OK
Mais le fstab pourrait être à l’origine du problème d’accès lors de la copie de fichiers ?
[quote]# /etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
proc /proc proc defaults 0 0
/ was on /dev/sda1 during installation
UUID=d0a3a60b-8c63-4e69-b048-69794863cb72 / ext4 errors=remount-ro 0 1
/data1 was on /dev/md0 during installation
UUID=a4f23418-3016-4097-a27a-4c970050452a /data1 ext3 defaults 0 2
/data2 was on /dev/md1 during installation
UUID=9fe28452-693f-4715-909b-3211e39795d0 /data2 ext3 defaults 0 2
/data3 was on /dev/sdf1 during installation
UUID=0e4d076d-f9e8-4e4b-9390-dc48ee414bf9 /data3 ext4 defaults 0 2
/home was on /dev/sda8 during installation
UUID=807e5910-7853-4db3-a16e-71dc9b132c28 /home ext4 defaults 0 2
/opt was on /dev/sda7 during installation
UUID=cb1850f6-1848-4dd3-a6b9-c7b9bfbd064a /opt ext4 defaults 0 2
/sauvegarde3 was on /dev/sdg1 during installation
UUID=1a5ae18a-d6c6-41fb-a825-33e040db8ffe /sauvegarde3 ext4 defaults 0 2
/tmp was on /dev/sda6 during installation
UUID=8b6b3abd-47bd-4adf-8ee8-ee5b0b31be55 /tmp ext4 defaults 0 2
/usr was on /dev/sda3 during installation
UUID=c1efb532-af4d-4e69-aadb-2f1888d0f6a7 /usr ext4 defaults 0 2
/var was on /dev/sda5 during installation
UUID=50ad06a4-5072-49fa-9493-5fe58c17b8f1 /var ext4 defaults 0 2
swap was on /dev/sda2 during installation
UUID=1d0e72ab-17b7-479e-a3c5-dffd86187631 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto 0 0
