Debian 11 kde 5.2 freeze
Depuis qq mois le système se bloque partiellement pendant qq secondes, voir qq minutes, puis revient.
J’ai lancé un reboot en tant que root mais le système n’a pu s’arrêter correctement, j’ai du éteindre électriquement.
A la remise sous tension le système semble charger correctement mais j’ai trouvé de nombreux messages d’erreurs dans syslog:
Nov 16 22:53:52 kmcs kernel: [    0.131268] unchecked MSR access error: RDMSR from 0x123 at rIP: 0xffffffffb486e6e4 (native_read_msr+0x4/0x30)
Nov 16 22:53:52 kmcs kernel: [    0.131308] unchecked MSR access error: WRMSR to 0x123 (tried to write 0x0000000000000001) at rIP: 0xffffffffb486e784 (native_write_msr+0x4/0x20)
Nov 16 22:53:52 kmcs kernel: [    0.429454] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [SAC1] at bit offset/length 64/64 exceeds size of target Buffer (64 bits) (20200925/dsopcode-198)
Nov 16 22:53:52 kmcs kernel: [    0.476235] ACPI: 8 ACPI AML tables successfully acquired and loaded
Nov 16 22:53:52 kmcs kernel: [    0.478001] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200925/nsinit-411)
Nov 16 22:53:52 kmcs systemd[1]: Starting Self Monitoring and Reporting Technology (SMART) Daemon...
Nov 16 22:53:52 kmcs kernel: [    0.478005] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200925/nsinit-419)
Nov 16 22:53:52 kmcs /usr/sbin/gpm[656]: *** info [daemon/startup.c(131)]:
Nov 16 22:53:52 kmcs kernel: [    0.491003] ACPI: Dynamic OEM Table Load:
Nov 16 22:53:52 kmcs kernel: [    0.491017] ACPI: SSDT 0xFFFF9CD5C1443800 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
Nov 16 22:53:52 kmcs kernel: [    0.492167] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200925/nsinit-411)
Nov 16 22:53:52 kmcs kernel: [    0.492171] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200925/nsinit-419)
Nov 16 22:53:52 kmcs kernel: [    1.659955] pcieport 0000:00:1c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Nov 16 22:53:52 kmcs kernel: [    6.029297] EXT4-fs (nvme0n1p6): re-mounted. Opts: errors=remount-ro
Nov 16 22:53:52 kmcs kernel: [    6.586128] mei_me 0000:00:16.0: hbm: dma setup response: failure = 3 REJECTED
Nov 16 22:53:52 kmcs kernel: [    6.833307] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
Nov 16 22:53:52 kmcs udisksd[661]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Nov 16 22:53:52 kmcs udisksd[661]: Failed to load the 'mdraid' libblockdev plugin
Nov 16 22:53:52 kmcs kernel: [    7.296869] thermal thermal_zone4: failed to read out thermal zone (-61)
Nov 16 22:53:53 kmcs systemd-xdg-autostart-generator[1080]: Not generating service for XDG autostart app-orca\x2dautostart-autostart.service, error parsing Exec= line: No such file or directory
Nov 16 22:53:53 kmcs pipewire[1082]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
Toute suggestion bienvenue
Qu’est-ce qui se bloque et qu’est-ce qui ne se bloque pas ?
Est-ce que tu as pu voir sur quoi le système butait pour le redémarrage ?
Je ne vois rien de problématique.
Enfin, j’ai juste un doute, si tu peux nous donne le retour de la commande mount pour voir, je ne sais pas si EXT4-fs (nvme0n1p6): re-mounted. Opts: errors=remount-ro est normal, pour voir si le système est bien monté en lecture-écriture.
Ce qui bloque: la barre de controle escamotable reste affichée et le menu « K » ainsi que tous les lanceurs ne répondent pas. De même le clic droit sur le bureau
Ce qui marche: les applications en cours d’execution du bureau actif dans l’activité en cours fonctionnent
Rien n’empêchait de redémarrer, c’est l’arrêt qui n’a pu aboutir. Même après 1 heure le système affichait encore des messages d’erreur. Je ne sais comment les retrouver. Dans syslog ?
Les messages suivants :
La commande demandée:
~$ sudo mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,noexec,relatime,size=16343272k,nr_inodes=4085818,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=3273608k,mode=755)
/dev/nvme0n1p6 on / type ext4 (rw,relatime,errors=remount-ro)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13368)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p4 on /ubuntu18 type ext4 (rw,relatime)
/dev/nvme0n1p2 on /ubuntu20 type ext4 (rw,relatime)
/dev/nvme0n1p5 on /usr/local/data type ext4 (rw,relatime)
/dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3273604k,nr_inodes=818401,mode=700,uid=1000,gid=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
