voila je tente de me connecté sur mon ssh :
daniel@localhost:~$ sftp -P 666 thorhyeux@localhost
ssh: connect to host localhost port 666: Connection refused
Couldn’t read packet: Connection reset by peer
ensuite je tente de redémarré mon ssh :
root@localhost:/home/daniel# /etc/init.d/ssh restart
/etc/ssh/sshd_config: line 23: Bad configuration option: LogLevel1
/etc/ssh/sshd_config: terminating, 1 bad configuration options
ensuite je tente de démarré mon rssh :
root@localhost:/home/daniel# /etc/init.d/rsyslog restart
[ ok ] Stopping enhanced syslogd: rsyslogd.
[ ok ] Starting enhanced syslogd: rsyslogd.
donc j’en conclue que le problème viens de ssh, je fais nano /etc/ssh/sshd_config :
Package generated configuration file
See the sshd_config(5) manpage for details
What ports, IPs and protocols we listen for
Port 666
Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
Logging
SyslogFacility LOCAL6
LogLevel1 INFO
Authentication:
LoginGraceTime 120
PermitRootLogin no
StrictModes yes
RSAAuthentication yes
#PubkeyAuthentication no
#AuthorizedKeysFile %h/.ssh/authorized_keys
Don’t read the user’s ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
similar for protocol version 2
HostbasedAuthentication no
Uncomment if you don’t trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
Change to yes to enable challenge-response passwords (beware issues with
some PAM modules and threads)
ChallengeResponseAuthentication no
Change to no to disable tunnelled clear text passwords
PasswordAuthentication yes
Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding no
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server -f LOCAL7 -1 INFO
Set this to ‘yes’ to enable PAM authentication, account processing,
and session processing. If this is enabled, PAM authentication will
be allowed through the ChallengeResponseAuthentication and
PasswordAuthentication. Depending on your PAM configuration,
PAM authentication via ChallengeResponseAuthentication may bypass
the setting of “PermitRootLogin without-password”.
If you just want the PAM account and session checks to run without
PAM authentication, then enable this but set PasswordAuthentication
and ChallengeResponseAuthentication to ‘no’.
UsePAM yes
utilisateurs autorisés
AllowUsers thorhyeux
AllowUsers jessie
je regarde la ligne 23, car cette erreur l’indique : ![]()
bref, quelle est cette erreur, que dois-je faire pour la corrigé? ![]()
LogLevel1 INFO
merci
