D-Link dwl-510 debian wheezy / rt2561
Bonsoir,
Je n’arrive pas à faire fonctionner ma carte wifi D-Link dwl-510 sous debian wheezy
lspci
J’ai pourtant bien installé les firmware.
Voici le message de dmesg
[ 29.559439] rt61pci 0000:01:00.0: firmware: requesting rt2561.bin [ 29.642111] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 34.709517] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 37.926165] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 38.107878] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 38.264616] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 41.516239] wlan0: direct probe to AP 5c:33:8e:cd:3c:7a (try 1) [ 41.712078] wlan0: direct probe to AP 5c:33:8e:cd:3c:7a (try 2) [ 41.912095] wlan0: direct probe to AP 5c:33:8e:cd:3c:7a (try 3) [ 42.112065] wlan0: direct probe to AP 5c:33:8e:cd:3c:7a timed out [ 80.724831] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 80.893101] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 84.750146] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Donc à priori
Pourtant j’ai installé le paquet contenant ce fichier
root@debian:/home/tristan# dpkg -i /media/ecole/firmware-ralink_0.36+wheezy.1_all.deb Sélection du paquet firmware-ralink précédemment désélectionné. (Lecture de la base de données... 48328 fichiers et répertoires déjà installés.) Dépaquetage de firmware-ralink (à partir de .../firmware-ralink_0.36+wheezy.1_all.deb) ... Paramétrage de firmware-ralink (0.36+wheezy.1) ... root@debian:/home/tristan# modprobe rt61pci root@debian:/home/tristan# modinfo rt61pci filename: /lib/modules/2.6.32-5-686/kernel/drivers/net/wireless/rt2x00/rt61pci.ko license: GPL firmware: rt2661.bin firmware: rt2561s.bin firmware: rt2561.bin description: Ralink RT61 PCI & PCMCIA Wireless LAN driver. version: 2.3.0 author: http://rt2x00.serialmonkey.com srcversion: 58CB8FB9B8C50DC7068D2D6 alias: pci:v00001814d00000401sv*sd*bc*sc*i* alias: pci:v00001814d00000302sv*sd*bc*sc*i* alias: pci:v00001814d00000301sv*sd*bc*sc*i* depends: rt2x00lib,rt2x00pci,eeprom_93cx6,crc-itu-t vermagic: 2.6.32-5-686 SMP mod_unload modversions 686 parm: nohwcrypt:Disable hardware encryption. (bool)
Le module est bien chargé crc_itu_t 1035 1 rt61pci ac97_bus 710 1 snd_ac97_codec rt2x00pci 3773 1 rt61pci rt2x00lib 19101 2 rt61pci,rt2x00pci
ça semble rouler côté réseau[code]
root@debian:/home/tristan# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0e:a6:f0:a8:f9
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:118 errors:0 dropped:0 overruns:0 frame:0
TX packets:118 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8172 (7.9 KiB) TX bytes:8172 (7.9 KiB)
wlan0 Link encap:Ethernet HWaddr 00:19:5b:78:c9:7f
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)[/code]
Par contre iwlist scanning ne me retourne rien, bien entendu
Le kernel c’est 2.6.32.
Une piste ? Des idées ?
Merci d’avance
Je pense que tu fais fausse route. Ton firmware est bien installé, sinon tu aurais un “firmware not found”.
si tu fais un down puis un up sur wlan0, qu’est ce que ça donne ?
ça ne change rien.
Par contre je me demande suis ce n’est pas une question de distance entre le PC et la box , c’est possible ?
pas de message d’erreur ?
Au niveau distance, en dessous de 15 m, ça doit capter.
non pas de message d’erreur
Ai réinstallé le paquet avec une connexion filaire et là ça roule, la carte fonctionne. Mais n’arrête pas de décrocher !
Ai mis une NETGEAR W1100 qui trainait, elle fait l’affaire.
Désolé du bruit
Thx
