Aprés avoir réussi à activer ma carte wifi sous la debian etch, nouvellement installée sur mon portable, j’ai essayé, encore avec succes et grande joie d’aller sur le net avec le navigateur mozilla fire-fox (ou konqueror) et ceci en utilisant un serveur proxy.
Mais, quand je fais en ligne de commande, un:
j’obtiens:
[quote]Ign security.debian.org etch/updates Release.gpg
Ign security.debian.org etch/updates/main Packages
Ign security.debian.org etch/updates/contrib Packages
Ign security.debian.org etch/updates/main Sources
Ign security.debian.org etch/updates/contrib Sources
Err security.debian.org etch/updates/main Packages
302 Found [IP: 128.101.240.212 80]
Err security.debian.org etch/updates/contrib Packages
Err security.debian.org etch/updates/main Sources
Err security.debian.org etch/updates/contrib Sources
Failed to fetch security.debian.org/dists/etch/u … ackages.gz 302 Found [IP: 128.101.240.212 80]
Failed to fetch security.debian.org/dists/etch/u … Sources.gz 302 Found [IP: 128.101.240.212 80]
Reading package lists… Done
W: Couldn’t stat source package list security.debian.org etch/updates/main Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_main_binary-amd64_Packages) - stat (2 No such file or directory)
W: Couldn’t stat source package list security.debian.org etch/updates/contrib Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_contrib_binary-amd64_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Some index files failed to download, they have been ignored, or old ones used instead.[/quote]
Sachant qu’un:
aboutit à:
[quote]#
deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-1 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-21 (20061110)]/ etch main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-20 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-19 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-18 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-17 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-16 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-15 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-14 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-13 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-12 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-11 (20061110)]/ etch main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-10 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-9 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-8 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-7 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-6 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-5 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-4 (20061110)]/ etch contrib main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-3 (20061110)]/ etch main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-2 (20061110)]/ etch main
#deb cdrom:[Debian GNU/Linux testing Etch - Official Snapshot amd64 Binary-1 (20061110)]/ etch contrib main
Line commented out by installer because it failed to verify:
deb security.debian.org/ etch/updates main contrib
deb-src security.debian.org/ etch/updates main contrib[/quote]
Bien sur, avant d’avoir activé ma carte-wifi et donc avant de pouvoir aller sur le net, j’avais scanné tout les 21 CDs que j’avais téléchargé, mais une fois j’ai eu le net, j’ai commanté toutes les lignes crdom (et décommanté ceux en url).
Donc mes deux questions sont:
1°) Quelle configuration dois-je faire, pour ne pas avoir de message d’erreur, lors d’un apt-get update(et apt-get install) ?
2°) Exist-il d’autres URL(correspondants à la distribution citée) à ajouter au sources.list ?
Merci d’avance pour l’aide.
P.S.
- Konqueror et Firefox sont configurés avec un proxy.
-$ cat /etc/issue
