Après avoir lancer sous Linux Debian 8 les logiciels :
- Rkhunter, chkrootkit et Lynis :
Voici les résultats :
[b]
- Rkhunter :[/b]
[code]rkhunter -c
[ Rootkit Hunter version 1.4.2 ]
Checking system commands…
Performing ‘strings’ command checks
Checking ‘strings’ command [ OK ]
Performing ‘shared libraries’ checks
Checking for preloading variables [ None found ]
Checking for preloaded libraries [ None found ]
Checking LD_LIBRARY_PATH variable [ Not found ]
Performing file properties checks
Checking for prerequisites [ OK ]
/usr/local/sbin/sshd [ Warning ]
/usr/local/bin/ssh [ Warning ]
/usr/sbin/adduser [ OK ]
/usr/sbin/chroot [ OK ]
/usr/sbin/cron [ OK ]
/usr/sbin/groupadd [ OK ]
/usr/sbin/groupdel [ OK ]
/usr/sbin/groupmod [ OK ]
/usr/sbin/grpck [ OK ]
/usr/sbin/nologin [ OK ]
/usr/sbin/pwck [ OK ]
/usr/sbin/rsyslogd [ OK ]
/usr/sbin/tcpd [ OK ]
/usr/sbin/useradd [ OK ]
/usr/sbin/userdel [ OK ]
/usr/sbin/usermod [ OK ]
/usr/sbin/vipw [ OK ]
/usr/sbin/unhide-linux [ OK ]
/usr/sbin/unhide-posix [ OK ]
/usr/sbin/unhide-tcp [ OK ]
/usr/bin/awk [ OK ]
/usr/bin/basename [ OK ]
/usr/bin/chattr [ OK ]
/usr/bin/cut [ OK ]
/usr/bin/diff [ OK ]
/usr/bin/dirname [ OK ]
/usr/bin/dpkg [ Warning ]
/usr/bin/dpkg-query [ Warning ]
/usr/bin/du [ OK ]
/usr/bin/env [ OK ]
/usr/bin/file [ OK ]
/usr/bin/find [ OK ]
/usr/bin/GET [ OK ]
/usr/bin/groups [ OK ]
/usr/bin/head [ OK ]
/usr/bin/id [ OK ]
/usr/bin/killall [ OK ]
/usr/bin/last [ OK ]
/usr/bin/lastlog [ OK ]
/usr/bin/ldd [ OK ]
/usr/bin/less [ OK ]
/usr/bin/locate [ OK ]
/usr/bin/logger [ OK ]
/usr/bin/lsattr [ OK ]
/usr/bin/lsof [ OK ]
/usr/bin/mail [ OK ]
/usr/bin/md5sum [ OK ]
/usr/bin/mlocate [ OK ]
/usr/bin/newgrp [ OK ]
/usr/bin/passwd [ OK ]
/usr/bin/perl [ Warning ]
/usr/bin/pgrep [ OK ]
/usr/bin/pkill [ OK ]
/usr/bin/pstree [ OK ]
/usr/bin/rkhunter [ OK ]
/usr/bin/runcon [ OK ]
/usr/bin/sha1sum [ OK ]
/usr/bin/sha224sum [ OK ]
/usr/bin/sha256sum [ OK ]
/usr/bin/sha384sum [ OK ]
/usr/bin/sha512sum [ OK ]
/usr/bin/size [ OK ]
/usr/bin/sort [ OK ]
/usr/bin/ssh [ Warning ]
/usr/bin/stat [ OK ]
/usr/bin/strings [ OK ]
/usr/bin/sudo [ Warning ]
/usr/bin/tail [ OK ]
/usr/bin/telnet [ OK ]
/usr/bin/test [ OK ]
/usr/bin/top [ OK ]
/usr/bin/touch [ OK ]
/usr/bin/tr [ OK ]
/usr/bin/uniq [ OK ]
/usr/bin/users [ OK ]
/usr/bin/vmstat [ OK ]
/usr/bin/w [ OK ]
/usr/bin/watch [ OK ]
/usr/bin/wc [ OK ]
/usr/bin/wget [ OK ]
/usr/bin/whatis [ OK ]
/usr/bin/whereis [ OK ]
/usr/bin/which [ OK ]
/usr/bin/who [ OK ]
/usr/bin/whoami [ OK ]
/usr/bin/unhide [ OK ]
/usr/bin/gawk [ OK ]
/usr/bin/lwp-request [ OK ]
/usr/bin/bsd-mailx [ OK ]
/usr/bin/telnet.netkit [ OK ]
/usr/bin/w.procps [ OK ]
/sbin/depmod [ OK ]
/sbin/fsck [ OK ]
/sbin/ifconfig [ OK ]
