Merci d’avoir répondu aussi rapidement
L’applet qui produit le message d’erreur au démarrage de ma session est le moniteur de changement de fréquence du processeur. Quant à la version du noyau c’est : 2.6.18-4-686
Ni powernowd ni cpufreqd n’étaient installés car je suis sur une installation fraîche.
Après installation et lancement de powernowd, voici le résultat :
[code]powernowd: PowerNow Daemon v0.97, © 2003-2006 John Clemens
/sys/devices/system/cpu/cpu0/cpufreq/affected_cpus: No such file or directory
powernowd: err=2
powernowd: Found 1 scalable unit: – 2 ‘CPUs’ per scalable unit
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq: No such file or directory
PowerNowd encountered and error and could not start.
Please make sure that:
- You are running a v2.6.7 kernel or later
- That you have sysfs mounted /sys
- That you have the core cpufreq and cpufreq-userspace
modules loaded into your kernel
- That you have the cpufreq driver for your cpu loaded,
(for example: powernow-k7), and that it works. Check
’dmesg’ for errors.
If all of the above are true, and you still have problems,
please email the author: clemej@alum.rpi.edu
J’ai donc tapé la commande dmesg (attention c’est long…)
[code]Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed May 9 23:03:12 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001bff0000 (usable)
BIOS-e820: 000000001bff0000 - 000000001bffffc0 (ACPI data)
BIOS-e820: 000000001bffffc0 - 000000001c000000 (ACPI NVS)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
447MB LOWMEM available.
On node 0 totalpages: 114672
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 110576 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 OID_00 ) @ 0x000e6010
ACPI: RSDT (v001 INSYDE RSDT_000 0x00000001 CSI 0x00010101) @ 0x1bffb0eb
ACPI: FADT (v001 INSYDE FACP_000 0x00000100 CSI 0x00010101) @ 0x1bfffa90
ACPI: MADT (v001 INSYDE APIC_000 0x30303030 0000 0x30303030) @ 0x1bfffb20
ACPI: BOOT (v001 INSYDE SYS_BOOT 0x00000100 CSI 0x00010101) @ 0x1bfffb90
ACPI: SSDT (v001 PmRef CpuPm 0x00003000 INTL 0x20030522) @ 0x1bffb11f
ACPI: DSDT (v001 TOSINV Avani2 0x00001004 MSFT 0x0100000e) @ 0x00000000
ATI board detected. Disabling timer routing over 8254.
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:4 APIC version 20
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Processor #1 15:4 APIC version 20
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 21 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 20000000 (gap: 1c000000:e3f80000)
Detected 3066.937 MHz processor.
Built 1 zonelists. Total pages: 114672
Kernel command line: root=/dev/hda2 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 446640k/458688k available (1544k kernel code, 11476k reserved, 577k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 6136.74 BogoMIPS (lpj=12273494)Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 0000459d 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000 0000459d 00000000 00000000
monitor/mwait feature present.
using mwait in idle threads.
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 1024K
CPU: Physical Processor ID: 0
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000180 0000459d 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
CPU0: Intel Mobile Intel® Pentium® 4 CPU 3.06GHz stepping 01
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine… 6134.02 BogoMIPS (lpj=12268052)CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 0000459d 00000000 00000000
Intel machine check reporting enabled on CPU#1.
CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
CPU1: Thermal monitoring enabled
CPU1: Intel Mobile Intel® Pentium® 4 CPU 3.06GHz stepping 01
Total of 2 processors activated (12270.77 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
…MP-BIOS bug: 8254 timer not connected to IO-APIC
…trying to set up timer (IRQ0) through the 8259A … failed.
…trying to set up timer as Virtual Wire IRQ… works.
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
migration_cost=316
checking if image is initramfs… it is
Freeing initrd memory: 4778k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xe9964, last bus=2
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [_SB.PCI0] bus is 0
PCI: Ignoring BAR0-3 of IDE controller 0000:00:14.1
Boot video device is 0000:01:05.0
PCI: Transparent bridge - 0000:00:14.4
PCI: Bus #03 (-#06) is hidden behind transparent bridge #02 (-#02) (try ‘pci=assign-busses’)
Please report the result to linux-kernel to fix this permanently
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.AGP.PRT]
ACPI: PCI Interrupt Link [LNK0] (IRQs 5 7 10 *11)
ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 *10 11)
ACPI: PCI Interrupt Link [LNK2] (IRQs 5 7 *10 11)
ACPI: PCI Interrupt Link [LNK3] (IRQs *5 7 10 11)
ACPI: Embedded Controller [EC0] (gpe 7) interrupt mode.
