Controleur de domaine samba avec ldap [résolu]
Bonjour à tous, alors voila mon probleme,
j’ai de monter un controleur de domaine samba avec l’authentification Ldap… donc à l’heure actuel j’en arrive là:
[code]debiam:/# net getlocalsid
[2008/02/19 14:23:37, 0] lib/smbldap.c:smbldap_connect_system(977)
failed to bind to server ldap://127.0.0.1 with dn=“cn=admin,dc=local,dc=org” Error: Invalid credentials
SID for domain DEBIAM is: S-1-5-21-1666131003-4134978410-775110116
avec:
debiam:/# ldapsearch -x -b "dc=local,dc=org" ldap_bind: Can't contact LDAP server (-1)
V’là mon smb.conf:
[code]# Samba config file created using SWAT
from 127.0.0.1 (127.0.0.1)
Date: 2008/01/22 17:10:12
[global]
log file = /var/log/samba/log.%m
passwd chat = Enter\snew\sUNIX\spassword: %n\n Retype\snew\sUNIX\spassword: %n\n password\supdated\ssuccessfully .
passwd program = /usr/bin/passwd%u
workgroup = local.org
netbios name = debiam
#include = /etc/samba/dhcp.conf
interfaces = 192.168.252.0/24
null passwords = yes
encrypt passwords = true
security = user
passdb backend = ldapsam:ldap://192.168.252.80
ldap suffix = dc=local,dc=org
ldap machine suffix = ou=machines
ldap user suffix=ou=users
ldap group suffix = ou=groups
    ldap admin dn = cn=admin,dc=local,dc=org
    ldap delete dn = yes
    obey pam restrictions=yes
    domain master = yes
    domain logons = yes
    ldap password sync=yes
    enable privileges=yes
dns proxy = No
    os level = 33
    preferred master = yes
    domain logons = yes
    logon script = logon.bat
    logon drive = Z:
    admin users = root @adm
    wins support = true
    name resolve order = lmhosts wins host bcast
server string = "Domain Controler DEBIAM"
default = kamkam
path = /home
remote announce = 192.168.252.0/local.org
os level = 20
comment = arf
valid users = kamel,@kamel
syslog = 0
panic action = /usr/share/samba/panic-action %d
max log size = 1000
   #smbtools
   add user script=/usr/sbin/smbldap-userass -m "%u"
   delete user script=/usr/sbin/smbldap-userdel "%u"
   add machine script=/usr/sbin/smbldap-useradd -w "%u"
   add group script=/usr/sbin/smbldap-groupadd -p "%g"
   delete group script=/usr/sbin/smbldap-groupdel "%g"
   add user to group script=/usr/sbin/smbldap-groupmod -m "%u" "%g"
   delete user from group script=/usr/sbin/smbldap-usermod -g "%g" "%u"
   set primary group script=/usr/sbin/smbldap-usermod -g "%g" "%u"
   passwd program=/usr/sbin/smbldap-passwd -u %u
[printers]
comment = All Printers
path = /var/spool/samba
create mask = 0700
printable = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
[netlogon]
domain master=yes
domain logons=yes
logon script=%U.bat
logon path=\debiam\windowsprofile%U
logon drive=U:
logon home=\debiam%U
path = /home/samba/netlogon
read only = yes
write list = administrateur
browseable=no
guest ok=yes
writable=no
share modes=no
[kamkam]
comment = ah
path = /home[/code]
et le sldap.conf:
[code]# Allow LDAPv2 binds
allow bind_v2
This is the main slapd configuration file. See slapd.conf(5) for more
info on the configuration options.
Global Directives:
Features to permit
allow bind_v2
Schema and objectClass definitions
include /etc/ldap/schema/core.schema
include /etc/ldap/schema/cosine.schema
include /etc/ldap/schema/nis.schema
include /etc/ldap/schema/inetorgperson.schema
include /etc/ldap/schema/samba.schema
Where the pid file is put. The init.d script
will not stop the server if you change this.
pidfile /var/run/slapd/slapd.pid
List of arguments that were passed to the server
argsfile /var/run/slapd/slapd.args
Read slapd.conf(5) for possible values
loglevel 0
Where the dynamically loaded modules are stored
modulepath /usr/lib/ldap
moduleload back_bdb
The maximum number of entries that is returned for a search operation
sizelimit 500
The tool-threads parameter sets the actual amount of cpu’s that is used
for indexing.
tool-threads 1
Specific Backend Directives for bdb:
Backend specific directives apply to this backend until another
‘backend’ directive occurs
backend bdb
checkpoint 512 30
Specific Backend Directives for ‘other’:
#backend
Specific Directives for database #1, of type bdb:
Database specific directives apply to this databasse until another
‘database’ directive occurs
database bdb
The base of your directory in database #1
suffix “dc=local,dc=org”
rootdn directive for specifying a superuser on the database. This is needed
for syncrepl.
rootdn "cn=admin,dc=local,dc=org"
rootpw {SSHA}tasC+EsCyV7EbPpE2HMOA2Wve1ZWEJI3
Where the database file are physically stored for database #1
directory “/var/lib/ldap”
For the Debian package we use 2MB as default but be sure to update this
value if you have plenty of RAM
dbconfig set_cachesize 0 2097152 0
Sven Hartge reported that he had to set this value incredibly high
to get slapd running at all. See http://bugs.debian.org/303057
for more information.
Number of objects that can be locked at the same time.
dbconfig set_lk_max_objects 1500
Number of locks (both requested and granted)
dbconfig set_lk_max_locks 1500
Number of lockers
dbconfig set_lk_max_lockers 1500
Indexing options for database #1
index objectClass eq
Save the time that the entry gets modified, for database #1
lastmod on
Where to store the replica logs for database #1
replogfile /var/lib/ldap/replog
The userPassword by default can be changed
by the entry owning it if they are authenticated.
Others should not be able to see it, except the
admin entry below
These access lines apply to database #1 only
access to attrs=userPassword,
by dn=“cn=admin,dc=local,dc=org” write
by anonymous auth
by self write
by * none
Ensure read access to the base for things like
supportedSASLMechanisms. Without this you may
have problems with SASL not knowing what
mechanisms are available and the like.
Note that this is covered by the ‘access to *’
access to dn.base=""
by * read
The admin dn has full write access, everyone else
can read everything.
access to *
by * read
For Netscape Roaming support, each user gets a roaming
profile for which they have write access to
#access to dn=".*,ou=Roaming,o=morsnet"
by dnattr=owner write
Specific Directives for database #2, of type ‘other’ (can be bdb too):
#database
The base of your directory for database #2
#suffix “dc=debian,dc=org”[/code]
Si quelqu’un à une idée…
Merçi!
bon finalement j’ai reconfigurer mes fichiers .conf,
l’annuaire ldap répond comme il faut sans message d’erreur, et
le serveur samba aussi en fesant un net getlocalsid il ne me renvoi pas d’érreur, mais quand je connecte un client Windows, il ne trouve pas le chemin soit l’utilisateur est inconnue, pourtant c’est un utilisateur du domaine dans samba et ldap…
donc, je continue… :wink:
me fallait ajouter l’utilisateur comme ça:
#useradd -g nom_du_groupe user1
#smbpasswd -a user
voila… :wink:
