Je ne peux plus me connecter en wifi.
Un coup de main SVP. Merci.
Compte rendu de wificheck:
>> cat /etc/lsb-release
>> lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 13d3:3304 IMC Networks
Bus 001 Device 004: ID 064e:d213 Suyin Corp.
Bus 001 Device 005: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 004 Device 003: ID 046d:c52f Logitech, Inc. Wireless Mouse M305
>> lspci -k -nn | grep -A 3 -i net
03:00.0 Network controller [0280]: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
Subsystem: AzureWave AW-NB037H 802.11bgn Wireless Half-size Mini PCIe Card [AR9002WB-1NGCD] [1a3b:2c37]
Kernel driver in use: ath9k
04:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller [1b21:1042]
05:00.0 Ethernet controller [0200]: Atheros Communications Inc. AR8151 v2.0 Gigabit Ethernet [1969:1083] (rev c0)
Subsystem: ASUSTeK Computer Inc. Device [1043:1851]
Kernel driver in use: atl1c
>> sudo lshw -C network
>> lsmod
Module Size Used by
nls_utf8 12456 1
nls_cp437 16553 1
vfat 17270 1
fat 45864 1 vfat
parport_pc 22422 0
ppdev 12763 0
lp 17160 0
parport 35954 3 lp,ppdev,parport_pc
bnep 17568 2
rfcomm 33549 0
binfmt_misc 12914 1
uinput 17434 0
nfsd 212377 2
nfs 312923 0
nfs_acl 12511 2 nfs,nfsd
auth_rpcgss 37129 2 nfs,nfsd
fscache 36638 1 nfs
lockd 67358 2 nfs,nfsd
sunrpc 173441 6 lockd,auth_rpcgss,nfs_acl,nfs,nfsd
loop 22718 0
uvcvideo 57785 0
videodev 79317 1 uvcvideo
media 18148 2 videodev,uvcvideo
i915 374609 3
arc4 12458 2
joydev 17237 0
ath3k 12671 0
btusb 17508 0
bluetooth 119202 12 btusb,ath3k,rfcomm,bnep
ath9k 64516 0
nouveau 570511 0
ath9k_common 12728 1 ath9k
ath9k_hw 334421 2 ath9k_common,ath9k
ttm 57809 1 nouveau
snd_hda_codec_realtek 197100 1
drm_kms_helper 27281 2 nouveau,i915
ath 21370 3 ath9k_hw,ath9k_common,ath9k
drm 187778 6 drm_kms_helper,ttm,nouveau,i915
mac80211 193035 1 ath9k
snd_hda_intel 26220 4
snd_hda_codec 78148 2 snd_hda_intel,snd_hda_codec_realtek
snd_hwdep 13189 1 snd_hda_codec
snd_pcm 68049 2 snd_hda_codec,snd_hda_intel
iTCO_wdt 17091 0
asus_nb_wmi 12436 0
cfg80211 137387 3 mac80211,ath,ath9k
i2c_algo_bit 12834 2 nouveau,i915
snd_page_alloc 13003 2 snd_pcm,snd_hda_intel
coretemp 12854 0
iTCO_vendor_support 12704 1 iTCO_wdt
acpi_cpufreq 12935 1
mperf 12453 1 acpi_cpufreq
asus_wmi 18677 1 asus_nb_wmi
i2c_i801 16972 0
processor 28161 1 acpi_cpufreq
crc32c_intel 12747 0
psmouse 69263 0
snd_seq 45282 0
pcspkr 12616 0
i2c_core 23922 7 i2c_i801,i2c_algo_bit,drm,drm_kms_helper,nouveau,i915,videodev
sparse_keymap 12760 1 asus_wmi
serio_raw 12891 0
evdev 17532 21
rfkill 19011 6 asus_wmi,cfg80211,bluetooth
snd_seq_device 13176 1 snd_seq
mxm_wmi 12515 1 nouveau
ac 12624 0
battery 13146 0
cryptd 14560 0
video 17682 2 nouveau,i915
button 12937 2 nouveau,i915
snd_timer 22919 2 snd_seq,snd_pcm
wmi 13243 3 mxm_wmi,asus_wmi,nouveau
snd 52811 16 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek
soundcore 13070 1 snd
power_supply 13475 3 battery,ac,nouveau
ext4 363319 1
crc16 12343 2 ext4,bluetooth
jbd2 66775 1 ext4
mbcache 13082 1 ext4
usbhid 36442 0
hid 81334 1 usbhid
usb_storage 43892 1
sg 25877 0
sr_mod 21899 0
sd_mod 36156 5
cdrom 35266 1 sr_mod
crc_t10dif 12348 1 sd_mod
ahci 29136 2
libahci 22916 1 ahci
libata 140776 2 libahci,ahci
scsi_mod 162375 5 libata,sd_mod,sr_mod,sg,usb_storage
atl1c 32228 0
xhci_hcd 73461 0
thermal 17383 0
thermal_sys 18084 3 thermal,video,processor
ehci_hcd 40222 0