ACPI: Power Resource [PUT2] (on)
ACPI: PCI Interrupt Routing Table [_SB.PCI0.P2P_._PRT]
ACPI: Power Resource [PFA1] (off)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 11 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
pnp: 00:07: ioport range 0x200-0x20f has been reserved
pnp: 00:07: ioport range 0x280-0x29f has been reserved
pnp: 00:07: ioport range 0x40b-0x40b has been reserved
PCI: Bridge: 0000:00:01.0
IO window: c000-dfff
MEM window: e0000000-efffffff
PREFETCH window: a0000000-afffffff
PCI: Bus 3, cardbus bridge: 0000:02:06.0
IO window: 0000a400-0000a4ff
IO window: 0000a800-0000a8ff
PREFETCH window: 90000000-91ffffff
MEM window: d2000000-d3ffffff
PCI: Bridge: 0000:00:14.4
IO window: a000-bfff
MEM window: d0000000-dfffffff
PREFETCH window: 90000000-9fffffff
ACPI: PCI Interrupt 0000:02:06.0[A] -> GSI 19 (level, low) -> IRQ 177
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x37 set to 0x1
audit: initializing netlink socket (disabled)
audit(1187361385.228:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A
ACPI: PCI Interrupt 0000:00:14.6[B] -> GSI 17 (level, low) -> IRQ 185
ACPI: PCI interrupt for device 0000:00:14.6 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard as /class/input/input0
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Starting balanced_irq
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
ACPI: Transitioning device [FAN1] to D3
ACPI: Fan [FAN1] (off)
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Cst] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Cst] [20060707]
ACPI: Thermal Zone [THZN] (67 C)
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ATIIXP: IDE controller at PCI slot 0000:00:14.1
ACPI: PCI Interrupt 0000:00:14.1[A] -> GSI 16 (level, low) -> IRQ 193
ATIIXP: chipset revision 0
ATIIXP: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x8070-0x8077, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x8078-0x807f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0…
ohci_hcd: 2005 April 22 USB 1.1 ‘Open’ Host Controller (OHCI) Driver (PCI)
8139too Fast Ethernet driver 0.9.27
ieee1394: Initialized config rom entry `ip1394’
hda: FUJITSU MHT2040AT, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hdc: MATSHITADVD-RAM UJ-820S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 19 (level, low) -> IRQ 177
ohci_hcd 0000:00:13.0: OHCI Host Controller
ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:13.0: irq 177, io mem 0xf0001000
hda: max request size: 128KiB
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
hda: 78140160 sectors (40007 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 hda3 < hda5 hda6 >
hdc: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ACPI: PCI Interrupt 0000:00:13.1[A] -> GSI 19 (level, low) -> IRQ 177
ohci_hcd 0000:00:13.1: OHCI Host Controller
ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:13.1: irq 177, io mem 0xf0002000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
PCI: Enabling device 0000:00:13.2 (0000 -> 0002)
ACPI: PCI Interrupt 0000:00:13.2[A] -> GSI 19 (level, low) -> IRQ 177
ehci_hcd 0000:00:13.2: EHCI Host Controller
ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
ehci_hcd 0000:00:13.2: irq 177, io mem 0x20000000
ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 6 ports detected
ACPI: PCI Interrupt 0000:02:0a.0[A] -> GSI 19 (level, low) -> IRQ 177
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[177] MMIO=[d0000000-d00007ff] Max Packet=[2048] IR/IT contexts=[4/8]
ACPI: PCI Interrupt 0000:02:07.0[A] -> GSI 18 (level, low) -> IRQ 201
eth0: RealTek RTL8139 at 0xa000, 00:a0:d1:b6:81:2a, IRQ 201
eth0: Identified 8139 chip type 'RTL-8100B/8139D’
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
Attempting manual resume
ohci_hcd 0000:00:13.0: wakeup
