voici une idée de mon matériel:
lspci -vv
00:00.0 Host bridge: Intel Corporation Device 2280 (rev 35)
Subsystem: ASUSTeK Computer Inc. Device 1250
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: iosf_mbi_pci
00:02.0 VGA compatible controller: Intel Corporation Device 22b1 (rev 35) (prog-if 00 [VGA controller])
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 255
Region 0: Memory at 80000000 (64-bit, non-prefetchable) [size=16M]
Region 2: Memory at 90000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at f000 [size=64]
Expansion ROM at [disabled]
Capabilities:
00:0b.0 Signal processing controller: Intel Corporation Device 22dc (rev 35)
Latency: 0
Region 0: Memory at 81429000 (64-bit, non-prefetchable) [size=4K]
Capabilities:
00:13.0 SATA controller: Intel Corporation Device 22a3 (rev 35) (prog-if 01 [AHCI 1.0])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 133
Region 4: I/O ports at f060 [size=32]
Region 5: Memory at 81424000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
00:14.0 USB controller: Intel Corporation Device 22b5 (rev 35) (prog-if 30 [XHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 134
Region 0: Memory at 81400000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: xhci_hcd
00:1a.0 Encryption controller: Intel Corporation Device 2298 (rev 35)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 64 bytes
Region 0: Memory at 81300000 (32-bit, non-prefetchable) [size=1M]
Region 1: Memory at 81200000 (32-bit, non-prefetchable) [size=1M]
Capabilities:
00:1b.0 Audio device: Intel Corporation Device 2284 (rev 35)
Subsystem: ASUSTeK Computer Inc. Device 111e
Interrupt: pin A routed to IRQ 135
Region 0: Memory at 81410000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation Device 22c8 (rev 35) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 81500000-816fffff
Prefetchable memory behind bridge: 0000000081700000-00000000818fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities:
Kernel driver in use: pcieport
00:1c.2 PCI bridge: Intel Corporation Device 22cc (rev 35) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 81000000-811fffff
Capabilities:
00:1f.0 ISA bridge: Intel Corporation Device 229c (rev 35)
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Capabilities:
00:1f.3 SMBus: Intel Corporation Device 2292 (rev 35)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 255
Region 0: Memory at 81418000 (32-bit, non-prefetchable) [size=32]
Region 4: I/O ports at f040 [size=32]
Capabilities:
02:00.0 Network controller: Qualcomm Atheros Device 0042 (rev 31)
Subsystem: AzureWave Device 2231
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: Memory at 81000000 (64-bit, non-prefetchable) [size=2M]
Capabilities:
Quel pilote rajouter? Comment intégrer les réseaux disponibles à GnomeWifiManager?
Une autre application possible?
Remerciements anticipés.
