Connexion wifi, presque
bonjour,
voilà, j’ai suivi vos conseils pour installer ma carte netgear MA521avec ndiswrapper, tout semble en place mais un léger problème persiste :slightly_smiling: : lorsque je veux pinguer ma gateway j’obtiens : destination host unreachable.
voilà ma config :
more /etc/network/interfaces
[color=red]# This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth1
auto wlan0
iface wlan0 inet static
address 192.168.0.6
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.100
wpa-conf managed
wpa-ap-scan 1
wpa-scan-ssid 1
wpa-ssid zerim[/color]
ifconfig
[color=red]lo Lien encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
wlan0 Lien encap:Ethernet HWaddr 00:09:5B:63:C0:84
inet adr:192.168.0.6 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::209:5bff:fe63:c084/64 Scope:Lien
RX packets:10 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:872 (872.0 b) TX bytes:468 (468.0 b)
Interruption:10 Mémoire:e2000000-e2000025
[/color]
iwconfig
wlan0 IEEE 802.11b ESSID:"zerim"
Mode:Managed Frequency:2.462 GHz Access Point: 00:09:5B:A9:E2:D2
Bit Rate:11 Mb/s Tx-Power:20 dBm Sensitivity=0/3
RTS thr:2432 B Fragment thr:2432 B
Encryption key:off
Power Management:off
Link Quality:37/100 Signal level:-72 dBm Noise level:-96 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:-541408449 Invalid misc:0 Missed beacon:0
iwlist wlan0 scan
lan0 Scan completed :
Cell 01 - Address: 00:09:5B:A9:E2:D2
ESSID:"zerim"
Protocol:IEEE 802.11b
Mode:Managed
Frequency:2.462 GHz (Channel 11)
Quality:43/100 Signal level:-68 dBm Noise level:-96 dBm
Encryption key:off
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s
Extra:bcn_int=100
Extra:atim=0
Désolé de répondre si tard, mais es tu sûr d’être en ip statique sur ton ap ?
Tu es sûr qu’une config genre
# The primary network interface allow-hotplug eth1 auto wlan0 iface wlan0 inet dhcp wpa-conf managed wpa-ap-scan 1 wpa-scan-ssid 1 wpa-ssid zerim ne passerait pas mieux ?
