connaître le chipset de sa carte wifi
Bonjour, j’ai pas mal cherché mais je ne trouve pas quel est le chipset de ma carte Atheros :
[code]lspci -vvv
02:00.0 Network controller: Atheros Communications Inc. Device 002b (rev 01)
Subsystem: Device 1a3b:1089
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 17
Region 0: Memory at feaf0000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Address: 00000000 Data: 0000
Capabilities: [60] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <64us
ClockPM- Suprise- LLActRep- BwNot-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [100] Advanced Error Reporting <?>
Capabilities: [140] Virtual Channel <?>
Capabilities: [160] Device Serial Number 12-14-24-ff-ff-17-15-00
Capabilities: [170] Power Budgeting <?>
Kernel driver in use: ath9k
Kernel modules: ath9k
Si quelqu’un a la même et s’est déjà posé la question.
Device 1a3b:1089 ne mentionne pas le chipset il me semble ?
la carte fonctionnant nickel avec ath9k cela veut-il dire sans coup férir que le chipset est atheros ?
[code]About Atheros Communications, Inc.
Atheros Communications is the leading developer of networking technologies for secure, high-performance wireless local area networks. As the industry innovator and market-share leader in multi-mode wireless solutions compliant with the IEEE 802.11 specifications, Atheros is driving transparent connections among electronic devices in the office, home and on the road. Atheros technology is being used by many of the world’s leading wireless equipment manufacturers including 3Com, Accton, Actiontec, Acrowave Systems, AIRAYA, Airespace, AirVast Technology, ALPS, Ambit, Aruba Wireless Networks, Askey, ASUS, Avaya, BenQ, Chantry Networks, Contec, CyberTAN, Dacom, Delta Networks, D-Link, Gemtek, Gigabyte Technology, Global Sun Tech, HP, IBM, ICOM, Intel, Intermec, I-O Data, Linksys, NEC, NETGEAR, Nortel, Philips, Proxim, Samsung, Senao, SMC Networks, Sony, Symbol Technologies, TDK, TECOM, Toshiba, Trapeze Networks, USI, W2 Networks, Wistron NeWeb, Z-Com and others. For more information, visit www.atheros.com or send email to info@atheros.com.[/code]
Mon anglais étant ce qu’il est, je crois comprendre qu’Atheros EST le chipset utilisé chez ces fabricants de cartes.
lspci renverrait donc le chipset et non le nom de la carte ?
Ben oui!
