j’ai récemment fais l’acquisition de ce PC, sur lequel j’ai installé Debian Squeeze :
Linux debian 2.6.32-5-amd64 #1 SMP Mon Jan 16 16:22:28 UTC 2012 x86_64 GNU/Linux
Tout est niquel, sauf le wifi… D’ailleurs j’ai installé network-manager-gnome mais aucune icone n’apparait. Ca fait 3 jours que je cherches, j’ai essayé différentes manipulations mais rien y fait. voici quelque infos :
lspci :
00:00.0 Host bridge: Intel Corporation Sandy Bridge DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Sandy Bridge PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation Cougar Point HECI Controller #1 (rev 04)
00:1a.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation Cougar Point High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 1 (rev b5)
00:1c.2 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 3 (rev b5)
00:1c.4 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 5 (rev b5)
00:1d.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Cougar Point LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation Cougar Point 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation Cougar Point SMBus Controller (rev 05)
01:00.0 VGA compatible controller: nVidia Corporation Device 0df5 (rev a1)
02:00.0 Network controller: Intel Corporation Device 008a (rev 34)
03:00.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
iwconfig :
[code]lo no wireless extensions.
eth0 no wireless extensions.
pan0 no wireless extensions.
ifconfig -a :
[code]eth0 Link encap:Ethernet HWaddr 84:8f:69:ba:50:e1
inet adr:192.168.1.12 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::868f:69ff:feba:50e1/64 Scope:Lien
RX packets:11973 errors:0 dropped:0 overruns:0 frame:0
TX packets:8944 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13174084 (12.5 MiB) TX bytes:1349408 (1.2 MiB)
Interruption:28 Adresse de base:0xc000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)
pan0 Link encap:Ethernet HWaddr 2e:08:7c:68:34:5c
BROADCAST MULTICAST MTU:1500 Metric:1
j’ai suivi le wiki (http://wiki.debian.org/iwlagn#Squeeze) mais rien y fait ![]()
Je suis actuellement en ethernet, voici le contenu de /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eth0
#NetworkManager#iface eth0 inet dhcp
Je n’ai vraiment plus d’idées… quelqu’un pourrait-il m’aider? ![]()
Merci d’avance pour votre aide et n’hésitez pas à me demander quoi que se soit.
Cordialement
autant pour moi donc.
