use
# swapmax Total amount of swap
# swapperc Percentage of swap in use
# sysname System name, Linux for example
# time (format) Local time, see man strftime to get more
# information about format
# totaldown net Total download, overflows at 4 GB on
# Linux with 32-bit arch and there doesn't
# seem to be a way to know how many times
# it has already done that before torsmo
# has started.
# totalup net Total upload, this one too, may overflow
# updates Number of updates (for debugging)
# upspeed net Upload speed in kilobytes
# upspeedf net Upload speed in kilobytes with one
# decimal
# uptime Uptime
# uptime_short Uptime in a shorter format
# seti_prog Seti@home current progress
# seti_progbar (height) Seti@home current progress bar
# seti_credit Seti@hoome total user credit
# variable is given either in format $variable or in ${variable}. Latter
# allows characters right after the variable and must be used in network
# stuff because of an argument
#${font Dungeon:style=Bold:pixelsize=10}I can change the font as well
#${font Verdana:size=10}as many times as I choose
#${font Perry:size=10}Including UTF-8,
#${font Luxi Mono:size=10}justo como este texto que o google traduz fêz o português
# stuff after 'TEXT' will be formatted on screen
#${font Grunge:size=12}${time %a %b %d}${alignr -25}${time %k:%M}
TEXT
$nodename - $sysname $kernel on $machine
$stippled_hr
${color lightgrey}Uptime:$color $uptime ${color lightgrey}- Load:$color $loadavg
${color lightgrey}CPU Usage:${color #5000a0} ${cpu}% ${cpubar}
${color black}${cpugraph 000000 5000a0}
${color lightgrey}RAM Usage:$color $mem/$memmax - $memperc% $membar
${color lightgrey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar}
${color lightgrey}Processes:$color $processes ${color grey}Running:$color $running_processes
$color$stippled_hr
${color lightgrey}Networking:
Down:${color #8844ee} ${downspeed eth0} k/s${color lightgrey} ${offset 70}Up:${color #22ccff} ${upspeed eth0} k/s
${color black}${downspeedgraph eth0 32,150 ff0000 0000ff} $alignr${color black}${upspeedgraph eth0 32,150 0000ff ff0000}
${color lightgrey}File systems:
/ $color${fs_used /}/${fs_size /} ${fs_bar /}
${color lightgrey}Temperatures:
CPU:$color ${i2c temp 2}C${color grey} - MB:$color ${i2c temp 1}C
${color}Name PID CPU% MEM%
${color #ddaa00} ${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${color lightgrey} ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${color lightgrey} ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${color}Mem usage
${color #ddaa00} ${top_mem name 1} ${top_mem pid 1} ${top_mem cpu 1} ${top_mem mem 1}
${color lightgrey} ${top_mem name 2} ${top_mem pid 2} ${top_mem cpu 2} ${top_mem mem 2}
${color lightgrey} ${top_mem name 3} ${top_mem pid 3} ${top_mem cpu 3} ${top_mem mem 3}
${color #5b6dad}Monitors CPU FAN1 FAN2
${color #7f8ed3} ${i8k_cpu_temp}C ${i8k_left_fan_status} ${i8k_right_fan_status}
${color #5b6dad}MPD: ${color #7f8ed3}${alignc}$mpd_artist - $mpd_title
${color #7f8ed3}$mpd_bar
${color #7f8ed3}${alignc}$mpd_status
le souci c est que j’utilise pour la température.
lm-sensors
sensors
it8718-isa-0290
Adapter: ISA adapter
in0: +1.14 V (min = +0.00 V, max = +4.08 V)
in1: +3.26 V (min = +0.00 V, max = +4.08 V)
in2: +0.00 V (min = +0.00 V, max = +4.08 V) ALARM
in3: +3.09 V (min = +0.00 V, max = +4.08 V)
in4: +3.01 V (min = +0.00 V, max = +4.08 V)
in5: +0.00 V (min = +0.00 V, max = +4.08 V) ALARM
in6: +1.02 V (min = +0.00 V, max = +4.08 V)
in7: +2.96 V (min = +0.00 V, max = +4.08 V)
in8: +2.99 V
fan1: 0 RPM (min = 3245 RPM) ALARM
fan2: 0 RPM (min = 3245 RPM) ALARM
fan3: 0 RPM (min = 0 RPM)
temp1: +61.0°C (low = -1.0°C, high = +127.0°C) sensor = thermal diode
temp2: +55.0°C (low = -1.0°C, high = +127.0°C) sensor = transistor
temp3: -55.0°C (low = -1.0°C, high = +127.0°C) sensor = transistor
cpu0_vid: +2.050 V
pour les lien que j’ai trouver:
blog.arofarn.info/linux/scripts- … iguration/
donc j’ai fait un:
ls -la /sys/bus/i2c/devices
total 0
drwxr-xr-x 2 root root 0 jun 23 12:29 .
drwxr-xr-x 4 root root 0 jun 23 12:29 ..
et pour le gpu je ne connait pas la syntaxe:(
nvclock -i
-- General info --
Card: nVidia Geforce 8800GTX
Architecture: NV50/G80 A2
PCI id: 0x191
GPU clock: 576.000 MHz
Bustype: PCI-Express
-- Shader info --
Clock: 1350.000 MHz
Stream units: 128 (11111111b)
ROP units: 24 (111111b)
-- Memory info --
Amount: 768 MB
Type: 384 bit DDR3
Clock: 899.996 MHz
-- PCI-Express info --
Current Rate: 16X
Maximum rate: 16X
-- Sensor info --
Sensor: Analog Devices ADT7473
Board temperature: 67C
GPU temperature: 72C
Fanspeed: 82 RPM
Fanspeed mode: manual
PWM duty cycle: 61.2%
-- VideoBios information --
Version: 60.80.08.00.44
Signon message: ASUS EN8800GTX VGA BIOS Version 60.80.08.00.43.AS05
VID mask: 3
Voltage level 0: 1.10V, VID: 0
Voltage level 1: 1.20V, VID: 1
Voltage level 2: 1.30V, VID: 2
et pour ce qui est du dd je suis obliger de passer en root pour pouvoire l’afficher, donc il pourrait y avoir un problème de droit :
/usr/sbin/hddtemp /dev/sda -D
================= hddtemp 0.3-beta15 ==================
Modèle: Hitachi HDT725032VLA360
field(1) = 0
field(2) = 0
field(3) = 68
field(4) = 110
field(5) = 0
field(7) = 0
field(8) = 0
field(9) = 70
field(10) = 0
field(12) = 110
field(192) = 142
field(193) = 142
field(194) = 52
field(196) = 0
field(197) = 0
field(198) = 0
field(199) = 0
If one of the field value seems to match the temperature, be sure to read
the hddtemp man page before sending a report (section REPORT). Thanks.
sinon les group de 'utilisateur
groupes=20(dialout),21(fax),22(voice),24(cdrom),25(floppy),26(tape),29(audio),44(video),46(plugdev),60(games),111(scanner),116(vboxusers)
ce qui m’intéresse donc c est surtout l’affichage de la température sur le fond du bureau du cpu,gpu,cm,hdd car il fait 27C° et je tape déjà vert les 68C° pour le cpu !
Merci d’avance
je veux le même !
Par exemple :
