Voici mes logs de connexion à partir du client windows:
Mon Sep 10 12:33:25 2007 OpenVPN 2.0.5 Win32-MinGW [SSL] [LZO] built on Nov 2 2005
Mon Sep 10 12:33:25 2007 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Mon Sep 10 12:33:25 2007 Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
Mon Sep 10 12:33:25 2007 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 10 12:33:25 2007 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 10 12:33:25 2007 LZO compression initialized
Mon Sep 10 12:33:25 2007 Control Channel MTU parms [ L:1542 D:166 EF:66 EB:0 ET:0 EL:0 ]
Mon Sep 10 12:33:25 2007 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Mon Sep 10 12:33:25 2007 Local Options hash (VER=V4): '504e774e'
Mon Sep 10 12:33:25 2007 Expected Remote Options hash (VER=V4): '14168603'
Mon Sep 10 12:33:25 2007 UDPv4 link local: [undef]
Mon Sep 10 12:33:25 2007 UDPv4 link remote: 82.xxx.xxx.xxx:2294
Mon Sep 10 12:33:25 2007 TLS: Initial packet from 82.xxx.xxx.xxx:2294, sid=9bc44f23 4e0a5e64
Mon Sep 10 12:33:25 2007 VERIFY OK: depth=1, /C=CZ/ST=State/L=City/O=Local/OU=Local/CN=openvpn.domain.com/emailAddress=toto@domain.com
Mon Sep 10 12:33:25 2007 VERIFY OK: nsCertType=SERVER
Mon Sep 10 12:33:25 2007 VERIFY OK: depth=0, /C=CZ/ST=State/L=City/O=Local/OU=Local/CN=openvpn.domain.com/emailAddress=toto@domain.com
Mon Sep 10 12:33:25 2007 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Sep 10 12:33:25 2007 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 10 12:33:25 2007 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Sep 10 12:33:25 2007 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Sep 10 12:33:25 2007 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Mon Sep 10 12:33:25 2007 [openvpn.domain.com] Peer Connection Initiated with 82.xxx.xxx.xxx:2294
Mon Sep 10 12:33:26 2007 SENT CONTROL [openvpn.domain.com]: 'PUSH_REQUEST' (status=1)
Mon Sep 10 12:33:26 2007 PUSH: Received control message: 'PUSH_REPLY,route 192.168.0.0 255.255.255.0,dhcp-option DNS 10.8.0.1,dhcp-option DOMAIN zone.domain.com,dhcp-option WINS 10.8.0.1,route 10.8.0.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 10.8.0.10 10.8.0.9'
Mon Sep 10 12:33:26 2007 OPTIONS IMPORT: timers and/or timeouts modified
Mon Sep 10 12:33:26 2007 OPTIONS IMPORT: --ifconfig/up options modified
Mon Sep 10 12:33:26 2007 OPTIONS IMPORT: route options modified
Mon Sep 10 12:33:26 2007 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Sep 10 12:33:26 2007 TAP-WIN32 device [Connexion openVPN] opened: \\.\Global\{9E2F5B9C-EAD9-4A3C-AA68-BE3C42C8D61E}.tap
Mon Sep 10 12:33:26 2007 TAP-Win32 Driver Version 8.1
Mon Sep 10 12:33:26 2007 TAP-Win32 MTU=1500
Mon Sep 10 12:33:26 2007 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.10/255.255.255.252 on interface {9E2F5B9C-EAD9-4A3C-AA68-BE3C42C8D61E} [DHCP-serv: 10.8.0.9, lease-time: 31536000]
Mon Sep 10 12:33:26 2007 Successful ARP Flush on interface [16777224] {9E2F5B9C-EAD9-4A3C-AA68-BE3C42C8D61E}
Mon Sep 10 12:33:26 2007 TEST ROUTES: 0/0 succeeded len=2 ret=0 a=0 u/d=down
Mon Sep 10 12:33:26 2007 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 10 12:33:27 2007 TEST ROUTES: 0/0 succeeded len=2 ret=0 a=0 u/d=down
Mon Sep 10 12:33:27 2007 Route: Waiting for TUN/TAP interface to come up...
Mon Sep 10 12:33:28 2007 TEST ROUTES: 2/2 succeeded len=2 ret=1 a=0 u/d=up
Mon Sep 10 12:33:28 2007 route ADD 192.168.0.0 MASK 255.255.255.0 10.8.0.9
Mon Sep 10 12:33:28 2007 Route addition via IPAPI succeeded
Mon Sep 10 12:33:28 2007 route ADD 10.8.0.0 MASK 255.255.255.0 10.8.0.9
Mon Sep 10 12:33:28 2007 Initialization Sequence Completed
J’ai fais un ipconfig /all sur le client et c’est assez bizarre Etch ne m’envoi pas l’ip de la passerelle!:
[code]Ethernet carte Connexion au réseau local 3:
Suffixe DNS spécifique à la connexion. : zone.domain.com
Description . . . . . . . . . . . : TAP-Win32 Adapter V8
Adresse physique. . . . . . . . . : 00-FA-9E-2F-5D-9C
DHCP activé . . . . . . . . . . . : Oui
Autoconfiguration activé . . . . : Oui
Adresse IP. . . . . . . . . . . . : 10.8.0.10
Masque de sous-réseau . . . . . . : 255.255.255.252
Passerelle par défaut . . . . . . :
Serveur DHCP. . . . . . . . . . . : 10.8.0.9
Serveurs DNS. . . . . . . . . . . : 10.8.0.1
Serveur WINS principal. . . . . . : 10.8.0.1
Bail obtenu . . . . . . . . . . . : lundi 10 septembre 2007 11:42:47
Bail expire . . . . . . . . . . . : mardi 9 septembre 2008 11:42:47[/code]