usbcore 128651 8 ehci_hcd,xhci_hcd,usb_storage,usbhid,btusb,ath3k,uvcvideo
usb_common 12354 1 usbcore
>> iwconfig
wlan0 IEEE 802.11bgn ESSID:"FreeWifi"
Mode:Managed Frequency:2.462 GHz Access Point: B2:FD:AE:5F:88:7A
Bit Rate=58.5 Mb/s Tx-Power=16 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=59/70 Signal level=-51 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
>> ifconfig -a
eth0 Link encap:Ethernet HWaddr 14:da:e9:a9:2a:08
inet adr:192.168.0.71 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::16da:e9ff:fea9:2a08/64 Scope:Lien
RX packets:128874 errors:0 dropped:0 overruns:0 frame:0
TX packets:91591 errors:0 dropped:0 overruns:0 carrier:1
RX bytes:149035470 (142.1 MiB) TX bytes:11128030 (10.6 MiB)
Interruption:56
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:511 errors:0 dropped:0 overruns:0 frame:0
TX packets:511 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:247276 (241.4 KiB) TX bytes:247276 (241.4 KiB)
wlan0 Link encap:Ethernet HWaddr 74:2f:68:c4:62:5b
adr inet6: fe80::762f:68ff:fec4:625b/64 Scope:Lien
TX packets:584 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:142455 (139.1 KiB)
>> sudo iwlist scan
wlan0 Scan completed :
Cell 01 - Address: B2:FD:AE:5F:88:79
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=56/70 Signal level=-54 dBm
Encryption key:on
ESSID:""
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
18 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=000000777e375b0e
Extra: Last beacon: 308ms ago
IE: Unknown: 0000
IE: Unknown: 010882848B961224486C
IE: Unknown: 03010B
IE: Unknown: 32040C183060
IE: Unknown: 33082001020304050607
IE: Unknown: 33082105060708090A0B
IE: Unknown: 050400010000
IE: Unknown: 2A0104
IE: Unknown: 2D1A6E1017FFFF000001000000000000000000000000000000000000
IE: Unknown: 3D160B000600000000000000000000000000000000000000
IE: Unknown: 7F0101
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
IE: Unknown: 0B05020018127A
IE: Unknown: DD1E00904C336E1017FFFF000001000000000000000000000000000000000000
IE: Unknown: DD1A00904C340B000600000000000000000000000000000000000000
IE: Unknown: DD07000C4300000000
Cell 02 - Address: B2:FD:AE:5F:88:7A
Channel:11
Encryption key:off
ESSID:"FreeWifi"
Mode:Master
Extra:tsf=000000777e376448
Extra: Last beacon: 304ms ago
IE: Unknown: 00084672656557696669
IE: Unknown: 03010B
IE: Unknown: 2A0104
IE: Unknown: 3E0100
IE: Unknown: 7F0101
Cell 03 - Address: B2:FD:AE:5F:88:7B
Channel:11
Encryption key:on
ESSID:"FreeWifi_secure"
Mode:Master
Extra:tsf=000000777e376d11
IE: Unknown: 000F46726565576966695F736563757265
IE: Unknown: 03010B
IE: Unknown: 2A0104
IE: Unknown: 3E0100
IE: WPA Version 1
Group Cipher : CCMP
Authentication Suites (1) : 802.1x
IE: Unknown: 7F0101
Cell 04 - Address: B2:FD:AE:5F:88:78
Channel:11
Encryption key:on
ESSID:"xxxxxx"
Mode:Master
Extra:tsf=000000777e375175
Extra: Last beacon: 312ms ago
IE: Unknown: 00066D6169736F6E
IE: Unknown: 03010B
IE: Unknown: 2A0104
IE: Unknown: 3E0100
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : TKIP CCMP
IE: Unknown: 7F0101
Cell 05 - Address: F4:CA:E5:B7:6F:49
Channel:6
Frequency:2.437 GHz (Channel 6)
Quality=30/70 Signal level=-80 dBm
Encryption key:off
ESSID:"FreeWifi"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 22 Mb/s
6 Mb/s; 9 Mb/s; 12 Mb/s
Bit Rates:18 Mb/s; 24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000001d3794e09b7
Extra: Last beacon: 708ms ago
IE: Unknown: 010882848B962C0C1218
