Cross-compilation de libavg
je veux faire l’operation de cross-compilation libavg-1.7.0
les etapes suivis sont:
$ sudo /usr/share/pdebuild-cross/xapt -a armel libpango1.0-dev libavformat-dev libavcodec-dev libswscale-dev python2.6-dev libboost-python-dev libboost-thread-dev libglu-dev libgl1-mesa-dev libgtk2.0-dev libglib2.0-dev libsdl-dev libxml2-dev libxxf86vm-dev libcairo-dev librsvg2-dev --force-yes
cat configure | sed s/-msse2// > configure.arm
mv configure.arm configure
chmod 755 configure
Edit src/base/Exception.cpp and replace debugBreak code by :
void debugBreak()
#ifndef arm
#ifdef _WIN32
__asm int 3;
#else
asm(“int $3”);
#endif
#else
asm(“swi 0x03”);
#endif
export PANGOFT2_CFLAGS="-I/usr/arm-linux-gnueabi/include/“
export PANGOFT2_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export GDK_PIXBUF_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export GDK_PIXBUF_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export LIBRSVG_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export LIBRSVG_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export FONTCONFIG_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export FONTCONFIG_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export FFMPEG_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export FFMPEG_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export BOOST_PYTHON_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export BOOST_PYTHON_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export AVCODEC_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export AVCODEC_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export MTDEV_LIBS=”-L/usr/arm-linux-gnueabi/lib/“
export MTDEV_CFLAGS=”-I/usr/arm-linux-gnueabi/include/“
export BOOST_THREAD_LIB=”-L/usr/arm-linux-gnueabi/lib/“
export BOOST_THREAD_CFLAGS=”-I/usr/arm-linux-gnueabi/include/"
export CROSSTOOL=arm-linux-gnueabi
export CXX=$CROSSTOOL-g+±4.4
export CC=$CROSSTOOL-gcc-4.4
export AR=$CROSSTOOL-ar
export AS=$CROSSTOOL-as
CFLAGS="-I/usr/arm-linux-gnueabi/include/gtk-2.0 -I/usr/arm-linux-gnueabi/include/glib-2.0" CXXFLAGS="-I/usr/arm-linux-gnueabi/include/gtk-2.0 -I/usr/arm-linux-gnueabi/include/glib-2.0/ -I/usr/arm-linux-gnueabi/lib/glib-2.0/include/ -I/usr/arm-linux-gnueabi/include/pango-1.0 -I/usr/arm-linux-gnueabi/include/cairo/ -I/usr/arm-linux-gnueabi/include/librsvg-2" LDFLAGS="-lgdk_pixbuf-2.0 -lavcodec -lavutil -lavformat -lswscale -lSDL -lpango-1.0 -lpangoft2-1.0 -lrsvg-2 " FREETYPE_LIBS=/usr/arm-linux-gnueabi/lib ./configure --target=arm-linux-gnueabi --host=arm-linux-gnueabi CC=arm-linux-gnueabi-gcc-4.4 CXX=$CROSSTOOL-g+±4.4 AR=arm-linux-gnueabi-ar TRIP=arm-linux-gnueabi-strip RANLIB=arm-linux-gnueabi-ranlib --with-sdl-prefix=/usr/arm-linux-gnueabi --prefix=/home/administrateur/Bureau/out
- make et make install
Lorsque j’exécute la commande make je recois le message d’erreur suivant:
make[3]: entrant dans le répertoire « /home/invitee/Bureau/conf/libavg-1.7.1/src/base »
CXX FileHelper.lo
CXX CmdLine.lo
CXX Exception.lo
CXX Logger.lo
CXX ConfigMgr.lo
CXX XMLHelper.lo
CXX TimeSource.lo
CXX OSHelper.lo
CXX ProfilingZone.lo
CXX ThreadProfiler.lo
CXX ScopeTimer.lo
CXX Test.lo
CXX TestSuite.lo
CXX ObjectCounter.lo
CXX Point.lo
CXX Directory.lo
CXX DirEntry.lo
CXX StringHelper.lo
CXX MathHelper.lo
CXX GeomHelper.lo
CXX CubicSpline.lo
CXX BezierCurve.lo
CXX UTF8String.lo
CXX Triangle.lo
CXX Triangulate.lo
CXX WideLine.lo
CXX Triple.lo
CXX Backtrace.lo
CXX Matrix3x4.lo
CXX ProfilingZoneID.lo
CXXLD libbase.la
CXX testbase.o
CXXLD testbase
/usr/lib/gcc/arm-linux-gnueabi/4.4.5/…/…/…/…/arm-linux-gnueabi/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
make[3]: *** [testbase] Erreur 1
make[3]: quittant le répertoire « /home/invitee/Bureau/conf/libavg-1.7.1/src/base »
make[2]: *** [all-recursive] Erreur 1
make[2]: quittant le répertoire « /home/invitee/Bureau/conf/libavg-1.7.1/src »
make[1]: *** [all] Erreur 2
make[1]: quittant le répertoire « /home/invitee/Bureau/conf/libavg-1.7.1/src »
make: *** [all-recursive] Erreur
Information sur la distrubition
noyau employé : Linux debian 2.6.32-5-686 #1 SMP Mon Feb 25 01:04:36 UTC 2013 i686 GNU/Linux
lspci :
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:02.0 VGA compatible controller: InnoTek Systemberatung GmbH VirtualBox Graphics Adapter
00:03.0 Ethernet controller: Intel Corporation 82540EM Gigabit Ethernet Controller (rev 02)
00:04.0 System peripheral: InnoTek Systemberatung GmbH VirtualBox Guest Service
00:05.0 Multimedia audio controller: Intel Corporation 82801AA AC’97 Audio Controller (rev 01)
00:06.0 USB Controller: Apple Computer Inc. KeyLargo/Intrepid USB
00:07.0 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 08)
00:0d.0 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 02)
merci d’avoir m’aider
