[Debian 8 "Jessy"] Fichier /etc/ssh/sshd_conf vide ?
Souhaitant vérifier que Linux Debian 8 soit sécurisé car d’après Chkrootkit de nombreux “warning” et présence de logiciels malveillants ?
Résultat de chkrootkit ( en partie :
[code]
Performing group and account checks
Checking for passwd file [ Found ]
Checking for root equivalent (UID 0) accounts [ None found ]
Checking for passwordless accounts [ None found ]
Checking for passwd file changes [ None found ]
Checking for group file changes [ None found ]
Checking root account shell history files [ OK ]
Performing system configuration file checks
Checking for an SSH configuration file [ Found ]
Checking if SSH root access is allowed [ Warning ]
Checking if SSH protocol v1 is allowed [ Warning ]
Checking for a running system logging daemon [ Found ]
Checking for a system logging configuration file [ Found ]
Checking if syslog remote logging is allowed [ Not allowed ]
Performing filesystem checks
Checking /dev for suspicious file types [ Warning ]
Checking for hidden files and directories [ Warning ]
[Press to continue]
System checks summary
File properties checks…
Files checked: 146
Suspect files: 0
Rootkit checks…
Rootkits checked : 379
Possible rootkits: 0
Applications checks…
All checks skipped[/code]
Le Fichier /etc/ssh/sshd_conf vide ?
–> Comment le restaurer ?
Hello,
Alors les possibles commandes à tester :
Ou bien tout supprimer et réinstaller (à ne pas faire via ssh bien entendu)
apt-get remove --purge openssh-server apt-get install ssh
