Hi all,
On imaps connection from my Outlook to cyrus2.2.13 autocreate patched, i got this error :
cyrus/master[2619]: about to exec /usr/lib/cyrus/bin/imapd
cyrus/imaps[2619]: executed
cyrus/imaps[2619]: accepted connection
cyrus/imaps[2619]: unable to get private key from '/etc/ssl/private/ssl-cert-cyrus.key’
cyrus/imaps[2619]: TLS server engine: cannot load cert/key data, may be a cert/key mismatch?
cyrus/imaps[2619]: error initializing TLS
cyrus/imaps[2619]: Fatal error: tls_init() failed
cyrus/imaps[2619]: DBERROR db4: Database handles open during environment close
cyrus/imaps[2619]: DBERROR: error exiting application: Invalid argument
cyrus/master[2283]: process 2619 exited, status 75
cyrus/master[2283]: service imaps pid 2619 in BUSY state: terminated abnormally
Can’t, of course, connect to my imap box. Connections are OK if i comment tls_cert_* but i need to use encryption.
smtps work properly with my postfix2.3.8 under TLS with same pem/key/ca files.
My imapd.conf :
File containing the global certificate used for ALL services tls_cert_file: /etc/ssl/certs/ssl-cert-cyrus.pem
File containing the private key belonging to the global server certificate.
tls_key_file: /etc/ssl/private/ssl-cert-cyrus.key
File containing one or more Certificate Authority (CA) certificates.
tls_ca_file: /etc/ssl/certs/cyrus-ca.pem
Path to directory with certificates of CAs.
tls_ca_path: /etc/ssl/certs
Thanks for any help.
Regards,
