Bonsoir,
Je voudrais packadeger openssh 4.6. J’ai modifier les fichiers changelog, control comme je pense il fallais, puis fait un debuild -S -sa -kMACLEFGPG, ensuite pbuilder create --distribution stable et le fatal
pbuilder build *dsc.
Voila l’erreur que ca m’a sortie:
make[2]: Entering directory `/tmp/buildd/openssh-4.6p1/openbsd-compat'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/tmp/buildd/openssh-4.6p1/openbsd-compat'
(cd scard && /usr/bin/make DESTDIR= install)
make[2]: Entering directory `/tmp/buildd/openssh-4.6p1/scard'
../mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share
/usr/bin/install -c -m 0644 ./Ssh.bin /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/Ssh.bin
make[2]: Leaving directory `/tmp/buildd/openssh-4.6p1/scard'
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/bin
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/sbin
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man1
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man1
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man5
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man5
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man8
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/share/man/man8
./mkinstalldirs /tmp/buildd/openssh-4.6p1/debian/openssh/usr/libexec
mkdir /tmp/buildd/openssh-4.6p1/debian/openssh/usr/libexec
(umask 022 ; ./mkinstalldirs /var/empty)
mkdir /var/empty
mkdir: cannot create directory `/var/empty': Permission denied
make[1]: *** [install-files] Error 1
make[1]: Leaving directory `/tmp/buildd/openssh-4.6p1'
make: *** [install] Error 2
pbuilder: Failed autobuilding of package
-> Aborting with an error
-> unmounting dev/pts filesystem
-> unmounting proc filesystem
-> cleaning the build env
-> removing directory /var/cache/pbuilder/build//23312 and its subdirectories
Jai executer ces commandes en root, j’ai de la place sur mes disques, je vois pas pourquoi il merde sur la création d’un /var/empty, et la dernière ligne “make[1]: Leaving directory `/tmp/buildd/openssh-4.6p1’” est ce dans mon /tmp ou celui du chroot? Car /tmp est monté en noexec.
Merci de votre coup de main
