je cherche a envoyer un fichier en scp sur mon serveur
la connexion ce fait bien il me demande un password
puis le transfert ne bouge plus
voici les log
christopher@Ubuntu:~$ scp -v /home/christopher/docker.tar.gz christopher@xx.xx.xx.234:/home/christopher/
Executing: program /usr/bin/ssh host xx.xx.xx.234, user christopher, command scp -v -t /home/christopher/
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to xxxxxxxxxxx [192.xxxxxxxxxxx] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/christopher/.ssh/id_rsa type -1
debug1: identity file /home/christopher/.ssh/id_rsa-cert type -1
debug1: identity file /home/christopher/.ssh/id_dsa type -1
debug1: identity file /home/christopher/.ssh/id_dsa-cert type -1
debug1: identity file /home/christopher/.ssh/id_ecdsa type -1
debug1: identity file /home/christopher/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/christopher/.ssh/id_ed25519 type -1
debug1: identity file /home/christopher/.ssh/id_ed25519-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.9p1 Debian-10
debug1: match: OpenSSH_7.9p1 Debian-10 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.66.234:22 as 'christopher'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:yTODnG5Z/CM8TxxxxxxxxxxxV8UnlMRaB3wuNHUQ8AcYmBo
debug1: Host '192.168.66.234' is known and matches the ECDSA host key.
debug1: Found key in /home/christopher/.ssh/known_hosts:5
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/christopher/.ssh/id_rsa
debug1: Trying private key: /home/christopher/.ssh/id_dsa
debug1: Trying private key: /home/christopher/.ssh/id_ecdsa
debug1: Trying private key: /home/christopher/.ssh/id_ed25519
debug1: Next authentication method: password
christopher@19xxxxxxx4's password:
debug1: Authentication succeeded (password).
Authenticated to 1xxxxxxxxx ([xxxxxxxxxxxxxxxxxx]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Sending environment.
debug1: Sending env LANG = fr_FR.UTF-8
debug1: Sending command: scp -v -t /home/christopher/
Sending file modes: C0777 4632934 docker.tar.gz
Sink: C0777 4632934 docker.tar.gz
docker.tar.gz
