Un autre, Fin de démarrage = 10"
Connexion après 30"
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000dedfa000 (usable)
[ 0.000000] BIOS-e820: 00000000dedfa000 - 00000000dee54000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000dee54000 - 00000000df357000 (reserved)
[ 0.000000] BIOS-e820: 00000000df357000 - 00000000df35a000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df35a000 - 00000000df5a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000df5a0000 - 00000000df5b1000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df5b1000 - 00000000df5c8000 (reserved)
[ 0.000000] BIOS-e820: 00000000df5c8000 - 00000000df5ca000 (usable)
[ 0.000000] BIOS-e820: 00000000df5ca000 - 00000000df5cb000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df5cb000 - 00000000df5d3000 (reserved)
[ 0.000000] BIOS-e820: 00000000df5d3000 - 00000000df5dd000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df5dd000 - 00000000df639000 (reserved)
[ 0.000000] BIOS-e820: 00000000df639000 - 00000000df67c000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000df67c000 - 00000000df800000 (usable)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000041f800000 (usable)
[ 0.000000] DMI 2.6 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x41f800 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask C00000000 write-back
[ 0.000000] 1 base 400000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 base 41F800000 mask FFF800000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xdf800 max_arch_pfn = 0x400000000
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000df800000
[ 0.000000] 0000000000 - 00df800000 page 2M
[ 0.000000] kernel direct mapping tables up to df800000 @ 10000-15000
[ 0.000000] init_memory_mapping: 0000000100000000-000000041f800000
[ 0.000000] 0100000000 - 041f800000 page 2M
[ 0.000000] kernel direct mapping tables up to 41f800000 @ 13000-25000
[ 0.000000] RAMDISK: 37710000 - 37fefe5f
[ 0.000000] ACPI: RSDP 00000000000f0420 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 00000000dee49068 0004C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 00000000dee53160 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 00000000dee49140 0A01C (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS 00000000df5d4f80 00040
[ 0.000000] ACPI: APIC 00000000dee53258 00092 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 00000000dee532f0 001D6 (v01 AMICPU PROC 00000001 MSFT 03000001)
[ 0.000000] ACPI: MCFG 00000000dee534c8 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000dee53508 00038 (v01 ALASKA A M I 01072009 AMI. 00000004)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-000000041f800000
[ 0.000000] Bootmem setup node 0 0000000000000000-000000041f800000
[ 0.000000] NODE_DATA [0000000000020000 - 0000000000027fff]
[ 0.000000] bootmap [0000000000100000 - 0000000000183eff] pages 84
[ 0.000000] (8 early reservations) ==> bootmem [0000000000 - 041f800000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
[ 0.000000] #2 [0001000000 - 00016d95c4] TEXT DATA BSS ==> [0001000000 - 00016d95c4]
[ 0.000000] #3 [0037710000 - 0037fefe5f] RAMDISK ==> [0037710000 - 0037fefe5f]
[ 0.000000] #4 [000009d800 - 0000100000] BIOS reserved ==> [000009d800 - 0000100000]
[ 0.000000] #5 [00016da000 - 00016da27a] BRK ==> [00016da000 - 00016da27a]
[ 0.000000] #6 [0000010000 - 0000013000] PGTABLE ==> [0000010000 - 0000013000]
[ 0.000000] #7 [0000013000 - 0000020000] PGTABLE ==> [0000013000 - 0000020000]
[ 0.000000] found SMP MP-table at [ffff8800000fceb0] fceb0
[ 0.000000] [ffffea0000000000-ffffea000e7fffff] PMD -> [ffff880001800000-ffff88000f9fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x0041f800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[5] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000dedfa
[ 0.000000] 0: 0x000df5c8 -> 0x000df5ca
[ 0.000000] 0: 0x000df67c -> 0x000df800
[ 0.000000] 0: 0x00100000 -> 0x0041f800
[ 0.000000] On node 0 totalpages: 4187917
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 117 pages reserved
[ 0.000000] DMA zone: 3808 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 894904 pages, LIFO batch:31
[ 0.000000] Normal zone: 44772 pages used for memmap
[ 0.000000] Normal zone: 3229980 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000dedfa000 - 00000000dee54000
[ 0.000000] PM: Registered nosave memory: 00000000dee54000 - 00000000df357000
[ 0.000000] PM: Registered nosave memory: 00000000df357000 - 00000000df35a000
[ 0.000000] PM: Registered nosave memory: 00000000df35a000 - 00000000df5a0000
[ 0.000000] PM: Registered nosave memory: 00000000df5a0000 - 00000000df5b1000
[ 0.000000] PM: Registered nosave memory: 00000000df5b1000 - 00000000df5c8000
[ 0.000000] PM: Registered nosave memory: 00000000df5ca000 - 00000000df5cb000
[ 0.000000] PM: Registered nosave memory: 00000000df5cb000 - 00000000df5d3000
[ 0.000000] PM: Registered nosave memory: 00000000df5d3000 - 00000000df5dd000
[ 0.000000] PM: Registered nosave memory: 00000000df5dd000 - 00000000df639000
[ 0.000000] PM: Registered nosave memory: 00000000df639000 - 00000000df67c000
[ 0.000000] PM: Registered nosave memory: 00000000df800000 - 00000000fed1c000
[ 0.000000] PM: Registered nosave memory: 00000000fed1c000 - 00000000fed20000
[ 0.000000] PM: Registered nosave memory: 00000000fed20000 - 00000000ff000000
[ 0.000000] PM: Registered nosave memory: 00000000ff000000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at df800000 (gap: df800000:1f51c000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff88000fc00000 s90328 r8192 d24360 u262144
[ 0.000000] pcpu-alloc: s90328 r8192 d24360 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4128692
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-5-amd64 root=UUID=3329ab5a-2052-440e-91e5-ad7ce291b80e ro quiet nomodeset nouveau.modeset=0
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] Checking aperture...
[ 0.000000] No AGP bridge found
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.000000] Placing 64MB software IO TLB between ffff88000fdde000 - ffff880013dde000
[ 0.000000] software IO TLB at phys 0xfdde000 - 0x13dde000
[ 0.000000] Memory: 16436744k/17293312k available (3083k kernel code, 541644k absent, 314924k reserved, 2048k data, 592k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:472
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3502.794 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 7005.58 BogoMIPS (lpj=14011176)
[ 0.000011] Security Framework initialized
[ 0.000014] SELinux: Disabled at boot.
