Tiens un guide pour installer clonezilla sur une partition :
clonezilla.org/livehd.php
[quote]
Clonezilla Live on Hard Drive
In this doc we explain how to put clonezilla live in your harddrive which already has an OS installed.
Here we use grub boot loader as an example. You have to put the clonezilla live files in a FAT, ext2/3, reiserfs or any grub supported partition.
If you do not have such a partition, you can use gparted to resize your partition and create another partition to put clonezilla live. Here we assume you already have a FAT partition /dev/sda4 to put clonezilla live. This is how to do that:
Boot the OS in the harddrive, saying it's GNU/Linux.
Mount /dev/sda4 as /mnt, you can make it by: mount /dev/sda4 /mnt
Download clonezilla live zip file, and unzip all the files in /mnt, make sure you put all the files in /mnt, say, "GPL" is in /mnt/, not in any subdir. You can make it by something like: "unzip clonezilla-live-*.zip -d /mnt" (Replace clonezilla-live-*.zip with the file name you just downloaded).
Change the dir name "live" under /mnt as another name, say "live-hd". You can make it by: "cd /mnt; mv live live-hd"
If your grub is version 1.x, edit your grub config file /boot/grub/menu.lst, and append the following:
title Clonezilla live on harddrive
root (hd0,3)
kernel /live-hd/vmlinuz boot=live live-config noswap nolocales edd=on nomodeset ocs_live_run="ocs-live-general" ocs_live_extra_param="" keyboard-layouts="" ocs_live_batch="no" locales="" vga=788 ip=frommedia nosplash live-media-path=/live-hd bootfrom=/dev/sda4 toram=filesystem.squashfs
initrd /live-hd/initrd.img
boot
//NOTE// There is a length limit (256 characters, for example) on the boot parameters for grub 1. For more info, please check this discussion.
If your grub is 2.x (grub-pc), e.g. on Debian Squeeze or Ubuntu 9.10, edit /etc/grub.d/40_custom, make it like:
menuentry "Clonezilla" {
set root=(hd0,4)
linux /live-hd/vmlinuz boot=live live-config noswap nolocales edd=on nomodeset ocs_live_run=\"ocs-live-general\" ocs_live_extra_param=\"\" keyboard-layouts=\"\" ocs_live_batch=\"no\" locales=\"\" vga=788 ip=frommedia nosplash live-media-path=/live-hd bootfrom=/dev/sda4 toram=filesystem.squashfs
//NOTE//
In grub2, (hd0,4) means the first harddrive and the 4th partition. It's different from that in grub version 1. Then run "update-grub2" to update your grub2 config. (Thanks to Louie Chen for providing this).
Remember to put back slash \ before " for the boot parameters in grub 2. Otherwise it won't shown in /proc/cmdline, then some actions of Clonezilla won't work.
Besides, you can use only the Clonezilal live iso file in grub2 (Thanks to the patches files from grml). For example, put clonezilla-live-1.2.6-24.iso in dir /home/isos/, then make the grub2 custom menu (/etc/grub.d/40_custom) like:
menuentry "Clonezilla live" {
set isofile="/home/isos/clonezilla-live-1.2.6-24.iso"
loopback loop $isofile
linux (loop)/live/vmlinuz boot=live live-config noswap nolocales edd=on nomodeset ocs_live_run=\"ocs-live-general\" ocs_live_extra_param=\"\" keyboard-layouts=\"\" ocs_live_batch=\"no\" locales=\"\" vga=788 ip=frommedia nosplash toram=filesystem.squashfs findiso=$isofile
initrd (loop)/live/initrd.img
Then run "update-grub2" to update your grub2 config.[/quote]
« You have to put the clonezilla live files in a FAT, ext2/3, reiserfs or any grub supported partition »
Logique ou primaire, ça n’a pas d’importance pour linux.
À la différence de Microsoft ou de FreeBSD, linux se démarre depuis les partitions logiques.
