Avec conky, j’ai souvent du texte qui se superpose (par exemple pour les processus en cours ou pour les pourcentages). Je joins une capture pour bien voir le problème.
Je crois pourtant avoir tout bien réglé dans le .conkyrc (double buffer, …)
[code]alignment bottom_right
background no
border_width 1
cpu_avg_samples 2
default_color white
default_outline_color white
default_shade_color 111
double_buffer yes
draw_borders no
draw_graph_borders yes
draw_outline no
draw_shades yes
use_xft yes
xftfont DejaVu Sans Mono:size=12
gap_x 20
gap_y 60
minimum_size 360 5
net_avg_samples 2
no_buffers yes
out_to_console no
out_to_stderr no
extra_newline no
own_window yes
own_window_class Conky
own_window_type desktop
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_transparent yes
own_window_argb_visual yes
own_window_argb_value 100
stippled_borders 0
update_interval 1.0
uppercase no
use_spacer none
show_graph_scale no
show_graph_range no
hddtemp_host 127.0.0.1
hddtemp_port 7634
mpd_host 192.168.0.10
mpd_port 6600
TEXT
$alignc$color ${time %a %d %h %Y %H:%M}
$if_mpd_playing
$hr
${scroll 36 5 $color${mpd_artist} ${color grey}-$color ${mpd_title} ${color grey}(${mpd_elapsed}/${mpd_length})}
$endif
$hr
${color grey}Battery:$color $battery_time - $battery_percent% $battery_bar
${color grey}Uptime:$color $uptime_short $alignr$loadavg
${color grey}Temp:$color ${execi 10 sensors | grep -n ‘Physical id 0’ | awk -F’+’ ‘{print $2}’ | awk -F’ ’ ‘{print $1}’} | ${execi 10 sensors | grep -n ‘Core 0’ | awk -F’+’ ‘{print $2}’ | awk -F’ ’ ‘{print $1}’} | ${execi 10 sensors | grep -n ‘Core 1’ | awk -F’+’ ‘{print $2}’ | awk -F’ ’ ‘{print $1}’}
${color grey}Frequency:$color ${freq_g}GHz
${color grey}RAM Usage:$color $mem/$memmax - $memperc% ${membar 4}
${color grey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar 4}
${color grey}CPU Usage:$color $cpu% ${cpubar 4}
${font DejaVu Sans Mono:size=11}
${color ddd}${top name 1} $alignr(${top pid 1}) ${top cpu 1}%
${color ddd}${top name 2} $alignr(${top pid 2}) ${top cpu 2}%
${color ddd}${top name 3} $alignr(${top pid 3}) ${top cpu 3}%
${font DejaVu Sans Mono:size=12}
${color grey}Processes:$color $processes $alignr${color grey}Running:$color $running_processes
${color grey}Entropy:$color $entropy_avail ${entropy_bar 4}
$hr
${color 999}File systems:
${color grey}/ $color${fs_used /}/${fs_size /} ${fs_bar 6 /}
${color grey}/home $color${fs_used /home}/${fs_size /home} ${fs_bar 6 /home}
${voffset -8}
${color 999}/dev/sda:
${color grey}Disk IO: ${diskiograph /dev/sda 17}
${font DejaVu Sans Mono:size=10}${color grey}R: $color${diskio_read /dev/sda} $alignr ${color grey}W: $color${diskio_write /dev/sda}
${color ddd}${top_io name 1} $alignr(${top_io pid 1}) ${top_io io_perc 1}%
${color ddd}${top_io name 2} $alignr(${top_io pid 2}) ${top_io io_perc 2}%
${color ddd}${top_io name 3} $alignr(${top_io pid 3}) ${top_io io_perc 3}%
${if_up wlan0}
${voffset -8}
${color 999}Networking: $color$alignr${wireless_essid wlan0}
${color grey}Link quality: $color${wireless_link_qual_perc wlan0}% ${wireless_link_bar 4 wlan0}
${color grey}Total down/up: $color${totaldown wlan0}/${totalup wlan0}
${color grey}Up: ${upspeedgraph wlan0 17,110} Down: ${downspeedgraph wlan0 17,110}
${font DejaVu Sans Mono:size=10}$color${upspeed wlan0} $alignr ${downspeed wlan0}
$endif
$hr
${color grey}$alignc${execi 3600 xfce4-about --version | head -1 | sed ‘s/xfce4-about/Xfce/’}
${color grey}$alignc$sysname $kernel