[ 0.000712] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.002958] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.003901] Mount-cache hash table entries: 256
[ 0.003975] Initializing cgroup subsys ns
[ 0.003977] Initializing cgroup subsys cpuacct
[ 0.003979] Initializing cgroup subsys devices
[ 0.003980] Initializing cgroup subsys freezer
[ 0.003981] Initializing cgroup subsys net_cls
[ 0.003994] CPU: Physical Processor ID: 0
[ 0.003995] CPU: Processor Core ID: 0
[ 0.003997] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.003998] CPU: L2 cache: 256K
[ 0.003999] CPU: L3 cache: 8192K
[ 0.004001] CPU 0/0x0 -> Node 0
[ 0.004003] mce: CPU supports 9 MCE banks
[ 0.004011] CPU0: Thermal monitoring enabled (TM1)
[ 0.004012] CPU 0 MCA banks CMCI:0 CMCI:1 CMCI:3 SHD:5 SHD:6 SHD:7 CMCI:8
[ 0.004019] using mwait in idle threads.
[ 0.004020] Performance Events: Nehalem/Corei7 events, Intel PMU driver.
[ 0.004023] ... version: 3
[ 0.004024] ... bit width: 48
[ 0.004025] ... generic registers: 4
[ 0.004025] ... value mask: 0000ffffffffffff
[ 0.004026] ... max period: 000000007fffffff
[ 0.004027] ... fixed-purpose events: 3
[ 0.004028] ... event mask: 000000070000000f
[ 0.004702] ACPI: Core revision 20090903
[ 0.222759] Not enabling x2apic, Intr-remapping init failed.
[ 0.222761] Setting APIC routing to flat
[ 0.223091] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.262728] CPU0: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.368001] Booting processor 1 APIC 0x2 ip 0x6000
[ 0.378297] Initializing CPU#1
[ 0.455836] CPU: Physical Processor ID: 0
[ 0.455836] CPU: Processor Core ID: 1
[ 0.455838] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.455839] CPU: L2 cache: 256K
[ 0.455839] CPU: L3 cache: 8192K
[ 0.455841] CPU 1/0x2 -> Node 0
[ 0.455851] CPU1: Thermal monitoring enabled (TM1)
[ 0.455852] CPU 1 MCA banks CMCI:0 CMCI:1 CMCI:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.455926] CPU1: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.455932] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.475962] Booting processor 2 APIC 0x4 ip 0x6000
[ 0.486217] Initializing CPU#2
[ 0.563703] CPU: Physical Processor ID: 0
[ 0.563704] CPU: Processor Core ID: 2
[ 0.563705] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.563706] CPU: L2 cache: 256K
[ 0.563707] CPU: L3 cache: 8192K
[ 0.563709] CPU 2/0x4 -> Node 0
[ 0.563718] CPU2: Thermal monitoring enabled (TM1)
[ 0.563719] CPU 2 MCA banks CMCI:0 CMCI:1 CMCI:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.563788] CPU2: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.563793] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
[ 0.583821] Booting processor 3 APIC 0x6 ip 0x6000
[ 0.594076] Initializing CPU#3
[ 0.671570] CPU: Physical Processor ID: 0
[ 0.671571] CPU: Processor Core ID: 3
[ 0.671573] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.671574] CPU: L2 cache: 256K
[ 0.671574] CPU: L3 cache: 8192K
[ 0.671576] CPU 3/0x6 -> Node 0
[ 0.671586] CPU3: Thermal monitoring enabled (TM1)
[ 0.671587] CPU 3 MCA banks CMCI:0 CMCI:1 CMCI:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.671647] CPU3: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.671653] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
[ 0.691683] Booting processor 4 APIC 0x1 ip 0x6000
[ 0.701956] Initializing CPU#4
[ 0.779439] CPU: Physical Processor ID: 0
[ 0.779439] CPU: Processor Core ID: 0
[ 0.779442] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.779443] CPU: L2 cache: 256K
[ 0.779444] CPU: L3 cache: 8192K
[ 0.779446] CPU 4/0x1 -> Node 0
[ 0.779456] CPU4: Thermal monitoring enabled (TM1)
[ 0.779458] CPU 4 MCA banks SHD:0 SHD:1 SHD:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.779513] CPU4: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.779519] checking TSC synchronization [CPU#0 -> CPU#4]: passed.
[ 0.799550] Booting processor 5 APIC 0x3 ip 0x6000
[ 0.809805] Initializing CPU#5
[ 0.887305] CPU: Physical Processor ID: 0
[ 0.887306] CPU: Processor Core ID: 1
[ 0.887307] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.887308] CPU: L2 cache: 256K
[ 0.887309] CPU: L3 cache: 8192K
[ 0.887310] CPU 5/0x3 -> Node 0
[ 0.887320] CPU5: Thermal monitoring enabled (TM1)
[ 0.887321] CPU 5 MCA banks SHD:0 SHD:1 SHD:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.887376] CPU5: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.887382] checking TSC synchronization [CPU#0 -> CPU#5]: passed.
[ 0.907410] Booting processor 6 APIC 0x5 ip 0x6000
[ 0.917665] Initializing CPU#6
[ 0.995172] CPU: Physical Processor ID: 0
[ 0.995173] CPU: Processor Core ID: 2
[ 0.995175] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.995176] CPU: L2 cache: 256K
[ 0.995176] CPU: L3 cache: 8192K
[ 0.995178] CPU 6/0x5 -> Node 0
[ 0.995187] CPU6: Thermal monitoring enabled (TM1)
[ 0.995188] CPU 6 MCA banks SHD:0 SHD:1 SHD:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 0.995237] CPU6: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 0.995242] checking TSC synchronization [CPU#0 -> CPU#6]: passed.
[ 1.015274] Booting processor 7 APIC 0x7 ip 0x6000
[ 1.025528] Initializing CPU#7
[ 1.103040] CPU: Physical Processor ID: 0
[ 1.103040] CPU: Processor Core ID: 3
[ 1.103042] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 1.103043] CPU: L2 cache: 256K
[ 1.103044] CPU: L3 cache: 8192K
[ 1.103045] CPU 7/0x7 -> Node 0
[ 1.103055] CPU7: Thermal monitoring enabled (TM1)
[ 1.103056] CPU 7 MCA banks SHD:0 SHD:1 SHD:3 SHD:5 SHD:6 SHD:7 SHD:8
[ 1.103100] CPU7: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz stepping 07
[ 1.103106] checking TSC synchronization [CPU#0 -> CPU#7]: passed.
[ 1.123095] Brought up 8 CPUs
[ 1.123097] Total of 8 processors activated (56041.51 BogoMIPS).