/sbin/ifdown [ OK ]
/sbin/ifup [ OK ]
/sbin/init [ OK ]
/sbin/insmod [ OK ]
/sbin/ip [ OK ]
/sbin/lsmod [ OK ]
/sbin/modinfo [ OK ]
/sbin/modprobe [ OK ]
/sbin/rmmod [ OK ]
/sbin/route [ OK ]
/sbin/runlevel [ OK ]
/sbin/sulogin [ OK ]
/sbin/sysctl [ OK ]
/bin/bash [ OK ]
/bin/cat [ OK ]
/bin/chmod [ OK ]
/bin/chown [ OK ]
/bin/cp [ OK ]
/bin/date [ OK ]
/bin/df [ OK ]
/bin/dmesg [ OK ]
/bin/echo [ OK ]
/bin/egrep [ OK ]
/bin/fgrep [ OK ]
/bin/fuser [ OK ]
/bin/grep [ OK ]
/bin/ip [ OK ]
/bin/kill [ OK ]
/bin/less [ OK ]
/bin/login [ OK ]
/bin/ls [ OK ]
/bin/lsmod [ OK ]
/bin/mktemp [ OK ]
/bin/more [ OK ]
/bin/mount [ OK ]
/bin/mv [ OK ]
/bin/netstat [ OK ]
/bin/ping [ OK ]
/bin/ps [ OK ]
/bin/pwd [ OK ]
/bin/readlink [ OK ]
/bin/sed [ OK ]
/bin/sh [ OK ]
/bin/su [ OK ]
/bin/touch [ OK ]
/bin/uname [ OK ]
/bin/which [ OK ]
/bin/kmod [ OK ]
/bin/systemd [ OK ]
/bin/systemctl [ OK ]
/bin/dash [ OK ]
/lib/systemd/systemd [ OK ]
[Press to continue]
Checking for rootkits…
Performing check of known rootkit files and directories
55808 Trojan - Variant A [ Not found ]
ADM Worm [ Not found ]
AjaKit Rootkit [ Not found ]
Adore Rootkit [ Not found ]
aPa Kit [ Not found ]
Apache Worm [ Not found ]
Ambient (ark) Rootkit [ Not found ]
Balaur Rootkit [ Not found ]
BeastKit Rootkit [ Not found ]
beX2 Rootkit [ Not found ]
BOBKit Rootkit [ Not found ]
cb Rootkit [ Not found ]
CiNIK Worm (Slapper.B variant) [ Not found ]
Danny-Boy’s Abuse Kit [ Not found ]
Devil RootKit [ Not found ]
Dica-Kit Rootkit [ Not found ]
Dreams Rootkit [ Not found ]
Duarawkz Rootkit [ Not found ]
Enye LKM [ Not found ]
Flea Linux Rootkit [ Not found ]
Fu Rootkit [ Not found ]
Fuck`it Rootkit [ Not found ]
GasKit Rootkit [ Not found ]
Heroin LKM [ Not found ]
HjC Kit [ Not found ]
ignoKit Rootkit [ Not found ]
IntoXonia-NG Rootkit [ Not found ]
Irix Rootkit [ Not found ]
Jynx Rootkit [ Not found ]
KBeast Rootkit [ Not found ]
Kitko Rootkit [ Not found ]
Knark Rootkit [ Not found ]
ld-linuxv.so Rootkit [ Not found ]
Li0n Worm [ Not found ]
Lockit / LJK2 Rootkit [ Not found ]
Mood-NT Rootkit [ Not found ]
MRK Rootkit [ Not found ]
Ni0 Rootkit [ Not found ]
Ohhara Rootkit [ Not found ]
Optic Kit (Tux) Worm [ Not found ]
Oz Rootkit [ Not found ]
Phalanx Rootkit [ Not found ]
Phalanx2 Rootkit [ Not found ]
Phalanx2 Rootkit (extended tests) [ Not found ]
Portacelo Rootkit [ Not found ]
R3dstorm Toolkit [ Not found ]
RH-Sharpe’s Rootkit [ Not found ]
RSHA’s Rootkit [ Not found ]
Scalper Worm [ Not found ]
Sebek LKM [ Not found ]
Shutdown Rootkit [ Not found ]
SHV4 Rootkit [ Not found ]
SHV5 Rootkit [ Not found ]
Sin Rootkit [ Not found ]
Slapper Worm [ Not found ]
Sneakin Rootkit [ Not found ]
‘Spanish’ Rootkit [ Not found ]
