j’ai un problème avec mon serveur d’impression CUPS : lorsque je lance mon navigateur pour accéder à l’interface de configuration de CUPS, voici ce que j’ai : “Impossible de se connecter : Connexion refusée”
j’ai bien tenté de me dépanner mais là je sèche…
je suis sous debian 8 (jessie)
voici la liste des paquets installés :
ii cups 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD/driver support, web interface
ii cups-browsed 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - cups-browsed
ii cups-bsd 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - BSD commands
ii cups-client 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - client programs (SysV)
ii cups-common 1.7.5-11+deb8u1 all Common UNIX Printing System(tm) - common files
ii cups-core-drivers 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD-less printing
ii cups-daemon 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - daemon
ii cups-filters 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - Main Package
ii cups-filters-core-drivers 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - PPD-less printing
ii cups-pk-helper 0.2.5-2+b1 amd64 PolicyKit helper to configure cups with fine-grained privileges
ii cups-ppdc 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD manipulation utilities
ii cups-server-common 1.7.5-11+deb8u1 all Common UNIX Printing System(tm) - server common files
ii libcups2:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - Core library
ii libcupscgi1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - CGI library
ii libcupsfilters1:amd64 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - Shared library
ii libcupsimage2:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - Raster image library
ii libcupsmime1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - MIME library
ii libcupsppdc1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD manipulation library
ii python-cups 1.9.63-1 amd64 Python bindings for CUPS
ii python-cupshelpers 1.4.6-1 all Python utility modules around the CUPS printing system
Le serveur cups fonctionne :
# service cups status
● cups.service - CUPS Printing Service
Loaded: loaded (/lib/systemd/system/cups.service; enabled)
Active: active (running) since ven. 2016-01-29 11:20:13 CET; 8min ago
Docs: man:cupsd(8)
man:cupsd.conf(5)
Main PID: 542 (cupsd)
CGroup: /system.slice/cups.service
└─542 /usr/sbin/cupsd -f
un netstat ne me répond rien par contre nmap oui :
# nmap -p 631 127.0.0.1
Starting Nmap 6.47 ( http://nmap.org ) at 2016-01-29 11:29 CET
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000094s latency).
PORT STATE SERVICE
631/tcp closed ipp
j’ai bien sûr tenté de le réinstaller après l’avoir purgé…
une idée ?