IE: Unknown: 030106
IE: Unknown: 2A0104
IE: Unknown: 3205243048606C
IE: Unknown: 2D1AEC0003FFFFFF0001000000000000000100000000000000000000
IE: Unknown: 3D1606000400000000000000000000000000000000000000
IE: Unknown: 7F080000000000000040
Cell 06 - Address: F4:CA:E5:B7:6F:4A
Channel:6
Encryption key:on
Mode:Master
Extra:tsf=000001d3794d90f9
Extra: Last beacon: 704ms ago
IE: Unknown: 030106
IE: Unknown: 2A0104
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Cell 07 - Address: F4:CA:E5:B7:6F:48
Channel:6
Encryption key:on
ESSID:"Freebox vince"
Mode:Master
Extra:tsf=000001d3794f8160
Extra: Last beacon: 644ms ago
IE: Unknown: 000D46726565626F782076696E6365
IE: Unknown: 030106
IE: Unknown: 2A0104
Group Cipher : CCMP
>> uname -r -m
3.2.0-6-amd64 x86_64
>> cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
>> nm-tool
NetworkManager Tool
State: connected (global)
- Device: eth0 [Wired connection 1] -------------------------------------------
Type: Wired
Driver: atl1c
State: connected
Default: yes
HW Address: 14:DA:E9:A9:2A:08
Capabilities:
Carrier Detect: yes
Speed: 100 Mb/s
Wired Properties
Carrier: on
IPv4 Settings:
Address: 192.168.0.71
Prefix: 24 (255.255.255.0)
Gateway: 192.168.0.254
DNS: 212.27.40.241
DNS: 212.27.40.240
- Device: wlan0 [FreeWifi] ----------------------------------------------------
Type: 802.11 WiFi
Driver: ath9k
State: connecting (getting IP configuration)
Default: no
HW Address: 74:2F:68:C4:62:5B
Capabilities:
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points
FreeWifi_secure: Infra, B2:FD:AE:5F:88:7B, Freq 2462 MHz, Rate 54 Mb/s, Strength 80 WPA Enterprise
FreeWifi_secure: Infra, F4:CA:E5:B7:6F:4A, Freq 2437 MHz, Rate 54 Mb/s, Strength 35 WPA2 Enterprise
FreeWifi: Infra, B2:FD:AE:5F:88:7A, Freq 2462 MHz, Rate 54 Mb/s, Strength 80
xxxxxxx: Infra, B2:FD:AE:5F:88:78, Freq 2462 MHz, Rate 54 Mb/s, Strength 80 WPA
Freebox vince: Infra, F4:CA:E5:B7:6F:48, Freq 2437 MHz, Rate 54 Mb/s, Strength 32 WPA2
FreeWifi: Infra, F4:CA:E5:B7:6F:49, Freq 2437 MHz, Rate 54 Mb/s, Strength 34
>> nmcli dev wifi
SSID BSSID MODE FRÉQ DÉBIT SIGNAL SÉCURITÉ ACTIF
'FreeWifi_secure' B2:FD:AE:5F:88:7B Infrastructure 2462 MHz 54 Mo/s 80 WPA Enterprise non
'FreeWifi_secure' F4:CA:E5:B7:6F:4A Infrastructure 2437 MHz 54 Mo/s 35 WPA2 Enterprise non
'FreeWifi' B2:FD:AE:5F:88:7A Infrastructure 2462 MHz 54 Mo/s 80 -- non
'xxxxxx' B2:FD:AE:5F:88:78 Infrastructure 2462 MHz 54 Mo/s 80 WPA non
'Freebox vince' F4:CA:E5:B7:6F:48 Infrastructure 2437 MHz 54 Mo/s 32 WPA2 non
'FreeWifi' F4:CA:E5:B7:6F:49 Infrastructure 2437 MHz 54 Mo/s 34 -- non
>> nmcli connection list (< 15.04) ou nmcli connection show (>= 15.04)
NOM UUID TYPE TIMESTAMP-REAL
Wired connection 1 f3aa091d-b3a3-4686-a04b-10cfbd9d7b3c 802-3-ethernet lun. 10 sept. 2018 15:22:55 CEST
FreeWifi 37234378-16bb-4b25-9a19-704db94cb421 802-11-wireless mar. 04 sept. 2018 21:07:51 CEST
Auto maison 44e45368-e0d4-48c7-a7fb-18e2c1862768 802-11-wireless mar. 04 sept. 2018 18:45:16 CEST
Freebox vince 6390d2d4-52a6-46f2-827d-62edbddb07cb 802-11-wireless jamais
AndroidAP 9f9e9f4c-8eb0-41c8-b6b9-23b738d78a4d 802-11-wireless sam. 01 sept. 2018 19:46:14 CEST
>> nmcli connection status
NOM UUID PÉRIPHÉRIQUES PAR DÉFAUT VPN MASTER-PATH
Wired connection 1 f3aa091d-b3a3-4686-a04b-10cfbd9d7b3c eth0 oui non non défini
FreeWifi 37234378-16bb-4b25-9a19-704db94cb421 wlan0 non non non défini
>> sudo rfkill list
