merci pour les infos
je ne sais pas ce que tout ça signifie mais avant chaque reboot jai le même message
Hibernation image partition 8:5 present
Dec 13 20:46:08 StarKiller kernel: [ 1.742169] PM: Looking for hibernation image.
Dec 13 20:46:08 StarKiller kernel: [ 1.742291] PM: Image not found (code -22)
Dec 13 20:46:08 StarKiller kernel: [ 1.742292] PM: Hibernation image not present or could not be loaded.
20:46:08 StarKiller kernel: [ 0.909979] libata version 3.00 loaded.
Dec 13 20:46:08 StarKiller kernel: [ 1.006185] ahci 0000:00:11.0: version 3.0
Dec 13 20:46:08 StarKiller kernel: [ 1.559665] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 13 20:46:08 StarKiller kernel: [ 1.559733] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 13 20:46:08 StarKiller kernel: [ 1.742169] PM: Hibernation image partition 8:5 present
Dec 13 20:54:13 StarKiller kernel: [ 487.361654] sd 6:
0:0:0: [sdc] Mode Sense: 23 00 00 00
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./FM2A68M-HD+, BIOS P2.00 01/12/2016
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] MTRR default type: uncachable
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] MTRR fixed ranges enabled:
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 00000-9FFFF write-back
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] A0000-BFFFF write-through
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] C0000-FFFFF write-protect
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] MTRR variable ranges enabled:
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 2 base 0000C0000000 mask FFFFE0000000 write-back
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 3 disabled
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 4 disabled
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 5 disabled
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 6 disabled
Dec 14 07:33:41 StarKiller kernel: [ 0.000000] 7 disabled
Dec 14 07:33:41 StarKiller kernel: [ 0.276928] pci_bus 0000:04: resource 1 [mem 0xfe900000-0xfe9fffff]
Dec 14 07:33:41 StarKiller kernel: [ 0.633692] PCI: CLS 64 bytes, default 64
Dec 14 07:33:41 StarKiller kernel: [ 0.885668] pcie_pme 0000:00:02.2:pcie001: service driver pcie_pme loaded
Dec 14 07:33:41 StarKiller kernel: [ 0.885685] pcie_pme 0000:00:15.0:pcie001: service driver pcie_pme loaded
Dec 14 07:33:41 StarKiller kernel: [ 0.885705] pcie_pme 0000:00:15.2:pcie001: service driver pcie_pme loaded
Dec 14 07:33:41 StarKiller kernel: [ 0.911872] PM: Hibernation image not present or could not be loaded.
Dec 14 07:33:41 StarKiller kernel: [ 0.959477] QUIRK: Enable AMD PLL fix
Dec 14 07:33:41 StarKiller kernel: [ 0.960492] libata version 3.00 loaded.
Dec 14 07:33:41 StarKiller kernel: [ 1.053967] ahci 0000:00:11.0: version 3.0
Dec 14 07:33:41 StarKiller kernel: [ 1.611240] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 14 07:33:41 StarKiller kernel: [ 1.611257] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 14 07:33:41 StarKiller kernel: [ 1.820978] PM: Hibernation image partition 8:5 present
Dec 14 07:33:41 StarKiller kernel: [ 1.820978] PM: Looking for hibernation image.
Dec 14 07:33:41 StarKiller kernel: [ 1.821091] PM: Image not found (code -22)
Dec 14 07:33:41 StarKiller kernel: [ 1.821092] PM: Hibernation image not present or could not be loaded.
Dec 14 07:33:41 StarKiller kernel: [ 2.451341] sd 6:0:0:0: [sdc] Mode Sense: 23 00 00 00
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./FM2A68M-HD+, BIOS P2.00 01/12/2016
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] MTRR default type: uncachable
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] MTRR fixed ranges enabled:
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 00000-9FFFF write-back
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] A0000-BFFFF write-through
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] C0000-FFFFF write-protect
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] MTRR variable ranges enabled:
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 2 base 0000C0000000 mask FFFFE0000000 write-back
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 3 disabled
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 4 disabled
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 5 disabled
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 6 disabled
Dec 14 11:02:31 StarKiller kernel: [ 0.000000] 7 disabled
je vais essayer une version 32 bits