[ 1.126854] CPU0 attaching sched-domain:
[ 1.126856] domain 0: span 0,4 level SIBLING
[ 1.126857] groups: group ffff88000fc0fae0 cpus 0 (cpu_power = 589) group ffff88000fd0fae0 cpus 4 (cpu_power = 589)
[ 1.126861] domain 1: span 0-7 level MC
[ 1.126862] groups: group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178)
[ 1.126869] CPU1 attaching sched-domain:
[ 1.126870] domain 0: span 1,5 level SIBLING
[ 1.126871] groups: group ffff88000fc4fae0 cpus 1 (cpu_power = 589) group ffff88000fd4fae0 cpus 5 (cpu_power = 589)
[ 1.126874] domain 1: span 0-7 level MC
[ 1.126875] groups: group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178)
[ 1.126881] CPU2 attaching sched-domain:
[ 1.126882] domain 0: span 2,6 level SIBLING
[ 1.126883] groups: group ffff88000fc8fae0 cpus 2 (cpu_power = 589) group ffff88000fd8fae0 cpus 6 (cpu_power = 589)
[ 1.126886] domain 1: span 0-7 level MC
[ 1.126887] groups: group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178)
[ 1.126892] CPU3 attaching sched-domain:
[ 1.126893] domain 0: span 3,7 level SIBLING
[ 1.126894] groups: group ffff88000fccfae0 cpus 3 (cpu_power = 589) group ffff88000fdcfae0 cpus 7 (cpu_power = 589)
[ 1.126897] domain 1: span 0-7 level MC
[ 1.126898] groups: group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178)
[ 1.126904] CPU4 attaching sched-domain:
[ 1.126905] domain 0: span 0,4 level SIBLING
[ 1.126906] groups: group ffff88000fd0fae0 cpus 4 (cpu_power = 589) group ffff88000fc0fae0 cpus 0 (cpu_power = 589)
[ 1.126909] domain 1: span 0-7 level MC
[ 1.126910] groups: group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178)
[ 1.126915] CPU5 attaching sched-domain:
[ 1.126916] domain 0: span 1,5 level SIBLING
[ 1.126917] groups: group ffff88000fd4fae0 cpus 5 (cpu_power = 589) group ffff88000fc4fae0 cpus 1 (cpu_power = 589)
[ 1.126920] domain 1: span 0-7 level MC
[ 1.126921] groups: group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178)
[ 1.126926] CPU6 attaching sched-domain:
[ 1.126927] domain 0: span 2,6 level SIBLING
[ 1.126928] groups: group ffff88000fd8fae0 cpus 6 (cpu_power = 589) group ffff88000fc8fae0 cpus 2 (cpu_power = 589)
[ 1.126931] domain 1: span 0-7 level MC
[ 1.126932] groups: group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178) group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178)
[ 1.126938] CPU7 attaching sched-domain:
[ 1.126939] domain 0: span 3,7 level SIBLING
[ 1.126940] groups: group ffff88000fdcfae0 cpus 7 (cpu_power = 589) group ffff88000fccfae0 cpus 3 (cpu_power = 589)
[ 1.126943] domain 1: span 0-7 level MC
[ 1.126944] groups: group ffff88000fccfbf0 cpus 3,7 (cpu_power = 1178) group ffff88000fc0fbf0 cpus 0,4 (cpu_power = 1178) group ffff88000fc4fbf0 cpus 1,5 (cpu_power = 1178) group ffff88000fc8fbf0 cpus 2,6 (cpu_power = 1178)
[ 1.127144] devtmpfs: initialized
[ 1.129667] regulator: core version 0.5
[ 1.129693] NET: Registered protocol family 16
[ 1.129743] ACPI: bus type pci registered
[ 1.129786] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 63
[ 1.129787] PCI: Not using MMCONFIG.
[ 1.129788] PCI: Using configuration type 1 for base access
[ 1.130282] bio: create slab <bio-0> at 0
[ 1.130791] ACPI: EC: Look up EC in DSDT
[ 1.131224] ACPI: Executed 1 blocks of module-level executable AML code
[ 1.133894] ACPI Error (psargs-0359): [RAMB] Namespace lookup failure, AE_NOT_FOUND
[ 1.133897] ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20090903/nsinit-338)
[ 1.135601] ACPI: Interpreter enabled
[ 1.135603] ACPI: (supports S0 S1 S3 S4 S5)
[ 1.135616] ACPI: Using IOAPIC for interrupt routing
[ 1.135649] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 63
[ 1.135748] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 1.137271] PCI: Using MMCONFIG at e0000000 - e3ffffff
[ 1.137471] ACPI: BIOS _OSI(Linux) query ignored
[ 1.142079] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62
[ 1.142214] ACPI: No dock devices found.
[ 1.142451] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 1.142512] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 1.142514] pci 0000:00:01.0: PME# disabled
[ 1.142572] pci 0000:00:16.0: reg 10 64bit mmio: [0xfa529000-0xfa52900f]
[ 1.142625] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 1.142629] pci 0000:00:16.0: PME# disabled
[ 1.142671] pci 0000:00:19.0: reg 10 32bit mmio: [0xfa500000-0xfa51ffff]
[ 1.142676] pci 0000:00:19.0: reg 14 32bit mmio: [0xfa528000-0xfa528fff]
[ 1.142681] pci 0000:00:19.0: reg 18 io port: [0xf040-0xf05f]
[ 1.142727] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 1.142730] pci 0000:00:19.0: PME# disabled
[ 1.142773] pci 0000:00:1a.0: reg 10 32bit mmio: [0xfa527000-0xfa5273ff]
[ 1.142836] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 1.142840] pci 0000:00:1a.0: PME# disabled
[ 1.142875] pci 0000:00:1b.0: reg 10 64bit mmio: [0xfa520000-0xfa523fff]
[ 1.142923] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 1.142926] pci 0000:00:1b.0: PME# disabled
[ 1.143004] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.143007] pci 0000:00:1c.0: PME# disabled
[ 1.143088] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 1.143091] pci 0000:00:1c.1: PME# disabled
[ 1.143170] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 1.143173] pci 0000:00:1c.2: PME# disabled
[ 1.143250] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 1.143254] pci 0000:00:1c.3: PME# disabled
[ 1.143331] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 1.143334] pci 0000:00:1c.4: PME# disabled
[ 1.143412] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 1.143415] pci 0000:00:1c.6: PME# disabled
[ 1.143493] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 1.143496] pci 0000:00:1c.7: PME# disabled
[ 1.143542] pci 0000:00:1d.0: reg 10 32bit mmio: [0xfa526000-0xfa5263ff]
[ 1.143605] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.143609] pci 0000:00:1d.0: PME# disabled
[ 1.143740] pci 0000:00:1f.2: reg 10 io port: [0xf090-0xf097]
[ 1.143744] pci 0000:00:1f.2: reg 14 io port: [0xf080-0xf083]