Suckit Rootkit [ Not found ]
Superkit Rootkit [ Not found ]
TBD (Telnet BackDoor) [ Not found ]
TeLeKiT Rootkit [ Not found ]
T0rn Rootkit [ Not found ]
trNkit Rootkit [ Not found ]
Trojanit Kit [ Not found ]
Tuxtendo Rootkit [ Not found ]
URK Rootkit [ Not found ]
Vampire Rootkit [ Not found ]
VcKit Rootkit [ Not found ]
Volc Rootkit [ Not found ]
Xzibit Rootkit [ Not found ]
zaRwT.KiT Rootkit [ Not found ]
ZK Rootkit [ Not found ]
[Press to continue]
Performing additional rootkit checks
Suckit Rookit additional checks [ OK ]
Checking for possible rootkit files and directories [ None found ]
Checking for possible rootkit strings [ None found ]
Performing malware checks
Checking running processes for suspicious files [ None found ]
Checking for login backdoors [ None found ]
Checking for suspicious directories [ None found ]
Checking for sniffer log files [ None found ]
Suspicious Shared Memory segments [ None found ]
Performing Linux specific checks
Checking loaded kernel modules [ OK ]
Checking kernel module names [ OK ]
[Press to continue]
Checking the network…
Performing checks on the network ports
Checking for backdoor ports [ None found ]
Checking for hidden ports [ None found ]
Performing checks on the network interfaces
Checking for promiscuous interfaces [ None found ]
Checking the local host…
Performing system boot checks
Checking for local host name [ Found ]
Checking for system startup files [ Found ]
Checking system startup files for malware [ None found ]
Performing group and account checks
Checking for passwd file [ Found ]
Checking for root equivalent (UID 0) accounts [ None found ]
Checking for passwordless accounts [ None found ]
Checking for passwd file changes [ None found ]
Checking for group file changes [ None found ]
Checking root account shell history files [ OK ]
Performing system configuration file checks
Checking for an SSH configuration file [ Found ]
Checking if SSH root access is allowed [ Warning ]
Checking if SSH protocol v1 is allowed [ Warning ]
Checking for a running system logging daemon [ Found ]
Checking for a system logging configuration file [ Found ]
Checking if syslog remote logging is allowed [ Not allowed ]
Performing filesystem checks
Checking /dev for suspicious file types [ Warning ]
Checking for hidden files and directories [ Warning ]
[Press to continue]
System checks summary
File properties checks…
Files checked: 146
Suspect files: 7
Rootkit checks…
Rootkits checked : 379
Possible rootkits: 0
Applications checks…
All checks skipped
The system checks took: 5 minutes and 25 seconds
All results have been written to the log file: /var/log/rkhunter.log
One or more warnings have been found while checking the system.
