Lorsque je lance eclipse 4.2 Juno (la même chose avec eclipse 3.6 mais plus rapide), l’application se plante sans avertissement en laissant un fichier:
il se passe la même chose avec les différentes machines virtuelles :
java-7-openjdk-amd64
j2sdk1.6-oracle
jdk-7-oracle-x64
un extrait du fichier hs_err_pid5755.log (en pièce jointe).
Je suis en Jessie/sid
Si vous avez besoin d’autres informations n’hésitez pas a me demander.
Je suis a sec.
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fc123c82718, pid=5755, tid=140467817449216
# JRE version: OpenJDK Runtime Environment (7.0_65-b32) (build 1.7.0_65-b32)
# Java VM: OpenJDK 64-Bit Server VM (24.65-b04 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libgobject-2.0.so.0+0x19718] g_object_get_qdata+0x18
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please include
# instructions on how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00007fc13000a800): JavaThread "main" [_thread_in_native, id=5756, stack(0x00007fc1364c8000,0x00007fc1365c9000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000000000c10
Registers:
RAX=0x0000000000000c10, RBX=0x00007fc130c74390, RCX=0x0000000000000330, RDX=0x00007fc130c74390
RSP=0x00007fc1365c57b0, RBP=0x0000000000000330, RSI=0x0000000000000330, RDI=0x00007fc130c74390
R8 =0x00000000f0050db0, R9 =0x0000000000000000, R10=0x00007fc12bf89d6c, R11=0x00007fc135246c40
R12=0x0000000000000000, R13=0x0000000740b62600, R14=0x00007fc1365c5868, R15=0x00007fc13000a800
RIP=0x00007fc123c82718, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Merci de votre aide.
Eric
LSOFF.crash-Java.txt (12.7 KB)
hs_err_pid5755.log (146 KB)