[ 1.143749] pci 0000:00:1f.2: reg 18 io port: [0xf070-0xf077]
[ 1.143754] pci 0000:00:1f.2: reg 1c io port: [0xf060-0xf063]
[ 1.143758] pci 0000:00:1f.2: reg 20 io port: [0xf020-0xf03f]
[ 1.143763] pci 0000:00:1f.2: reg 24 32bit mmio: [0xfa525000-0xfa5257ff]
[ 1.143800] pci 0000:00:1f.2: PME# supported from D3hot
[ 1.143802] pci 0000:00:1f.2: PME# disabled
[ 1.143827] pci 0000:00:1f.3: reg 10 64bit mmio: [0xfa524000-0xfa5240ff]
[ 1.143838] pci 0000:00:1f.3: reg 20 io port: [0xf000-0xf01f]
[ 1.143875] pci 0000:01:00.0: reg 10 32bit mmio: [0xf8000000-0xf9ffffff]
[ 1.143881] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xe8000000-0xefffffff]
[ 1.143887] pci 0000:01:00.0: reg 1c 64bit mmio pref: [0xf0000000-0xf3ffffff]
[ 1.143890] pci 0000:01:00.0: reg 24 io port: [0xe000-0xe07f]
[ 1.143894] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfa000000-0xfa07ffff]
[ 1.143944] pci 0000:01:00.1: reg 10 32bit mmio: [0xfa080000-0xfa083fff]
[ 1.151043] pci 0000:00:01.0: bridge io port: [0xe000-0xefff]
[ 1.151046] pci 0000:00:01.0: bridge 32bit mmio: [0xf8000000-0xfa0fffff]
[ 1.151051] pci 0000:00:01.0: bridge 64bit mmio pref: [0xe8000000-0xf3ffffff]
[ 1.151178] pci 0000:03:00.0: reg 10 64bit mmio: [0xfa400000-0xfa407fff]
[ 1.151292] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 1.151297] pci 0000:03:00.0: PME# disabled
[ 1.159098] pci 0000:00:1c.1: bridge 32bit mmio: [0xfa400000-0xfa4fffff]
[ 1.159201] pci 0000:05:00.0: reg 10 io port: [0xd040-0xd047]
[ 1.159210] pci 0000:05:00.0: reg 14 io port: [0xd030-0xd033]
[ 1.159219] pci 0000:05:00.0: reg 18 io port: [0xd020-0xd027]
[ 1.159229] pci 0000:05:00.0: reg 1c io port: [0xd010-0xd013]
[ 1.159238] pci 0000:05:00.0: reg 20 io port: [0xd000-0xd00f]
[ 1.159248] pci 0000:05:00.0: reg 24 32bit mmio: [0xfa310000-0xfa3101ff]
[ 1.159257] pci 0000:05:00.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 1.159316] pci 0000:05:00.0: PME# supported from D3hot
[ 1.159321] pci 0000:05:00.0: PME# disabled
[ 1.167071] pci 0000:00:1c.3: bridge io port: [0xd000-0xdfff]
[ 1.167075] pci 0000:00:1c.3: bridge 32bit mmio: [0xfa300000-0xfa3fffff]
[ 1.167147] pci 0000:06:00.0: reg 10 64bit mmio: [0xfa200000-0xfa207fff]
[ 1.167262] pci 0000:06:00.0: PME# supported from D3hot D3cold
[ 1.167267] pci 0000:06:00.0: PME# disabled
[ 1.175076] pci 0000:00:1c.4: bridge 32bit mmio: [0xfa200000-0xfa2fffff]
[ 1.175251] pci 0000:00:1c.6: transparent bridge
[ 1.175255] pci 0000:00:1c.6: bridge io port: [0xc000-0xcfff]
[ 1.175258] pci 0000:00:1c.6: bridge 32bit mmio: [0xfa100000-0xfa1fffff]
[ 1.175316] pci 0000:08:00.0: reg 10 io port: [0xc000-0xc0ff]
[ 1.175327] pci 0000:08:00.0: reg 14 32bit mmio: [0xfa121000-0xfa1210ff]
[ 1.175371] pci 0000:08:00.0: reg 30 32bit mmio pref: [0xfa100000-0xfa11ffff]
[ 1.175421] pci 0000:08:00.0: supports D1 D2
[ 1.175422] pci 0000:08:00.0: PME# supported from D1 D2 D3hot D3cold
[ 1.175428] pci 0000:08:00.0: PME# disabled
[ 1.175494] pci 0000:08:01.0: reg 10 32bit mmio: [0xfa120000-0xfa120fff]
[ 1.175592] pci 0000:08:01.0: supports D1 D2
[ 1.175593] pci 0000:08:01.0: PME# supported from D0 D1 D2 D3hot
[ 1.175599] pci 0000:08:01.0: PME# disabled
[ 1.175683] pci 0000:07:00.0: transparent bridge
[ 1.175691] pci 0000:07:00.0: bridge io port: [0xc000-0xcfff]
[ 1.175697] pci 0000:07:00.0: bridge 32bit mmio: [0xfa100000-0xfa1fffff]
[ 1.175783] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 1.175873] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 1.175909] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 1.175942] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
[ 1.175975] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 1.176008] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 1.176058] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT]
[ 1.176093] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX6._PRT]
[ 1.176127] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX6.BR24._PRT]
[ 1.179813] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 1.179886] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 1.179956] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
[ 1.180027] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.180097] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 1.180168] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 1.180238] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 1.180309] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 1.180366] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.180369] vgaarb: loaded
[ 1.180399] PCI: Using ACPI for IRQ routing
[ 1.180538] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.180541] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 1.182551] Switching to clocksource tsc
[ 1.183212] pnp: PnP ACPI init
[ 1.183217] ACPI: bus type pnp registered
[ 1.184496] pnp: PnP ACPI: found 11 devices
[ 1.184497] ACPI: ACPI bus type pnp unregistered
[ 1.184502] system 00:01: iomem range 0xfed10000-0xfed19fff has been reserved
[ 1.184504] system 00:01: iomem range 0xe0000000-0xe3ffffff has been reserved
[ 1.184505] system 00:01: iomem range 0xfed90000-0xfed93fff has been reserved
[ 1.184506] system 00:01: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 1.184508] system 00:01: iomem range 0xfee00000-0xfee0ffff has been reserved
[ 1.184511] system 00:02: ioport range 0x290-0x29f has been reserved
[ 1.184514] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
[ 1.184517] system 00:08: ioport range 0x400-0x453 has been reserved
[ 1.184518] system 00:08: ioport range 0x458-0x47f has been reserved
[ 1.184519] system 00:08: ioport range 0x500-0x57f has been reserved
[ 1.184521] system 00:08: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 1.184523] system 00:08: iomem range 0xfec00000-0xfecfffff could not be reserved
[ 1.184524] system 00:08: iomem range 0xfed08000-0xfed08fff has been reserved
[ 1.184526] system 00:08: iomem range 0xff000000-0xffffffff has been reserved