Please check the log file (/var/log/rkhunter.log)
2) Chkrootkit
chkrootkit
ROOTDIR is /' Checkingamd’… not found
Checking basename'... not infected Checkingbiff’… not found
Checking chfn'... not infected Checkingchsh’… not infected
Checking cron'... not infected Checkingcrontab’… not infected
Checking date'... not infected Checkingdu’… not infected
Checking dirname'... not infected Checkingecho’… not infected
Checking egrep'... not infected Checkingenv’… not infected
Checking find'... not infected Checkingfingerd’… not found
Checking gpm'... not found Checkinggrep’… not infected
Checking hdparm'... not found Checkingsu’… not infected
Checking ifconfig'... not infected Checkinginetd’… not infected
Checking inetdconf'... not found Checkingidentd’… not found
Checking init'... not infected Checkingkillall’… not infected
Checking ldsopreload'... not infected Checkinglogin’… not infected
Checking ls'... not infected Checkinglsof’… not infected
Checking mail'... not infected Checkingmingetty’… not found
Checking netstat'... not infected Checkingnamed’… not found
Checking passwd'... not infected Checkingpidof’… not infected
Checking pop2'... not found Checkingpop3’… not found
Checking ps'... not infected Checkingpstree’… not infected
Checking rpcinfo'... not infected Checkingrlogind’… not found
Checking rshd'... not found Checkingslogin’… not infected
Checking sendmail'... not infected Checkingsshd’… not found
Checking syslogd'... not tested Checkingtar’… not infected
Checking tcpd'... not infected Checkingtcpdump’… not infected
Checking top'... not infected Checkingtelnetd’… not found
Checking timed'... not found Checkingtraceroute’… not infected
Checking vdir'... not infected Checkingw’… not infected
Checking write'... not infected Checkingaliens’… no suspect files
Searching for sniffer’s logs, it may take a while… nothing found
Searching for rootkit HiDrootkit’s default files… nothing found
Searching for rootkit t0rn’s default files… nothing found
Searching for t0rn’s v8 defaults… nothing found
Searching for rootkit Lion’s default files… nothing found
Searching for rootkit RSHA’s default files… nothing found
Searching for rootkit RH-Sharpe’s default files… nothing found
Searching for Ambient’s rootkit (ark) default files and dirs… nothing found
Searching for suspicious files and dirs, it may take a while… The following suspicious files and directories were found:
/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/.noinit /usr/lib/pymodules/python2.7/.path
Searching for LPD Worm files and dirs… nothing found
Searching for Ramen Worm files and dirs… nothing found
Searching for Maniac files and dirs… nothing found
Searching for RK17 files and dirs… nothing found
Searching for Ducoci rootkit… nothing found
Searching for Adore Worm… nothing found
Searching for ShitC Worm… nothing found
Searching for Omega Worm… nothing found
Searching for Sadmind/IIS Worm… nothing found
Searching for MonKit… nothing found
Searching for Showtee… nothing found
Searching for OpticKit… nothing found
Searching for T.R.K… nothing found
Searching for Mithra… nothing found
Searching for LOC rootkit… nothing found
Searching for Romanian rootkit… nothing found
Searching for Suckit rootkit… nothing found
Searching for Volc rootkit… nothing found
Searching for Gold2 rootkit… nothing found
Searching for TC2 Worm default files and dirs… nothing found
Searching for Anonoying rootkit default files and dirs… nothing found
Searching for ZK rootkit default files and dirs… nothing found
Searching for ShKit rootkit default files and dirs… nothing found
Searching for AjaKit rootkit default files and dirs… nothing found
Searching for zaRwT rootkit default files and dirs… nothing found
Searching for Madalin rootkit default files… nothing found
Searching for Fu rootkit default files… nothing found
Searching for ESRK rootkit default files… nothing found
Searching for rootedoor… nothing found
Searching for ENYELKM rootkit default files… nothing found
Searching for common ssh-scanners default files… nothing found
Searching for Linux/Ebury - Operation Windigo ssh… Possible Linux/Ebury - Operation Windigo installetd
Searching for 64-bit Linux Rootkit … nothing found
Searching for 64-bit Linux Rootkit modules… nothing found
Searching for suspect PHP files… nothing found
Searching for anomalies in shell history files… nothing found
Checking asp'... not infected Checkingbindshell’… not infected
Checking lkm'... chkproc: nothing detected chkdirs: nothing detected Checkingrexedcs’… not found
Checking sniffer'... lo: not promisc and no packet sniffer sockets wlan0: PACKET SNIFFER(/sbin/wpa_supplicant[873], /sbin/wpa_supplicant[873], /sbin/dhclient[1624]) Checkingw55808’… not infected
Checking wted'... chkwtmp: nothing deleted Checkingscalper’… not infected
Checking slapper'... not infected Checkingz2’… user Linux-2
deleted or never logged from lastlog!
Checking `chkutmp’… The tty of the following user process(es) were not found
in /var/run/utmp !
! RUID PID TTY CMD
! root 649 tty7 /usr/bin/Xorg :0 -novtswitch -background none -noreset -verbose 3 -auth /var/run/gdm3/auth-for-Debian-gdm-z3kfA8/database -seat seat0 -nolisten tcp vt7
netstat -nap | grep "@/proc/udevd"
find /lib* -type f -name libns2.so
ssh -G 2>&1 | grep -e illegal -e unknown > /dev/null && echo "System clean" || echo "System infected"
System infected
Comment se débarrasser de ces logiciels malveillants et les bloquer définitivement ?
