Et voici :
Pour le copier / coller intégral de la mise à jour
[quote]root@WEB:/# apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following packages have been kept back:
db5.1-util
The following packages will be upgraded:
apache2 apache2-bin apache2-data apache2-utils apt-utils bind9-host ca-certificates dbconfig-common dnsutils file host
isc-dhcp-client isc-dhcp-common libapache2-mod-php5 libapt-inst1.5 libbind9-90 libcurl3-gnutls libdns-export100
libdns100 libirs-export91 libisc-export95 libisc95 libisccc90 libisccfg-export90 libisccfg90 libldap-2.4-2 liblwres90
libmagic1 libmysqlclient18 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpcre3
libpng12-0 libsystemd0 locales multiarch-support mysql-client-5.5 mysql-common mysql-server mysql-server-5.5
mysql-server-core-5.5 openssh-client openssh-server openssh-sftp-server passwd php5-cli php5-common php5-gd
php5-mcrypt php5-mysql php5-readline python-pygments rsyslog ssh systemd systemd-sysv
59 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
2 not fully installed or removed.
Need to get 0 B/31.3 MB of archives.
After this operation, 353 kB disk space will be freed.
Do you want to continue? [Y/n] y
Reading changelogs… Done
Extracting templates from packages: 100%
Preconfiguring packages …
Setting up udev (215-17+deb8u3) …
Failed to execute operation: Launch helper exited with unknown return code 1
Failed to restart udev.service: Launch helper exited with unknown return code 1
invoke-rc.d: initscript udev, action “restart” failed.
dpkg: error processing package udev (–configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
udev
root@WEB:/#[/quote]
Pour : cat /etc/apt/preferences
[quote] root@WEB:/# cat /etc/apt/preferences
cat: /etc/apt/preferences: No such file or directory
root@WEB:/# [/quote]
Pour : cat /etc/apt/preferences.d/*
[quote] root@WEB:/# cat /etc/apt/preferences.d/*
cat: /etc/apt/preferences.d/*: No such file or directory
Pour : dpkg --get-selections | grep hold
[quote] root@WEB:/# dpkg --get-selections | grep hold
Pour : aptitude -s upgrade
[quote]root@WEB:/# aptitude -s upgrade
Resolving dependencies…
host isc-dhcp-client isc-dhcp-common libapache2-mod-php5 libapt-inst1.5 libbind9-90 libcurl3-gnutls
libdns-export100 libdns100 libirs-export91 libisc-export95 libisc95 libisccc90 libisccfg-export90 libisccfg90
libldap-2.4-2 liblwres90 libmagic1 libmysqlclient18 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd
libpam0g libpcre3 libpng12-0 libsystemd0 locales multiarch-support mysql-client-5.5 mysql-common mysql-server
mysql-server-5.5 mysql-server-core-5.5 openssh-client openssh-server openssh-sftp-server passwd php5-cli
php5-common php5-gd php5-mcrypt php5-mysql php5-readline python-pygments rsyslog ssh systemd systemd-sysv
The following partially installed packages will be configured:
udev
59 packages upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/31.3 MB of archives. After unpacking 353 kB will be freed.
Do you want to continue? [Y/n/?] y
Would download/install/remove packages.
[quote] root@WEB:/# aptitude -s safe-upgrade
udev
Pour : aptitude -s full-upgrade
[quote] root@WEB:/# aptitude -s full-upgrade
apache2 apache2-bin apache2-data apache2-utils apt-utils bind9-host ca-certificates db5.1-util{b} dbconfig-common
dnsutils file host isc-dhcp-client isc-dhcp-common libapache2-mod-php5 libapt-inst1.5 libbind9-90 libcurl3-gnutls
udev
60 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 728 kB/32.0 MB of archives. After unpacking 1449 kB will be used.
The following packages have unmet dependencies:
db5.1-util : Breaks: libdb5.1 (< 5.1.29-8~) but 5.1.29-5 is installed.
The following actions will resolve these dependencies:
Remove the following packages:
db5.1-util
Accept this solution? [Y/n/q/?] y
The following packages will be REMOVED:
db5.1-util{a}
udev
59 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
Need to get 0 B/31.3 MB of archives. After unpacking 607 kB will be freed.
root@WEB:/#
Et voilà
Merci d’avance