[ 1.184528] system 00:09: ioport range 0x454-0x457 has been reserved
[ 1.189196] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 1.189197] pci 0000:00:01.0: IO window: 0xe000-0xefff
[ 1.189199] pci 0000:00:01.0: MEM window: 0xf8000000-0xfa0fffff
[ 1.189201] pci 0000:00:01.0: PREFETCH window: 0x000000e8000000-0x000000f3ffffff
[ 1.189204] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[ 1.189204] pci 0000:00:1c.0: IO window: disabled
[ 1.189209] pci 0000:00:1c.0: MEM window: disabled
[ 1.189212] pci 0000:00:1c.0: PREFETCH window: disabled
[ 1.189217] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:03
[ 1.189218] pci 0000:00:1c.1: IO window: disabled
[ 1.189222] pci 0000:00:1c.1: MEM window: 0xfa400000-0xfa4fffff
[ 1.189225] pci 0000:00:1c.1: PREFETCH window: disabled
[ 1.189230] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:04
[ 1.189231] pci 0000:00:1c.2: IO window: disabled
[ 1.189235] pci 0000:00:1c.2: MEM window: disabled
[ 1.189238] pci 0000:00:1c.2: PREFETCH window: disabled
[ 1.189244] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:05
[ 1.189246] pci 0000:00:1c.3: IO window: 0xd000-0xdfff
[ 1.189250] pci 0000:00:1c.3: MEM window: 0xfa300000-0xfa3fffff
[ 1.189254] pci 0000:00:1c.3: PREFETCH window: 0xe4000000-0xe40fffff
[ 1.189259] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:06
[ 1.189260] pci 0000:00:1c.4: IO window: disabled
[ 1.189264] pci 0000:00:1c.4: MEM window: 0xfa200000-0xfa2fffff
[ 1.189267] pci 0000:00:1c.4: PREFETCH window: disabled
[ 1.189273] pci 0000:07:00.0: PCI bridge, secondary bus 0000:08
[ 1.189276] pci 0000:07:00.0: IO window: 0xc000-0xcfff
[ 1.189283] pci 0000:07:00.0: MEM window: 0xfa100000-0xfa1fffff
[ 1.189288] pci 0000:07:00.0: PREFETCH window: disabled
[ 1.189297] pci 0000:00:1c.6: PCI bridge, secondary bus 0000:07
[ 1.189300] pci 0000:00:1c.6: IO window: 0xc000-0xcfff
[ 1.189304] pci 0000:00:1c.6: MEM window: 0xfa100000-0xfa1fffff
[ 1.189307] pci 0000:00:1c.6: PREFETCH window: disabled
[ 1.189312] pci 0000:00:1c.7: PCI bridge, secondary bus 0000:09
[ 1.189313] pci 0000:00:1c.7: IO window: disabled
[ 1.189317] pci 0000:00:1c.7: MEM window: disabled
[ 1.189320] pci 0000:00:1c.7: PREFETCH window: disabled
[ 1.189329] alloc irq_desc for 16 on node -1
[ 1.189330] alloc kstat_irqs on node -1
[ 1.189334] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.189336] pci 0000:00:01.0: setting latency timer to 64
[ 1.189342] alloc irq_desc for 17 on node -1
[ 1.189342] alloc kstat_irqs on node -1
[ 1.189344] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.189348] pci 0000:00:1c.0: setting latency timer to 64
[ 1.189354] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 1.189358] pci 0000:00:1c.1: setting latency timer to 64
[ 1.189364] alloc irq_desc for 18 on node -1
[ 1.189365] alloc kstat_irqs on node -1
[ 1.189367] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.189370] pci 0000:00:1c.2: setting latency timer to 64
[ 1.189377] alloc irq_desc for 19 on node -1
[ 1.189378] alloc kstat_irqs on node -1
[ 1.189379] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 1.189383] pci 0000:00:1c.3: setting latency timer to 64
[ 1.189389] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.189392] pci 0000:00:1c.4: setting latency timer to 64
[ 1.189399] pci 0000:00:1c.6: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.189402] pci 0000:00:1c.6: setting latency timer to 64
[ 1.189407] pci 0000:07:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.189412] pci 0000:07:00.0: setting latency timer to 64
[ 1.189420] pci 0000:00:1c.7: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 1.189423] pci 0000:00:1c.7: setting latency timer to 64
[ 1.189426] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 1.189427] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 1.189428] pci_bus 0000:01: resource 0 io: [0xe000-0xefff]
[ 1.189430] pci_bus 0000:01: resource 1 mem: [0xf8000000-0xfa0fffff]
[ 1.189431] pci_bus 0000:01: resource 2 pref mem [0xe8000000-0xf3ffffff]
[ 1.189432] pci_bus 0000:03: resource 1 mem: [0xfa400000-0xfa4fffff]
[ 1.189433] pci_bus 0000:05: resource 0 io: [0xd000-0xdfff]
[ 1.189434] pci_bus 0000:05: resource 1 mem: [0xfa300000-0xfa3fffff]
[ 1.189436] pci_bus 0000:05: resource 2 pref mem [0xe4000000-0xe40fffff]
[ 1.189437] pci_bus 0000:06: resource 1 mem: [0xfa200000-0xfa2fffff]
[ 1.189438] pci_bus 0000:07: resource 0 io: [0xc000-0xcfff]
[ 1.189439] pci_bus 0000:07: resource 1 mem: [0xfa100000-0xfa1fffff]
[ 1.189440] pci_bus 0000:07: resource 3 io: [0x00-0xffff]
[ 1.189441] pci_bus 0000:07: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 1.189442] pci_bus 0000:08: resource 0 io: [0xc000-0xcfff]
[ 1.189444] pci_bus 0000:08: resource 1 mem: [0xfa100000-0xfa1fffff]
[ 1.189445] pci_bus 0000:08: resource 3 io: [0xc000-0xcfff]
[ 1.189446] pci_bus 0000:08: resource 4 mem: [0xfa100000-0xfa1fffff]
[ 1.189447] pci_bus 0000:08: resource 6 io: [0x00-0xffff]
[ 1.189448] pci_bus 0000:08: resource 7 mem: [0x000000-0xffffffffffffffff]
[ 1.189461] NET: Registered protocol family 2
[ 1.189674] IP route cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 1.190282] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 1.191201] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.191311] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.191312] TCP reno registered
[ 1.191370] NET: Registered protocol family 1
[ 1.191389] alloc irq_desc for 23 on node -1
[ 1.191390] alloc kstat_irqs on node -1
[ 1.191395] pci 0000:00:1a.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.318787] pci 0000:00:1a.0: PCI INT A disabled
[ 1.318811] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.446627] pci 0000:00:1d.0: PCI INT A disabled
[ 1.446645] pci 0000:01:00.0: Boot video device
[ 1.446669] pci 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.446701] pci 0000:03:00.0: PCI INT A disabled
[ 1.446726] pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.446749] pci 0000:06:00.0: PCI INT A disabled
[ 1.446775] Unpacking initramfs...