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
usb 1-3: new low speed USB device using ohci_hcd and address 3
usb 1-3: configuration #1 chosen from 1 choice
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00080da0d1b6812a]
eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected Ati IGP7000/M chipset
agpgart: AGP aperture is 64M @ 0xb0000000
input: PC Speaker as /class/input/input1
piix4_smbus 0000:00:14.0: Found 0000:00:14.0 device
Real Time Clock Driver v1.12ac
Yenta: CardBus bridge found at 0000:02:06.0 [1179:ff10]
Yenta: Using CSCINT to route CSC interrupts to PCI
Yenta: Routing CardBus interrupts to PCI
Yenta TI: socket 0000:02:06.0, mfunc 0x01111122, devctl 0x64
usbcore: registered new driver hiddev
input: Microsoft Microsoft Notebook/Mobile Optical Mouse 2.0 as /class/input/input2
input: USB HID v1.10 Mouse [Microsoft Microsoft Notebook/Mobile Optical Mouse 2.0] on usb-0000:00:13.0-3
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
irda_init()
NET: Registered protocol family 23
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
Yenta: ISA IRQ mask 0x0c78, PCI irq 177
Socket status: 30000006
Yenta: Raising subordinate bus# of parent bus (#02) from #02 to #06
pcmcia: parent PCI bridge I/O window: 0xa000 - 0xbfff
cs: IO port probe 0xa000-0xbfff: clean.
pcmcia: parent PCI bridge Memory window: 0xd0000000 - 0xdfffffff
pcmcia: parent PCI bridge Memory window: 0x90000000 - 0x9fffffff
ts: Compaq touchscreen protocol output
PCI: Enabling device 0000:00:14.6 (0000 -> 0002)
atiixp-modem: codec reset timeout
ACPI: PCI Interrupt 0000:00:14.5[B] -> GSI 17 (level, low) -> IRQ 185
Synaptics Touchpad, model: 1, fw: 5.9, id: 0xa56eb1, caps: 0x804713/0x0
synaptics: Toshiba Satellite A60 detected, limiting rate to 40pps.
input: SynPS/2 Synaptics TouchPad as /class/input/input3
cs: IO port probe 0x100-0x3af: excluding 0x220-0x227 0x300-0x307 0x310-0x317
cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: excluding 0xc00-0xc07 0xc10-0xc17 0xc50-0xc57 0xc68-0xc6f 0xcd0-0xcd7
cs: IO port probe 0xa00-0xaff: clean.
Adding 1148608k swap on /dev/hda5. Priority:-1 extents:1 across:1148608k
EXT3 FS on hda2, internal journal
loop: loaded (max 8 devices)
SCSI subsystem initialized
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
EXT3 FS on hda6, internal journal
pcmcia: Detected deprecated PCMCIA ioctl usage from process: discover.
pcmcia: This interface will soon be removed from the kernel; please expect breakage unless you upgrade to new tools.
pcmcia: see http://www.kernel.org/pub/linux/utils/kernel/pcmcia/pcmcia.html for details.
eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Battery Slot [BAT1] (battery present)
ACPI: AC Adapter [AC] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
ACPI: Power Button (CM) [PWRB]
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:01:05.0[A] -> GSI 16 (level, low) -> IRQ 193
[drm] Initialized radeon 1.25.0 20060524 on minor 0
mtrr: 0xa0000000,0x8000000 overlaps existing 0xa0000000,0x4000000
agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V2 device at 0000:01:05.0 into 4x mode
[drm] Setting GART location based on new memory map
[drm] writeback test succeeded in 1 usecs
eth1: no IPv6 routers present
Edit : Je n’avais pas vu le post de mattotop
Donc pour la commande cat /proc/cpuinfo, cela donne :
[code]processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 4
model name : Mobile Intel® Pentium® 4 CPU 3.06GHz
stepping : 1
cpu MHz : 3066.937
cache size : 1024 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe constant_tsc pni monitor ds_cpl est tm2 cid xtpr
bogomips : 6136.74
processor : 1
cpu family : 15
model : 4
stepping : 1
cpu MHz : 3066.937
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 6134.02
La commande uname -r me renvoie :
2.6.18-4-686
