Salut !
J’ai (correctement je crois) installé cpufreqd sur mon DELL Inspiron 8600c en remplacement de i8k qui ne lit pas correctement les infos du BIOS et qui ne gère pas correctement le processeur.
cpufreqd a été configuré et , lorsque je débranche le câble d’alimentation secteur, mon cpu baisse sa fréquence à environ 400Mhz contre 1700Mhz à pleine vitesse… Cependant, au bout de quelques secondes seulement, il passe à la fréquence max et y reste…
Avez-vous une idée du problème ?
Cordialement,
Joel
cpufreqd.conf**
this is a comment
you need: 1 [General] section,
1 or more [Profile] sections
1 or more [Rule] sections
a section ends at the first blank line
[Rule] sample:
[Rule]
name=sample_rule
ac=on # (on/off)
battery_interval=0-10
cpu_interval=30-60
programs=xine,mplayer
profile=sample_profile
[Profile] sample:
[Profile]
name=sample_profile
minfreq=10%
maxfreq=100%
policy=performance
see CPUFREQD.CONF(5) manpage for a complete reference
[General]
pidfile=/var/run/cpufreqd.pid
poll_interval=2
pm_type=acpi #(acpi, apm or pmu)
Uncomment the following line to enable ACPI workaround (see cpufreqd.conf(5))
acpi_workaround=1
verbosity=4 #(if you want a minimal logging set to 5)
[Profile]
name=hi_boost
minfreq=12.6%
maxfreq=100%
policy=performance
[Profile]
name=medium_boost
minfreq=12.6%
maxfreq=66%
policy=performance
[Profile]
name=lo_boost
minfreq=12.6%
maxfreq=33%
policy=performance
[Profile]
name=lo_power
minfreq=12.6%
maxfreq=33%
policy=powersave
conservative mode when not AC
[Rule]
name=conservative
ac=off # (on/off)
battery_interval=0-100
cpu_interval=0-40
profile=lo_power
need some power
[Rule]
name=lo_cpu_boost
ac=off # (on/off)
cpu_interval=30-80
profile=medium_boost
need big power (not if battery very low)
[Rule]
name=hi_cpu_boost
ac=off # (on/off)
battery_interval=50-100
cpu_interval=70-100
full power when AC
[Rule]
name=AC_on
ac=on # (on/off)
profile=hi_boost
full power when watching DVDs and not AC:
this is the last rule and takes less
precedence with respect to the others
[Rule]
name=dvd_watching
ac=off # (on/off)
programs=xine,mplayer,avidemux,vlc
cpu_interval=0-100
profile=hi_boost
fin cpufreqd.conf*******