[ 1.564978] Freeing initrd memory: 9087k freed
[ 1.566095] audit: initializing netlink socket (disabled)
[ 1.566101] type=2000 audit(1337263814.140:1): initialized
[ 1.568510] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.569236] VFS: Disk quotas dquot_6.5.2
[ 1.569261] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.569304] msgmni has been set to 32120
[ 1.569438] alg: No test for stdrng (krng)
[ 1.569463] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.569464] io scheduler noop registered
[ 1.569465] io scheduler anticipatory registered
[ 1.569466] io scheduler deadline registered
[ 1.569493] io scheduler cfq registered (default)
[ 1.569554] alloc irq_desc for 24 on node -1
[ 1.569555] alloc kstat_irqs on node -1
[ 1.569560] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 1.569563] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.569634] alloc irq_desc for 25 on node -1
[ 1.569635] alloc kstat_irqs on node -1
[ 1.569641] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[ 1.569648] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.569733] alloc irq_desc for 26 on node -1
[ 1.569733] alloc kstat_irqs on node -1
[ 1.569739] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
[ 1.569746] pcieport 0000:00:1c.1: setting latency timer to 64
[ 1.569830] alloc irq_desc for 27 on node -1
[ 1.569831] alloc kstat_irqs on node -1
[ 1.569837] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
[ 1.569844] pcieport 0000:00:1c.2: setting latency timer to 64
[ 1.569928] alloc irq_desc for 28 on node -1
[ 1.569929] alloc kstat_irqs on node -1
[ 1.569935] pcieport 0000:00:1c.3: irq 28 for MSI/MSI-X
[ 1.569942] pcieport 0000:00:1c.3: setting latency timer to 64
[ 1.570026] alloc irq_desc for 29 on node -1
[ 1.570026] alloc kstat_irqs on node -1
[ 1.570032] pcieport 0000:00:1c.4: irq 29 for MSI/MSI-X
[ 1.570039] pcieport 0000:00:1c.4: setting latency timer to 64
[ 1.570124] alloc irq_desc for 30 on node -1
[ 1.570124] alloc kstat_irqs on node -1
[ 1.570130] pcieport 0000:00:1c.7: irq 30 for MSI/MSI-X
[ 1.570137] pcieport 0000:00:1c.7: setting latency timer to 64
[ 1.570218] efifb: probing for efifb
[ 1.570346] efifb: framebuffer at 0xf1000000, mapped to 0xffffc90006600000, using 5120k, total 5120k
[ 1.570348] efifb: mode is 1280x1024x32, linelength=5120, pages=1
[ 1.570349] efifb: scrolling: redraw
[ 1.570350] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.621460] Console: switching to colour frame buffer device 160x64
[ 1.672498] fb0: EFI VGA frame buffer device
[ 1.673129] Linux agpgart interface v0.103
[ 1.673148] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.673360] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 1.673388] PNP: No PS/2 controller found. Probing ports directly.
[ 1.676120] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.676123] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.676159] mice: PS/2 mouse device common for all mice
[ 1.676180] rtc_cmos 00:04: RTC can wake from S4
[ 1.676196] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.676220] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.676226] cpuidle: using governor ladder
[ 1.676226] cpuidle: using governor menu
[ 1.676229] No iBFT detected.
[ 1.676361] TCP cubic registered
[ 1.676417] NET: Registered protocol family 10
[ 1.676732] Mobile IPv6
[ 1.676733] NET: Registered protocol family 17
[ 1.676771] PM: Resume from disk failed.
[ 1.676775] registered taskstats version 1
[ 1.677256] rtc_cmos 00:04: setting system clock to 2012-05-17 14:10:15 UTC (1337263815)
[ 1.677295] Initalizing network drop monitor service
[ 1.677310] Freeing unused kernel memory: 592k freed
[ 1.677360] Write protecting the kernel read-only data: 4240k
[ 1.684364] udev[116]: starting version 164
[ 1.698604] e1000e: Intel(R) PRO/1000 Network Driver - 1.2.20-k2
[ 1.698605] e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
[ 1.698628] e1000e 0000:00:19.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.698636] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.698718] alloc irq_desc for 31 on node -1
[ 1.698720] alloc kstat_irqs on node -1
[ 1.698732] e1000e 0000:00:19.0: irq 31 for MSI/MSI-X
[ 1.705523] usbcore: registered new interface driver usbfs
[ 1.705541] usbcore: registered new interface driver hub
[ 1.705565] usbcore: registered new device driver usb
[ 1.714162] SCSI subsystem initialized
[ 1.720453] libata version 3.00 loaded.
[ 1.724456] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.724478] r8169 0000:08:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.724517] r8169 0000:08:00.0: (unregistered net_device): no PCI Express capability
[ 1.724793] r8169 0000:08:00.0: eth0: RTL8110s at 0xffffc90001876000, 00:e0:4c:00:61:81, XID 04000000 IRQ 18
[ 1.725226] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.725721] firewire_ohci 0000:08:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.726179] xhci_hcd 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.726196] xhci_hcd 0000:03:00.0: setting latency timer to 64
[ 1.726199] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.726210] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
[ 1.787259] xhci_hcd 0000:03:00.0: irq 17, io mem 0xfa400000
[ 1.787301] usb usb1: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 1.787306] usb usb1: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.787307] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.787308] usb usb1: Product: xHCI Host Controller
[ 1.787309] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 xhci_hcd
[ 1.787310] usb usb1: SerialNumber: 0000:03:00.0
[ 1.787349] usb usb1: configuration #1 chosen from 1 choice
[ 1.787351] xHCI xhci_add_endpoint called for root hub
[ 1.787352] xHCI xhci_check_bandwidth called for root hub
[ 1.787367] hub 1-0:1.0: USB hub found
[ 1.787370] hub 1-0:1.0: 4 ports detected
[ 1.787415] xhci_hcd 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.787431] xhci_hcd 0000:06:00.0: setting latency timer to 64
[ 1.787434] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.787438] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 2
[ 1.802920] firewire_ohci: Added fw-ohci device 0000:08:01.0, OHCI version 1.0
[ 1.848492] xhci_hcd 0000:06:00.0: irq 16, io mem 0xfa200000
[ 1.848532] usb usb2: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 1.848536] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.848537] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.848538] usb usb2: Product: xHCI Host Controller
[ 1.848539] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 xhci_hcd
[ 1.848540] usb usb2: SerialNumber: 0000:06:00.0
[ 1.848570] usb usb2: configuration #1 chosen from 1 choice
[ 1.848571] xHCI xhci_add_endpoint called for root hub
[ 1.848572] xHCI xhci_check_bandwidth called for root hub
[ 1.848589] hub 2-0:1.0: USB hub found
[ 1.848592] hub 2-0:1.0: 4 ports detected
[ 1.998340] e1000e 0000:00:19.0: eth1: (PCI Express:2.5GB/s:Width x1) c8:60:00:74:68:f9
[ 1.998342] e1000e 0000:00:19.0: eth1: Intel(R) PRO/1000 Network Connection
[ 1.998372] e1000e 0000:00:19.0: eth1: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
[ 1.998382] ahci 0000:00:1f.2: version 3.0
[ 1.998391] alloc irq_desc for 20 on node -1
[ 1.998392] alloc kstat_irqs on node -1
[ 1.998396] ahci 0000:00:1f.2: PCI INT B -> GSI 20 (level, low) -> IRQ 20
[ 1.998421] alloc irq_desc for 32 on node -1
[ 1.998422] alloc kstat_irqs on node -1
[ 1.998429] ahci 0000:00:1f.2: irq 32 for MSI/MSI-X
[ 2.015433] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x2b impl SATA mode
[ 2.015437] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 2.015443] ahci 0000:00:1f.2: setting latency timer to 64
[ 2.037695] scsi0 : ahci
[ 2.037766] scsi1 : ahci
[ 2.037799] scsi2 : ahci
[ 2.037830] scsi3 : ahci
[ 2.037860] scsi4 : ahci
[ 2.037893] scsi5 : ahci
[ 2.037985] ata1: SATA max UDMA/133 abar m2048@0xfa525000 port 0xfa525100 irq 32
[ 2.037988] ata2: SATA max UDMA/133 abar m2048@0xfa525000 port 0xfa525180 irq 32
[ 2.037989] ata3: DUMMY
[ 2.037991] ata4: SATA max UDMA/133 abar m2048@0xfa525000 port 0xfa525280 irq 32
[ 2.037992] ata5: DUMMY
[ 2.037994] ata6: SATA max UDMA/133 abar m2048@0xfa525000 port 0xfa525380 irq 32
[ 2.038017] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 2.038019] ahci 0000:05:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 2.038036] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 2.038039] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 2.038049] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 2.038098] ehci_hcd 0000:00:1a.0: debug port 2
[ 2.038122] ahci 0000:05:00.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 2.038124] ahci 0000:05:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 2.038131] ahci 0000:05:00.0: setting latency timer to 64
[ 2.038209] scsi6 : ahci
[ 2.038255] scsi7 : ahci
[ 2.038286] ata7: SATA max UDMA/133 abar m512@0xfa310000 port 0xfa310100 irq 19
[ 2.038290] ata8: SATA max UDMA/133 abar m512@0xfa310000 port 0xfa310180 irq 19
[ 2.041983] ehci_hcd 0000:00:1a.0: cache line size of 32 is not supported
[ 2.041992] ehci_hcd 0000:00:1a.0: irq 23, io mem 0xfa527000
[ 2.057615] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 2.057634] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.057636] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.057638] usb usb3: Product: EHCI Host Controller
[ 2.057640] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 2.057643] usb usb3: SerialNumber: 0000:00:1a.0
[ 2.057716] usb usb3: configuration #1 chosen from 1 choice
[ 2.057732] hub 3-0:1.0: USB hub found
[ 2.057735] hub 3-0:1.0: 2 ports detected
[ 2.057761] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 2.057770] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.057772] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 2.057776] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 2.057795] ehci_hcd 0000:00:1d.0: debug port 2
[ 2.061673] ehci_hcd 0000:00:1d.0: cache line size of 32 is not supported
[ 2.061676] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xfa526000
[ 2.075340] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 2.075356] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.075359] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.075361] usb usb4: Product: EHCI Host Controller
[ 2.075363] usb usb4: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 2.075365] usb usb4: SerialNumber: 0000:00:1d.0
[ 2.075421] usb usb4: configuration #1 chosen from 1 choice
[ 2.075450] hub 4-0:1.0: USB hub found
[ 2.075453] hub 4-0:1.0: 2 ports detected
[ 2.297392] firewire_core: created device fw0: GUID 00601d0000000256, S400
[ 2.357273] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.357293] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.357308] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.357630] ata1.00: ATA-9: M4-CT128M4SSD2, 0309, max UDMA/100
[ 2.357633] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.357805] ata2.00: ATA-8: ST2000DM001-9YN164, CC9C, max UDMA/133
[ 2.357808] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.358033] ata1.00: configured for UDMA/100
[ 2.358337] ata4.00: ATA-8: ST3500418AS, CC46, max UDMA/133
[ 2.358341] ata4.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.358364] ata2.00: configured for UDMA/133
[ 2.359608] ata4.00: configured for UDMA/133
[ 2.361786] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.361814] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.361847] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.365320] ata6.00: ATAPI: HL-DT-ST DVDRAM GH22NS90, HN00S300, max UDMA/100
[ 2.366717] ata6.00: configured for UDMA/100
[ 2.369256] usb 3-1: new high speed USB device using ehci_hcd and address 2
[ 2.377339] scsi 0:0:0:0: Direct-Access ATA M4-CT128M4SSD2 0309 PQ: 0 ANSI: 5
[ 2.377495] scsi 1:0:0:0: Direct-Access ATA ST2000DM001-9YN1 CC9C PQ: 0 ANSI: 5
[ 2.377584] scsi 3:0:0:0: Direct-Access ATA ST3500418AS CC46 PQ: 0 ANSI: 5
[ 2.379529] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 2.379560] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2.379562] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 2.379564] sd 3:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.379577] sd 0:0:0:0: [sda] Write Protect is off
[ 2.379579] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.379599] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.379602] sd 3:0:0:0: [sdc] Write Protect is off
[ 2.379603] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.379605] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.379606] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.379621] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.379623] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.379760] sda:
[ 2.379774] sdc:
[ 2.379800] sdb: sda1 sda2 sda3 sda4
[ 2.380288] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.389387] scsi 5:0:0:0: CD-ROM HL-DT-ST DVDRAM GH22NS90 HN00 PQ: 0 ANSI: 5
[ 2.400228] sdc1
[ 2.400405] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 2.437559] sdb1
[ 2.437682] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.445402] sr0: scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.445406] Uniform CD-ROM driver Revision: 3.20
[ 2.445501] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 2.447323] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.447340] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.447354] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 2.447368] sr 5:0:0:0: Attached scsi generic sg3 type 5
[ 2.505492] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.505495] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.505566] usb 3-1: configuration #1 chosen from 1 choice
[ 2.505628] hub 3-1:1.0: USB hub found
[ 2.505740] hub 3-1:1.0: 6 ports detected
[ 2.616972] usb 4-1: new high speed USB device using ehci_hcd and address 2
[ 2.656041] PM: Starting manual resume from disk
[ 2.656043] PM: Resume from partition 8:2
[ 2.656044] PM: Checking hibernation image.
[ 2.656186] PM: Error -22 checking image file
[ 2.656189] PM: Resume from disk failed.
[ 2.669247] EXT4-fs (sda4): mounted filesystem with ordered data mode
[ 2.750199] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.750203] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.750301] usb 4-1: configuration #1 chosen from 1 choice
[ 2.750489] hub 4-1:1.0: USB hub found
[ 2.750565] hub 4-1:1.0: 8 ports detected
[ 2.758937] udev[449]: starting version 164
[ 2.780509] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 2.780518] ACPI: Power Button [PWRB]
[ 2.780559] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 2.780561] ACPI: Power Button [PWRF]
[ 2.783069] ACPI: SSDT 00000000df5d3818 0079C (v01 AMI IST 00000001 MSFT 03000001)
[ 2.784221] ACPI: SSDT 00000000df5daa18 0021C (v01 AMI CST 00000001 MSFT 03000001)
[ 2.789229] udev[492]: renamed network interface eth1 to eth1-eth0
[ 2.791395] Monitor-Mwait will be used to enter C-1 state
[ 2.795872] Monitor-Mwait will be used to enter C-2 state
[ 2.796090] Monitor-Mwait will be used to enter C-3 state
[ 2.796162] processor LNXCPU:00: registered as cooling_device0
[ 2.796205] ACPI: WMI: Mapper loaded
[ 2.797202] processor LNXCPU:01: registered as cooling_device1
[ 2.797797] processor LNXCPU:02: registered as cooling_device2
[ 2.799166] processor LNXCPU:03: registered as cooling_device3
[ 2.801076] processor LNXCPU:04: registered as cooling_device4
[ 2.801310] udev[482]: renamed network interface eth0 to eth1
[ 2.803044] processor LNXCPU:05: registered as cooling_device5
[ 2.803580] processor LNXCPU:06: registered as cooling_device6
[ 2.804028] processor LNXCPU:07: registered as cooling_device7
[ 2.839502] udev[492]: renamed network interface eth1-eth0 to eth0
[ 2.846073] nvidia: module license 'NVIDIA' taints kernel.
[ 2.846075] Disabling lock debugging due to kernel taint
[ 2.952625] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 2.952632] nvidia 0000:01:00.0: setting latency timer to 64
[ 2.952635] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.952768] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 295.40 Thu Apr 5 21:37:00 PDT 2012
[ 2.957424] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 2.957604] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 2.973172] alloc irq_desc for 22 on node -1
[ 2.973174] alloc kstat_irqs on node -1
[ 2.973178] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 2.973244] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 3.020648] usb 4-1.1: new low speed USB device using ehci_hcd and address 3
[ 3.130236] usb 4-1.1: New USB device found, idVendor=045e, idProduct=0780
[ 3.130239] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.130240] usb 4-1.1: Product: Comfort Curve Keyboard 3000
[ 3.130242] usb 4-1.1: Manufacturer: Microsoft
[ 3.130296] usb 4-1.1: configuration #1 chosen from 1 choice
[ 3.135566] Adding 3906552k swap on /dev/sda2. Priority:-1 extents:1 across:3906552k SS
[ 3.137220] usbcore: registered new interface driver hiddev
[ 3.142215] input: Microsoft Comfort Curve Keyboard 3000 as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.1/4-1.1:1.0/input/input4
[ 3.142284] generic-usb 0003:045E:0780.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Comfort Curve Keyboard 3000] on usb-0000:00:1d.0-1.1/input0
[ 3.150279] input: Microsoft Comfort Curve Keyboard 3000 as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.1/4-1.1:1.1/input/input5
[ 3.150332] generic-usb 0003:045E:0780.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Comfort Curve Keyboard 3000] on usb-0000:00:1d.0-1.1/input1
[ 3.150355] usbcore: registered new interface driver usbhid
[ 3.150383] usbhid: v2.6:USB HID core driver
[ 3.204448] usb 4-1.2: new low speed USB device using ehci_hcd and address 4
[ 3.301154] usb 4-1.2: New USB device found, idVendor=046d, idProduct=c069
[ 3.301157] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.301159] usb 4-1.2: Product: USB Laser Mouse
[ 3.301161] usb 4-1.2: Manufacturer: Logitech
[ 3.301238] usb 4-1.2: configuration #1 chosen from 1 choice
[ 3.305899] input: Logitech USB Laser Mouse as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.2/4-1.2:1.0/input/input6
[ 3.305963] generic-usb 0003:046D:C069.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-0000:00:1d.0-1.2/input0
[ 3.377203] usb 4-1.3: new full speed USB device using ehci_hcd and address 5
[ 3.520271] usb 4-1.3: New USB device found, idVendor=054c, idProduct=0268
[ 3.520275] usb 4-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.520278] usb 4-1.3: Product: PLAYSTATION(R)3 Controller
[ 3.520280] usb 4-1.3: Manufacturer: Sony
[ 3.520355] usb 4-1.3: configuration #1 chosen from 1 choice
[ 3.595923] usb 4-1.7: new full speed USB device using ehci_hcd and address 6
[ 3.596901] input: Sony PLAYSTATION(R)3 Controller as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.3/4-1.3:1.0/input/input7
[ 3.597010] sony 0003:054C:0268.0004: input,hiddev0,hidraw3: USB HID v1.11 Joystick [Sony PLAYSTATION(R)3 Controller] on usb-0000:00:1d.0-1.3/input0
[ 3.697177] usb 4-1.7: New USB device found, idVendor=0cf3, idProduct=3000
[ 3.697180] usb 4-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.697249] usb 4-1.7: configuration #1 chosen from 1 choice
[ 4.659966] loop: module loaded
[ 5.721777] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 5.728037] EXT4-fs (sda3): mounted filesystem with ordered data mode
[ 5.832811] EXT4-fs (sdb1): mounted filesystem with ordered data mode
[ 5.863478] EXT4-fs (sdc1): mounted filesystem with ordered data mode
[ 5.885548] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.891496] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.891672] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
[ 5.891674] nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
